[GRASS-SVN] r43964 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Oct 18 07:03:28 EDT 2010
Author: martinl
Date: 2010-10-18 04:03:28 -0700 (Mon, 18 Oct 2010)
New Revision: 43964
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location wizard: some more fixes related to #1167 (by Anna Kratochvilova)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-10-18 10:23:17 UTC (rev 43963)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-10-18 11:03:28 UTC (rev 43964)
@@ -122,8 +122,7 @@
self.Layout()
class DatabasePage(TitledPage):
- """!Wizard page for setting GIS data directory and location name
+ """!Wizard page for setting GIS data directory and location name"""
def __init__(self, wizard, parent, grassdatabase):
TitledPage.__init__(self, wizard, _("Define GRASS Database and Location Name"))
@@ -169,7 +168,6 @@
# bindings
self.Bind(wx.EVT_BUTTON, self.OnBrowse, self.bbrowse)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
- self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.tgisdbase.Bind(wx.EVT_TEXT, self.OnChangeName)
self.tlocation.Bind(wx.EVT_TEXT, self.OnChangeName)
@@ -185,6 +183,7 @@
event.Skip()
def OnBrowse(self, event):
+ """!Choose GRASS data directory"""
dlg = wx.DirDialog(self, _("Choose GRASS data directory:"),
os.getcwd(), wx.DD_DEFAULT_STYLE)
if dlg.ShowModal() == wx.ID_OK:
@@ -213,17 +212,10 @@
self.location = self.tlocation.GetValue()
self.grassdatabase = self.tgisdbase.GetValue()
- def OnEnterPage(self, event):
- """!Wizard page changed"""
- self.grassdatabase = self.tgisdbase.GetValue()
- self.location = self.tlocation.GetValue()
- event.Skip()
class CoordinateSystemPage(TitledPage):
- Wizard page for choosing method for location creation
+ """!Wizard page for choosing method for location creation"""
def __init__(self, wizard, parent):
TitledPage.__init__(self, wizard, _("Choose method for creating a new location"))
@@ -332,9 +324,7 @@
self.parent.sumpage.SetPrev(self.parent.csystemspage)
class ProjectionsPage(TitledPage):
- Wizard page for selecting projection (select coordinate system option)
+ """!Wizard page for selecting projection (select coordinate system option)"""
TitledPage.__init__(self, wizard, _("Choose projection"))
@@ -385,10 +375,7 @@
self.projlist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
- # do layout
- # self.Layout()
def OnPageChanging(self,event):
if event.GetDirection() and self.proj not in self.parent.projections.keys():
event.Veto()
@@ -398,7 +385,7 @@
self.proj = event.GetString().lower()
self.p4proj = ''
nextButton = wx.FindWindowById(wx.ID_FORWARD)
- if len(self.proj) == 0 and nextButton.IsEnabled():
+ if self.proj not in self.parent.projections.keys() and nextButton.IsEnabled():
nextButton.Enable(False)
if self.proj in self.parent.projections.keys():
@@ -615,7 +602,6 @@
def Search (self, index, pattern):
"""!Search projection by description
Return first found item or None
if pattern == '':
@@ -739,9 +725,9 @@
self.projdesc = self.parent.projections[self.parent.projpage.proj][0]
if self.prjParamSizer is None:
# entering page for the first time
- paramSBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ self.paramSBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label=_(" Enter parameters for %s projection ") % self.projdesc)
- paramSBSizer = wx.StaticBoxSizer(paramSBox)
+ paramSBSizer = wx.StaticBoxSizer(self.paramSBox)
self.panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
self.panel.SetupScrolling()
@@ -758,7 +744,7 @@
if event.GetDirection():
self.prjParamSizer.Clear(True)
+ self.paramSBox.SetLabel(_(" Enter parameters for %s projection ") % self.projdesc)
self.pparam = dict()
row = 0
for paramgrp in self.parent.projections[self.parent.projpage.proj][1]:
@@ -945,6 +931,7 @@
event.Skip()
def OnDText(self, event):
+ """!Datum code changed"""
self.datum = event.GetString()
@@ -973,6 +960,7 @@
event.Skip()
def OnDSearch(self, event):
+ """!Search geodetic datum by desc"""
str = self.searchb.GetValue()
try:
self.datum, self.ellipsoid, self.datumdesc = self.datumlist.Search(index=[0,1,2], pattern=str)
@@ -982,6 +970,7 @@
event.Skip()
def OnDatumSelected(self, event):
+ """!Datum selected"""
index = event.m_itemIndex
item = event.GetItem()
@@ -991,9 +980,7 @@
event.Skip()
class EllipsePage(TitledPage):
- Wizard page for selecting ellipsoid (select coordinate system option)
+ """!Wizard page for selecting ellipsoid (select coordinate system option)"""
TitledPage.__init__(self, wizard, _("Specify ellipsoid"))
@@ -1099,6 +1086,7 @@
event.Skip()
def OnItemSelected(self,event):
+ """!Ellipsoid selected"""
@@ -1108,10 +1096,8 @@
event.Skip()
class GeoreferencedFilePage(TitledPage):
- Wizard page for selecting georeferenced file to use
- for setting coordinate system parameters
+ """!Wizard page for selecting georeferenced file to use
+ for setting coordinate system parameters"""
TitledPage.__init__(self, wizard, _("Select georeferenced file"))
@@ -1152,13 +1138,14 @@
event.Skip()
def OnPageChanging(self, event):
- if event.GetDirection() and self.georeffile == '':
+ if event.GetDirection() and not os.path.isfile(self.georeffile):
event.Veto()
self.GetNext().SetPrev(self)
event.Skip()
def OnText(self, event):
+ """!File changed"""
self.georeffile = event.GetString()
if len(self.georeffile) > 0 and os.path.isfile(self.georeffile):
@@ -1182,14 +1169,9 @@
event.Skip()
- def OnCreate(self, event):
- pass
class WKTPage(TitledPage):
- Wizard page for selecting WKT file to use
+ """!Wizard page for selecting WKT file to use
TitledPage.__init__(self, wizard, _("Select WKT file"))
@@ -1227,13 +1209,14 @@
event.Skip()
- if event.GetDirection() and self.wktfile == '':
+ if event.GetDirection() and not os.path.isfile(self.wktfile):
event.Veto()
event.Skip()
self.wktfile = event.GetString()
if len(self.wktfile) > 0 and os.path.isfile(self.wktfile):
@@ -1257,14 +1240,9 @@
event.Skip()
- pass
class EPSGPage(TitledPage):
- Wizard page for selecting EPSG code for
- setting coordinate system parameters
+ """!Wizard page for selecting EPSG code for
+ setting coordinate system parameters"""
TitledPage.__init__(self, wizard, _("Choose EPSG Code"))
@@ -1471,10 +1449,8 @@
self.epsglist.Populate(data, update=True)
class CustomPage(TitledPage):
- Wizard page for entering custom PROJ.4 string
+ """!Wizard page for entering custom PROJ.4 string
@@ -1509,14 +1485,9 @@
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
- event.Skip()
- if event.GetDirection() and not self.customstring:
- event.Veto()
- elif not event.GetDirection() and not self.customstring:
- return
- else: # check for datum tranforms
+ if event.GetDirection():
+ # check for datum tranforms
ret, out, err = gcmd.RunCommand('g.proj',
read = True, getErrorMsg = True,
proj4 = self.customstring,
@@ -1563,19 +1534,19 @@
class SummaryPage(TitledPage):
"""!Shows summary result of choosing coordinate system parameters
- prior to creating location
+ prior to creating location"""
TitledPage.__init__(self, wizard, _("Summary"))
self.parent = parent
- self.panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
+ self.panel_proj4string = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
+ self.panel_proj = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
# labels
self.ldatabase = self.MakeLabel()
self.llocation = self.MakeLabel()
- self.lprojection = self.MakeLabel()
- self.lproj4string = self.MakeLabel(parent = self.panel)
+ self.lprojection = self.MakeLabel(parent = self.panel_proj)
+ self.lproj4string = self.MakeLabel(parent = self.panel_proj4string)
@@ -1585,17 +1556,22 @@
def __DoLayout(self):
"""!Do page layout"""
self.sizer.AddGrowableCol(1)
- self.sizer.AddGrowableRow(4)
+ self.sizer.AddGrowableRow(3,1)
+ self.sizer.AddGrowableRow(4,5)
- proj4Sizer = wx.BoxSizer(wx.VERTICAL)
- proj4Sizer.Add(item = self.lproj4string, proportion = 1,
- flag = wx.EXPAND | wx.ALL, border = 1)
- self.panel.SetSizer(proj4Sizer)
- self.panel.SetAutoLayout(True)
- proj4Sizer.Fit(self.panel)
- self.panel.Layout()
- self.panel.SetupScrolling()
+ projSizer = wx.BoxSizer(wx.VERTICAL)
+ projSizer.Add(item = self.lprojection, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ self.panel_proj.SetSizer(projSizer)
+ proj4stringSizer = wx.BoxSizer(wx.VERTICAL)
+ proj4stringSizer.Add(item = self.lproj4string, proportion = 1,
+ self.panel_proj4string.SetSizer(proj4stringSizer)
+ self.panel_proj4string.SetupScrolling()
+ self.panel_proj.SetupScrolling(scroll_y=False)
self.sizer.Add(item=self.MakeLabel(_("GRASS Database:")),
flag=wx.ALIGN_LEFT | wx.ALL,
border=5, pos=(1, 0))
@@ -1611,16 +1587,16 @@
self.sizer.Add(item=self.MakeLabel(_("Projection:")),
border=5, pos=(3, 0))
- self.sizer.Add(item=self.lprojection,
- flag=wx.ALIGN_LEFT | wx.ALL,
- border=5, pos=(3, 1))
+ self.sizer.Add(item=self.panel_proj,
+ flag=wx.ALIGN_LEFT | wx.ALL| wx.EXPAND,
+ border=0, pos=(3, 1))
self.sizer.Add(item=self.MakeLabel(_("PROJ.4 definition:")),
border=5, pos=(4, 0))
- self.sizer.Add(item=self.panel,
+ self.sizer.Add(item=self.panel_proj4string,
flag=wx.ALIGN_LEFT | wx.ALL | wx.EXPAND,
- border=5, pos=(4, 1))
+ border=0, pos=(4, 1))
"""!Insert values into text controls for summary of location
creation options
@@ -1656,6 +1632,7 @@
finishButton.Enable(True)
else:
gcmd.GError(err, parent = self)
+ self.lproj4string.SetLabel('')
finishButton.Enable(False)
projdesc = self.parent.projpage.projdesc
@@ -1669,12 +1646,15 @@
label = 'EPSG code %s (%s)' % (self.parent.epsgpage.epsgcode, self.parent.epsgpage.epsgdesc)
elif coordsys == 'file':
label = 'matches file %s' % self.parent.filepage.georeffile
+ self.lproj4string.SetLabel("")
elif coordsys == 'wkt':
label = 'matches file %s' % self.parent.wktpage.wktfile
elif coordsys == 'proj':
label = ('%s, %s %s' % (projdesc, datumdesc, ellipsedesc))
elif coordsys == 'xy':
label = ('XY coordinate system (not projected).')
elif coordsys == 'custom':
label = _("custom")
self.lproj4string.SetLabel(('%s' % self.parent.custompage.customstring.replace(' ', os.linesep)))
