[GRASS-SVN] r44012 - grass/trunk/general/g.mapset
svn_grass at osgeo.org
Sun Oct 24 04:19:40 EDT 2010
Author: martinl
Date: 2010-10-24 01:19:40 -0700 (Sun, 24 Oct 2010)
New Revision: 44012
grass/trunk/general/g.mapset/main.c
g.mapset: be less verbose when quiet flag is used
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c 2010-10-24 08:04:44 UTC (rev 44011)
+++ grass/trunk/general/g.mapset/main.c 2010-10-24 08:19:40 UTC (rev 44012)
@@ -44,8 +44,8 @@
module = G_define_module();
G_add_keyword(_("general"));
G_add_keyword(_("settings"));
- module->label = _("Change current mapset.");
- module->description = _("Optionally create new mapset or list available mapsets.");
+ module->label = _("Changes current mapset.");
+ module->description = _("Optionally create new mapset or list available mapsets in given location.");
mapset_opt = G_define_option();
mapset_opt->key = "mapset";
@@ -178,7 +178,7 @@
/* Clean temporary directory */
sprintf(path, "%s/etc/clean_temp", G_gisbase());
- G_message(_("Cleaning up temporary files..."));
+ G_verbose_message(_("Cleaning up temporary files..."));
G_spawn(path, "clean_temp", NULL);
/* Reset variables */
@@ -192,20 +192,23 @@
G_free(mapset_old_path);
- G_warning(_("Your shell continues to use the history for the old mapset"));
+ G_important_message(_("Your shell continues to use the history for the old mapset"));
if ((shell = getenv("SHELL"))) {
if (strstr(shell, "bash")) {
- G_message(_("You can switch the history by commands:\n"
- "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"),
- mapset_new_path, mapset_new_path);
+ G_important_message(_("You can switch the history by commands:\n"
+ "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"),
+ mapset_new_path, mapset_new_path);
else if (strstr(shell, "tcsh")) {
- "history -S; history -L %s/.history; setenv histfile=%s/.history"),
+ "history -S; history -L %s/.history; setenv histfile=%s/.history"),
+ G_message(_("Your current mapset is <%s>"), mapset_new);
G_free(mapset_new_path);
return (EXIT_SUCCESS);
