[GRASS-SVN] r43961 - grass/trunk/lib/python
Mon Oct 18 06:20:11 EDT 2010
Author: martinl
Date: 2010-10-18 03:20:11 -0700 (Mon, 18 Oct 2010)
New Revision: 43961
   grass/trunk/lib/python/core.py
improve *_command() dox strings
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py	2010-10-18 10:01:46 UTC (rev 43960)
+++ grass/trunk/lib/python/core.py	2010-10-18 10:20:11 UTC (rev 43961)
@@ -87,11 +87,11 @@
     @endcode
     @param prog GRASS module
-    @param flags flags to be used
-    @param overwrite True to enable overwriting the output (--o)
-    @param quiet run quietly (--q)
-    @param verbose run verbosely (--v)
-    @param options
+    @param flags flags to be used (given as a string)
+    @param overwrite True to enable overwriting the output (<tt>--o</tt>)
+    @param quiet True to run quietly (<tt>--q</tt>)
+    @param verbose True to run verbosely (<tt>--v</tt>)
+    @param options module's parameters
     @return list of arguments
@@ -130,12 +130,12 @@
     \endcode
-    @param kwargs
+    @param kwargs module's parameters
     @return Popen object
     options = {}
@@ -159,10 +159,10 @@
     complete, returning its exit code. Similar to subprocess.call(), but
     with the make_command() interface.
-    @param args
-    @param kwargs
+    @param args list of unnamed arguments (see start_command() for details)
+    @param kwargs list of named arguments (see start_command() for details)
-    @return exit code
+    @return exit code (0 for success)
     ps = start_command(*args, **kwargs)
     return ps.wait()
@@ -184,8 +184,8 @@
     MONITOR='x0';
     \endcode
-    @param args
-    @param kwargs
@@ -196,9 +196,9 @@
     """!Passes all arguments to start_command, but also adds
     "stdin = PIPE". Returns the Popen object.
-    @param args
-    @param kwargs
     kwargs['stdin'] = PIPE
@@ -208,9 +208,9 @@
     """!Passes all arguments to pipe_command, then waits for the process to
     complete, returning its stdout (i.e. similar to shell `backticks`).
-    @param args
-    @param kwargs
     @return stdout
     ps = pipe_command(*args, **kwargs)
@@ -227,9 +227,9 @@
     parse_command(..., parse = (grass.parse_key_val, { 'sep' : ':' }))
     @endcode
-    @param args
-    @param kwargs
     @return parsed module output
     parse = None
@@ -251,8 +251,8 @@
     """!Passes all arguments to feed_command, with the string specified
     by the 'stdin' argument fed to the process' stdin.
-    @param args
-    @param kwargs
     @return return code
@@ -266,12 +266,13 @@
     """!Interface to os.execvpe(), but with the make_command() interface.
-    @param env environment variable (default os.environ)
-    @param kwargs
+    @param env directory with enviromental variables
     args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
     if env == None:
