[GRASS-SVN] r44004 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Sun Oct 24 03:31:28 EDT 2010
Author: martinl
Date: 2010-10-24 00:31:28 -0700 (Sun, 24 Oct 2010)
New Revision: 44004
grass/branches/releasebranch_6_4/lib/python/core.py
pythonlib: doxygen updates for list_*() - list elements only for
mapsets in search path
(merge r44003 from trunk)
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2010-10-24 07:30:23 UTC (rev 44003)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2010-10-24 07:31:28 UTC (rev 44004)
@@ -572,15 +572,20 @@
# interface to g.list
def list_grouped(type):
- """!Returns the output from running g.list, as a dictionary where the keys
- are mapset names and the values are lists of maps in that mapset. Example:
+ """!List elements grouped by mapsets.
- \code
+ Returns the output from running g.list, as a dictionary where the
+ keys are mapset names and the values are lists of maps in that
+ mapset. Example:
+ @code
>>> grass.list_grouped('rast')['PERMANENT']
['aspect', 'erosion1', 'quads', 'soils', 'strm.dist', ...
- \endcode
+ @endcode
- @param type element type
+ @param type element type (rast, vect, rast3d, region, ...)
+ @return directory of mapsets/elements
dashes_re = re.compile("^----+$")
mapset_re = re.compile("<(.*)>")
@@ -598,20 +603,30 @@
continue
if mapset:
result[mapset].extend(line.split())
return result
-def mlist_grouped(type, mapset = None, pattern = None):
- """!Returns the output from running g.mlist, as a dictionary where the keys
+def mlist_grouped(type, pattern = None):
+ """!List of elements grouped by mapsets.
- @param mapset mapset name (default all mapset in search path)
+ Returns the output from running g.mlist, as a dictionary where the
+ mapset. Example:
+ @code
+ >>> grass.mlist_grouped('rast', pattern='r*')['PERMANENT']
+ ['railroads', 'roads', 'rstrct.areas', 'rushmore']
+ @endcode
@param pattern pattern string
result = {}
mapset_element = None
for line in read_command("g.mlist", flags="m",
- type = type, mapset = mapset, pattern = pattern).splitlines():
+ type = type, pattern = pattern).splitlines():
try:
map, mapset_element = line.split('@')
except ValueError:
@@ -632,29 +647,33 @@
return result
def list_pairs(type):
- """!Returns the output from running g.list, as a list of (map, mapset)
+ """!List of elements as tuples.
+ Returns the output from running g.list, as a list of (map, mapset)
pairs. Example:
- \code
+ @code
>>> grass.list_pairs('rast')
[('aspect', 'PERMANENT'), ('erosion1', 'PERMANENT'), ('quads', 'PERMANENT'), ...
- \endcode
+ @endcode
@return list of tuples (map, mapset)
return _concat([[(map, mapset) for map in maps]
for mapset, maps in list_grouped(type).iteritems()])
def list_strings(type):
- """!Returns the output from running g.list, as a list of qualified
+ """!List of elements as strings.
+ Returns the output from running g.list, as a list of qualified
names. Example:
- \code
+ @code
>>> grass.list_strings('rast')
['aspect at PERMANENT', 'erosion1 at PERMANENT', 'quads at PERMANENT', 'soils at PERMANENT', ...
- \endcode
+ @endcode
