[GRASS-SVN] r44009 - grass/trunk/general/g.mapsets
svn_grass at osgeo.org
Sun Oct 24 04:00:08 EDT 2010
Author: martinl
Date: 2010-10-24 01:00:08 -0700 (Sun, 24 Oct 2010)
New Revision: 44009
grass/trunk/general/g.mapsets/main.c
g.mapsets: more guisections
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c 2010-10-24 07:46:53 UTC (rev 44008)
+++ grass/trunk/general/g.mapsets/main.c 2010-10-24 08:00:08 UTC (rev 44009)
@@ -69,14 +69,16 @@
opt.mapset->required = NO;
opt.mapset->multiple = YES;
opt.mapset->description = _("Name(s) of existing mapset(s)");
+ opt.mapset->guisection = _("Search path");
opt.add = G_define_option();
opt.add->key = "addmapset";
opt.add->type = TYPE_STRING;
opt.add->required = NO;
opt.add->multiple = YES;
opt.add->description =
- _("Name(s) of existing mapset(s) to add to search list");
+ _("Name(s) of existing mapset(s) to add to search path");
+ opt.add->guisection = _("Search path");
opt.remove = G_define_option();
opt.remove->key = "removemapset";
@@ -84,18 +86,21 @@
opt.remove->required = NO;
opt.remove->multiple = YES;
opt.remove->description =
- _("Name(s) of existing mapset(s) to remove from search list");
+ _("Name(s) of existing mapset(s) to remove from search path");
+ opt.remove->guisection = _("Search path");
opt.fs = G_define_standard_option(G_OPT_F_SEP);
opt.fs->answer = "space";
opt.list = G_define_flag();
opt.list->key = 'l';
opt.list->description = _("List all available mapsets");
+ opt.list->guisection = _("Print");
opt.print = G_define_flag();
opt.print->key = 'p';
opt.print->description = _("Print current mapset search path");
+ opt.print->guisection = _("Print");
opt.dialog = G_define_flag();
opt.dialog->key = 's';
