[GRASS-SVN] r43973 - grass/trunk/imagery/i.rectify
    svn_grass at osgeo.org
    Mon Oct 18 11:30:41 EDT 2010
Author: mmetz
Date: 2010-10-18 08:30:41 -0700 (Mon, 18 Oct 2010)
New Revision: 43973
   grass/trunk/imagery/i.rectify/bilinear.c
   grass/trunk/imagery/i.rectify/bilinear_f.c
   grass/trunk/imagery/i.rectify/cubic.c
   grass/trunk/imagery/i.rectify/cubic_f.c
apply r43944 to i.rectify: Glynn: Don't store pointer to cache blocks which may be replaced
Modified: grass/trunk/imagery/i.rectify/bilinear.c
--- grass/trunk/imagery/i.rectify/bilinear.c	2010-10-18 15:12:24 UTC (rev 43972)
+++ grass/trunk/imagery/i.rectify/bilinear.c	2010-10-18 15:30:41 UTC (rev 43973)
@@ -23,50 +23,38 @@
 		struct Cell_head *cellhd	/* information of output map     */
-    int row0,			/* lower row index for interp    */
-      row1,			/* upper row index for interp    */
-      col0,			/* lower column index for interp */
-      col1;			/* upper column index for interp */
-    DCELL t, u,			/* intermediate slope            */
-      tu,			/* t * u                         */
-      result;			/* result of interpolation       */
-    DCELL *c00, *c01, *c10, *c11;
+    int row;			/* row indices for interp        */
+    int col;			/* column indices for interp     */
+    int i, j;
+    DCELL t, u;			/* intermediate slope            */
+    DCELL result;		/* result of interpolation       */
+    DCELL c[2][2];
-    /* cut indices to integer and get nearest cells */
-    /* example: *row_idx = 2.1
-     * nearest rows are 1 and 2, not 2 and 3 */
-    *row_idx -= 0.5;
-    *col_idx -= 0.5;
-    row0 = (int)floor(*row_idx);
-    col0 = (int)floor(*col_idx);
-    row1 = row0 + 1;
-    col1 = col0 + 1;
+    /* cut indices to integer */
+    row = (int)floor(*row_idx - 0.5);
+    col = (int)floor(*col_idx - 0.5);
     /* check for out of bounds - if out of bounds set NULL value and return */
-    if (row0 < 0 || row1 >= cellhd->rows || col0 < 0 || col1 >= cellhd->cols) {
+    if (row < 0 || row + 1 >= cellhd->rows || col < 0 || col + 1 >= cellhd->cols) {
 	Rast_set_null_value(obufptr, 1, cell_type);
 	return;
-    c00 = CPTR(ibuffer, row0, col0);
-    c01 = CPTR(ibuffer, row0, col1);
-    c10 = CPTR(ibuffer, row1, col0);
-    c11 = CPTR(ibuffer, row1, col1);
+    for (i = 0; i < 2; i++)
+	for (j = 0; j < 2; j++) {
+	    const DCELL *cellp = CPTR(ibuffer, row + i, col + j);
+	    if (Rast_is_f_null_value(cellp)) {
+		Rast_set_null_value(obufptr, 1, cell_type);
+		return;
+	    c[i][j] = *cellp;
-    /* check for NULL values */
-    if (Rast_is_f_null_value(c00) ||
-	Rast_is_f_null_value(c01) ||
-	Rast_is_f_null_value(c10) || Rast_is_f_null_value(c11)) {
-	Rast_set_null_value(obufptr, 1, cell_type);
-	return;
     /* do the interpolation  */
-    t = *col_idx - col0;
-    u = *row_idx - row0;
-    tu = t * u;
+    t = *col_idx - 0.5 - col;
+    u = *row_idx - 0.5 - row;
-    result = Rast_interp_bilinear(t, u, *c00, *c01, *c10, *c11);
+    result = Rast_interp_bilinear(t, u, c[0][0], c[0][1], c[1][0], c[1][1]);
     Rast_set_d_value(obufptr, result, cell_type);
Modified: grass/trunk/imagery/i.rectify/bilinear_f.c
--- grass/trunk/imagery/i.rectify/bilinear_f.c	2010-10-18 15:12:24 UTC (rev 43972)
+++ grass/trunk/imagery/i.rectify/bilinear_f.c	2010-10-18 15:30:41 UTC (rev 43973)
@@ -23,7 +23,7 @@
     /* start nearest neighbor to do some basic tests */
     int row, col;		/* row/col of nearest neighbor   */
-    DCELL *cellp;
+    DCELL *cellp, cell;
     row = (int)floor(*row_idx);
@@ -41,9 +41,10 @@
         return;
-    p_bilinear(ibuffer, obufptr, cell_type, row_idx, col_idx, cellhd);
+    cell = *cellp;
+    p_bilinear(ibuffer, obufptr, cell_type, col_idx, row_idx, cellhd);
     /* fallback to nearest if bilinear is null */
     if (Rast_is_d_null_value(obufptr))
-        Rast_set_d_value(obufptr, *cellp, cell_type);
+        Rast_set_d_value(obufptr, cell, cell_type);
Modified: grass/trunk/imagery/i.rectify/cubic.c
--- grass/trunk/imagery/i.rectify/cubic.c	2010-10-18 15:12:24 UTC (rev 43972)
+++ grass/trunk/imagery/i.rectify/cubic.c	2010-10-18 15:30:41 UTC (rev 43973)
@@ -25,24 +25,17 @@
-    int row,			/* row indices for interp        */
-      col;			/* column indices for interp     */
     int i, j;
-      result,			/* result of interpolation       */
-      val[4];			/* buffer for temporary values   */
-    DCELL *cellp[4][4];
+    DCELL val[4];		/* buffer for temporary values   */
+    DCELL cell[4][4];
-     * nearest rows are 0, 1, 2 and 3, not 1, 2, 3 and 4
-     * row 0 streches from 0 to 1, row 4 from 4 to 5
-     * 2.1 - 1 = 1.1
-     * 4 - 2.1 = 1.9 */
-    *row_idx -= 0.5;
-    *col_idx -= 0.5;
-    row = (int)floor(*row_idx);
-    col = (int)floor(*col_idx);
     /* check for out of bounds of map - if out of bounds set NULL value     */
     if (row - 1 < 0 || row + 2 >= cellhd->rows ||
@@ -52,26 +45,21 @@
     for (i = 0; i < 4; i++)
-	for (j = 0; j < 4; j++)
-	    cellp[i][j] = CPTR(ibuffer, row - 1 + i, col - 1 + j);
-    /* check for NULL value                                         */
-    for (i = 0; i < 4; i++)
 	for (j = 0; j < 4; j++) {
-	    if (Rast_is_d_null_value(cellp[i][j])) {
+	    const DCELL *cellp = CPTR(ibuffer, row - 1 + i, col - 1 + j);
+	    if (Rast_is_d_null_value(cellp)) {
 		return;
+	    cell[i][j] = *cellp;
-    t = *col_idx - col;
-    u = *row_idx - row;
     for (i = 0; i < 4; i++) {
-	DCELL **tmp = cellp[i];
-	val[i] = Rast_interp_cubic(t, *tmp[0], *tmp[1], *tmp[2], *tmp[3]);
+	val[i] = Rast_interp_cubic(t, cell[i][0], cell[i][1], cell[i][2], cell[i][3]);
     result = Rast_interp_cubic(u, val[0], val[1], val[2], val[3]);
Modified: grass/trunk/imagery/i.rectify/cubic_f.c
--- grass/trunk/imagery/i.rectify/cubic_f.c	2010-10-18 15:12:24 UTC (rev 43972)
+++ grass/trunk/imagery/i.rectify/cubic_f.c	2010-10-18 15:30:41 UTC (rev 43973)
@@ -24,7 +24,7 @@
-    DCELL *cellp;
@@ -42,6 +42,7 @@
         return;
+	cell = *cellp;
     p_cubic(ibuffer, obufptr, cell_type, row_idx, col_idx, cellhd);
     /* fallback to bilinear if cubic is null */
