[GRASS-SVN] r43987 - grass/trunk/imagery/i.landsat.toar
svn_grass at osgeo.org
Thu Oct 21 14:29:38 EDT 2010
Author: martinl
Date: 2010-10-21 11:29:38 -0700 (Thu, 21 Oct 2010)
New Revision: 43987
grass/trunk/imagery/i.landsat.toar/main.c
i.landsat.toar: very basic clean up after adding to trunk
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2010-10-21 10:27:03 UTC (rev 43986)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2010-10-21 18:29:38 UTC (rev 43987)
@@ -10,11 +10,11 @@
* PURPOSE: Calculate TOA Radiance or Reflectance and Kinetic Temperature
* for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
- * COPYRIGHT: (C) 2002, 2005 2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002, 2005, 2008, 2010 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -30,34 +30,31 @@
struct History history;
struct GModule *module;
- struct Cell_head cellhd, window;
- char *mapset;
+ struct Cell_head cellhd;
void *inrast, *outrast;
int infd, outfd;
void *ptr;
int nrows, ncols, row, col;
RASTER_MAP_TYPE in_data_type;
- int verbose = TRUE;
struct Option *input, *metfn, *sensor, *adate, *pdate, *elev,
*bgain, *metho, *perc, *dark, *satz, *atmo;
char *name, *met;
struct Flag *msss, *verbo, *frad, *l5_mtl;
lsat_data lsat;
char band_in[127], band_out[127];
int i, j, q, method, pixel, dn_dark[MAX_BANDS], dn_mode[MAX_BANDS];
- int sensor_id;
double qcal, rad, ref, percent, ref_mode, sat_zenith, rayleigh;
struct Colors colors;
struct FPRange range;
double min, max;
unsigned long hist[256], h_max;
/* initialize GIS environment */
G_gisinit(argv[0]);
@@ -67,24 +64,18 @@
_("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+.");
G_add_keyword(_("imagery"));
G_add_keyword(_("landsat"));
- G_add_keyword(_("top-of-atmosphere radiance"));
G_add_keyword(_("top-of-atmosphere reflectance"));
G_add_keyword(_("dos-type simple atmospheric correction"));
/* It defines the different parameters */
- input = G_define_option();
+ input = G_define_standard_option(G_OPT_R_INPUT);
input->key = "band_prefix";
- input->type = TYPE_STRING;
- input->required = YES;
- input->gisprompt = "input,cell,raster";
- input->description = _("Base name of the landsat band rasters (.#)");
+ input->description = _("Base name of Landsat band rasters (.#)");
- metfn = G_define_option();
+ metfn = G_define_standard_option(G_OPT_F_INPUT);
metfn->key = "metfile";
- metfn->type = TYPE_STRING;
metfn->required = NO;
- metfn->gisprompt = "old_file,file,file";
- metfn->description = _("Landsat ETM+ or TM5 header file (.met)");
+ metfn->description = _("Name of Landsat ETM+ or TM5 header file (.met)");
metho = G_define_option();
metho->key = "method";
@@ -93,18 +84,22 @@
metho->options = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
metho->description = _("Atmospheric correction method");
metho->answer = "uncorrected";
+ metho->guisection = _("Settings");
sensor = G_define_option();
sensor->key = "sensor";
- sensor->type = TYPE_INTEGER;
+ sensor->type = TYPE_STRING;
sensor->description = _("Spacecraft sensor");
- sensor->options = "1,2,3,4,5,7";
+ sensor->options = "mss1,mss2,mss3,tm4,tm5,tm7";
sensor->descriptions =
- _("1;Landsat-1 MSS;"
- "2;Landsat-2 MSS;"
- "3;Landsat-3 MSS;"
- "4;Landsat-4 TM;" "5;Landsat-5 TM;" "7;Landsat-7 ETM+");
+ _("mss1;Landsat-1 MSS;"
+ "mss2;Landsat-2 MSS;"
+ "mss3;Landsat-3 MSS;"
+ "tm4;Landsat-4 TM;"
+ "tm5;Landsat-5 TM;"
+ "tm7;Landsat-7 ETM+");
sensor->required = NO;
+ sensor->guisection = _("Settings");
adate = G_define_option();
adate->key = "date";
@@ -112,12 +107,14 @@
adate->required = NO;
adate->key_desc = "yyyy-mm-dd";
adate->description = _("Image acquisition date (yyyy-mm-dd)");
+ adate->guisection = _("Date settings");
elev = G_define_option();
elev->key = "solar_elevation";
elev->type = TYPE_DOUBLE;
elev->required = NO;
elev->description = _("Solar elevation in degrees");
+ elev->guisection = _("Settings");
bgain = G_define_option();
bgain->key = "gain";
@@ -125,6 +122,7 @@
bgain->required = NO;
bgain->description =
_("Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)");
+ bgain->guisection = _("Settings");
pdate = G_define_option();
pdate->key = "product_date";
@@ -132,6 +130,7 @@
pdate->required = NO;
pdate->key_desc = "yyyy-mm-dd";
pdate->description = _("Image creation date (yyyy-mm-dd)");
+ pdate->guisection = _("Date settings");
perc = G_define_option();
perc->key = "percent";
@@ -139,6 +138,7 @@
perc->required = NO;
perc->description = _("Percent of solar radiance in path radiance");
perc->answer = "0.01";
+ perc->guisection = _("Settings");
dark = G_define_option();
dark->key = "pixel";
@@ -147,6 +147,7 @@
dark->description =
_("Minimum pixels to consider digital number as dark object");
dark->answer = "1000";
+ dark->guisection = _("Settings");
satz = G_define_option();
satz->key = "sat_zenith";
@@ -154,6 +155,7 @@
satz->required = NO;
satz->description = _("Satellite zenith in degrees");
satz->answer = "8.2000";
+ satz->guisection = _("Settings");
atmo = G_define_option();
atmo->key = "rayleigh";
@@ -161,19 +163,22 @@
atmo->required = NO;
atmo->description = _("Rayleigh atmosphere"); /* scattering coefficient? */
atmo->answer = "0.0";
+ atmo->guisection = _("Settings");
/* define the different flags */
frad = G_define_flag();
frad->key = 'r';
frad->description = _("Output at-sensor radiance for all bands");
msss = G_define_flag();
msss->key = 's';
- msss->description = _("Set sensor of Landsat-4/5 to MSS");
+ msss->description = _("Set sensor of Landsat TM4/5 to MSS");
+ msss->guisection = _("Settings");
l5_mtl = G_define_flag();
l5_mtl->key = 't';
- l5_mtl->description = _("Landsat 5TM has a .MTL file instead of .met");
+ l5_mtl->description = _("Landsat TM5 has a .mtl file instead of .met");
+ l5_mtl->guisection = _("Settings");
verbo = G_define_flag();
verbo->key = 'v';
@@ -217,14 +222,9 @@
sat_zenith = atof(satz->answer);
rayleigh = atof(atmo->answer);
- if (sensor->answer)
- sensor_id = atoi(sensor->answer);
- else
- G_fatal_error(_("Must select type of satellite"));
/* Data from MET file: only Landsat-7 ETM+ and Landsat-5 TM */
if (met != NULL) {
- if (sensor_id == 7)
+ if (strcmp(sensor->answer, "tm7") == 0)
met_ETM(met, &lsat);
else if (l5_mtl->answer)
mtl_TM5(met, &lsat);
@@ -246,7 +246,7 @@
G_fatal_error(_("Lacking date or solar elevation for this satellite"));
else {
- if (sensor_id == 7) { /* Need gain */
+ if (strcmp(sensor->answer, "tm7") == 0) { /* Need gain */
if (bgain->answer != NULL && strlen(bgain->answer) == 9) {
set_ETM(&lsat, bgain->answer);
G_message("Landsat 7 ETM+");
@@ -256,29 +256,29 @@
else { /* Not need gain */
- if (sensor_id == 5) {
+ if (strcmp(sensor->answer, "tm5") == 0) {
if (msss->answer)
set_MSS5(&lsat);
else
set_TM5(&lsat);
G_message("Landsat-5 %s", lsat.sensor);
- else if (sensor_id == 4) {
+ else if (strcmp(sensor->answer, "tm4") == 0) {
if (msss->answer)
set_MSS4(&lsat);
else
set_TM4(&lsat);
G_message("Landsat-4 %s", lsat.sensor);
- else if (sensor_id == 3) {
+ else if (strcmp(sensor->answer, "mss3") == 0) {
set_MSS3(&lsat);
G_message("Landsat-3 MSS");
- else if (sensor_id == 2) {
+ else if (strcmp(sensor->answer, "mss2") == 0) {
set_MSS2(&lsat);
G_message("Landsat-2 MSS");
- else if (sensor_id == 1) {
+ else if (strcmp(sensor->answer, "mss1") == 0) {
set_MSS1(&lsat);
G_message("Landsat-1 MSS");
@@ -360,7 +360,7 @@
/* DN of dark object */
for (j = lsat.band[i].qcalmin; j < 256; j++) {
- if (hist[j] >= pixel) {
+ if (hist[j] >= (unsigned int) pixel) {
dn_dark[i] = j;
break;
@@ -456,7 +456,7 @@
if ((infd = Rast_open_old(band_in, "")) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), band_in);
in_data_type = Rast_get_map_type(infd);
- Rast_get_cellhd(band_in, mapset, &cellhd);
+ Rast_get_cellhd(band_in, "", &cellhd);
/* set same size as original band raster */
G_set_window(&cellhd);
@@ -481,8 +481,7 @@
thermal) ? _("temperature") : _("reflectance")),
band_in, band_out);
for (row = 0; row < nrows; row++) {
- if (verbose)
- G_percent(row, nrows, 2);
+ G_percent(row, nrows, 2);
Rast_get_row(infd, inrast, row, in_data_type);
for (col = 0; col < ncols; col++) {
@@ -524,6 +523,8 @@
Rast_put_row(outfd, outrast, DCELL_TYPE);
+ G_percent(1, 1, 1);
ref_mode = 0.;
if (method > DOS && !lsat.band[i].thermal) {
ref_mode = lsat_qcal2rad(dn_mode[i], &lsat.band[i]);
