[GRASS-SVN] r44017 -
grass/branches/releasebranch_6_4/raster/r.timestamp
svn_grass at osgeo.org
Sun Oct 24 05:19:19 EDT 2010
Author: martinl
Date: 2010-10-24 02:19:19 -0700 (Sun, 24 Oct 2010)
New Revision: 44017
grass/branches/releasebranch_6_4/raster/r.timestamp/description.html
grass/branches/releasebranch_6_4/raster/r.timestamp/main.c
r.timestamp: clean up the manual page
(merge r44015 from trunk)
Modified: grass/branches/releasebranch_6_4/raster/r.timestamp/description.html
--- grass/branches/releasebranch_6_4/raster/r.timestamp/description.html 2010-10-24 09:18:31 UTC (rev 44016)
+++ grass/branches/releasebranch_6_4/raster/r.timestamp/description.html 2010-10-24 09:19:19 UTC (rev 44017)
@@ -1,109 +1,136 @@
<h2>DESCRIPTION</h2>
-This command has 2 modes of operation. If no date argument is supplied, then
-the current timestamp for the raster map is printed. If a date argument is
-specified, then the timestamp for the raster map is set to the specified
-date(s). See EXAMPLES below.
+This command has 2 modes of operation. If no <b>date</b> argument is
+supplied, then the current timestamp for the raster map is printed. If
+a date argument is specified, then the timestamp for the raster map is
+set to the specified date(s). See examples below.
<h2>NOTES</h2>
-Strings containing spaces should be quoted. For specifying a range
-of time, the two timestamps should be separated by a forward slash.
-To remove the timestamp from a raster map, use <b>date=</b><em>none</em>.
+Strings containing spaces should be quoted. For specifying a range of
+time, the two timestamps should be separated by a forward slash. To
+remove the timestamp from a raster map, use <b>date=none</b>.
-<h2>EXAMPLES</h2>
+<h2>TIMESTAMP FORMAT</h2>
- <b>r.timestamp map=soils</b><br>
- Prints the timestamp for the "soils" raster map. If
- there is no timestamp for soils, nothing is printed. If
- there is a timestamp, one or two time strings are printed,
- depending on if the timestamp for the map consists of a
- single date or two dates (ie start and end dates).
+The timestamp values must use the format as described in the <em>GRASS
+Datetime Library</em>. The source tree for this library should have a
+description of the format. For convience, the formats are reproduced
+here:
<p>
-<b> r.timestamp map=soils date='15 sep 1987'</b><br>
- Sets the timestamp for "soils" to the single date<br>
- "15 sep 1987"
-<p>
-<b> r.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
- Sets the timestamp for "soils" to have the start date<br>
- "15 sep 1987" and the end date "20 feb 1988"
-<p>
-<b> r.timestamp map=soils date=none</b><br>
- Removes the timestamp for the "soils" raster map
+There are two types of datetime values:
+<ul>
+ <li><em>absolute</em> and
+ <li><em>relative</em>.
+</ul>
-<h2>TIMESTAMP FORMAT</h2>
- The timestamp values must use the format as described in the
- GRASS datetime library. The source tree for this library
- should have a description of the format. For convience, the
- formats as of Feb, 1996 are reproduced here:
-<p>
- There are two types of datetime values: absolute and
- relative. Absolute values specify exact dates and/or times.
- Relative values specify a span of time. Some examples will
- help clarify:
-<p>
-<b>Absolute</b><p>
- The general format for absolute values is:
-<p><tt>
- day month year [bc] hour:minute:seconds timezone
-<p>
- day is 1-31<br>
- month is jan,feb,...,dec<br>
- year is 4 digit year<br>
- [bc] if present, indicates dates is BC<br>
- hour is 0-23 (24 hour clock)<br>
- mintue is 0-59<br>
- second is 0-59.9999 (fractions of second allowed)<br>
- timezone is +hhmm or -hhmm (eg, -0600)<br>
-<p>
- parts can be missing
-<p>
- 1994 [bc]<br>
- Jan 1994 [bc]<br>
- 15 jan 1000 [bc]<br>
- 15 jan 1994 [bc] 10 [+0000]<br>
- 15 jan 1994 [bc] 10:00 [+0100]<br>
- 15 jan 1994 [bc] 10:00:23.34 [-0500]<br>
-<p>
-</tt>
-<b>Relative</b><p>
- There are two types of relative datetime values, year-
- month and day-second. The formats are:
-<p><tt>
- [-] # years # months<br>
+Absolute values specify exact dates and/or times. Relative values
+specify a span of time.
+<h3>Absolute</h3>
+The general format for absolute values is:
+<div class="code"><pre>
+ day month year [bc] hour:minute:seconds timezone
+ day is 1-31
+ month is jan,feb,...,dec
+ year is 4 digit year
+ [bc] if present, indicates dates is BC
+ hour is 0-23 (24 hour clock)
+ mintue is 0-59
+ second is 0-59.9999 (fractions of second allowed)
+ timezone is +hhmm or -hhmm (eg, -0600)
+</pre></div>
+Some parts can be missing, for example
+ 1994 [bc]
+ Jan 1994 [bc]
+ 15 jan 1000 [bc]
+ 15 jan 1994 [bc] 10 [+0000]
+ 15 jan 1994 [bc] 10:00 [+0100]
+ 15 jan 1994 [bc] 10:00:23.34 [-0500]
+</pre></div>
+<h3>Relative</h3>
+There are two types of relative datetime values, year-month and
+day-second. The formats are:
+ [-] # years # months
[-] # days # hours # minutes # seconds
-</tt><p>
- The words years, months, days, hours, minutes, seconds
- are literal words, and the # are the numeric values.<br>
- Examples:<p>
-<tt>
- 2 years<br>
- 5 months<br>
- 2 years 5 months<br>
- 100 days<br>
- 15 hours 25 minutes 35.34 seconds<br>
- 100 days 25 minutes<br>
+</pre></div>
+The words years, months, days, hours, minutes, seconds are literal
+words, and the # are the numeric values. Examples:
+ 2 years
+ 5 months
+ 2 years 5 months
+ 100 days
+ 15 hours 25 minutes 35.34 seconds
+ 100 days 25 minutes
1000 hours 35.34 seconds
-</tt><p>
- The following are <i>illegal</i> because it mixes year-month
- and day-second (because the number of days in a month
- or in a year vary):<p>
-<tt>
- 3 months 15 days<br>
+</pre></div>
+The following are <i>illegal</i> because it mixes year-month and
+day-second (because the number of days in a month or in a year vary):
+ 3 months 15 days
3 years 10 days
-</tt>
+</pre></div>
-<h2>SEE ALSO</h2>
+<h2>EXAMPLES</h2>
-<em><a HREF="v.timestamp.html">v.timestamp</a></em>
+Prints the timestamp for the "soils" raster map. If there is no
+timestamp for "soils", nothing is printed. If there is a timestamp,
+one or two time strings are printed, depending on if the timestamp for
+the map consists of a single date or two dates (ie start and end
+dates).
+ r.timestamp map=soils
+</pre></div>
+Sets the timestamp for "soils" to the single date "15 sep 1987".
+ r.timestamp map=soils date='15 sep 1987'
+</pre></div>
+Sets the timestamp for "soils" to have the start date "15 sep 1987"
+and the end date "20 feb 1988".
+ r.timestamp map=soils date='15 sep 1987/20 feb 1988'
+</pre></div>
+Removes the timestamp for the "soils" raster map.
+ r.timestamp map=soils date=none
+</pre></div>
<h2>BUGS</h2>
Spaces in the timestamp value are required.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="r.info.html">r.info</a>
+</em>
<h2>AUTHOR</h2>
-Michael Shapiro, <br>
-U.S.Army Construction Engineering Research Laboratory
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/raster/r.timestamp/main.c
--- grass/branches/releasebranch_6_4/raster/r.timestamp/main.c 2010-10-24 09:18:31 UTC (rev 44016)
+++ grass/branches/releasebranch_6_4/raster/r.timestamp/main.c 2010-10-24 09:19:19 UTC (rev 44017)
@@ -7,7 +7,7 @@
* Glynn Clements <glynn gclements.plus.com>,
* Hamish Bowman <hamish_nospam yahoo.com>, Jan-Oliver Wagner <jan intevation.de>
* PURPOSE:
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -32,7 +32,8 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, metadata, timestamp");
+ module->label = _("Modifies a timestamp for a raster map.");
module->description = _("Print/add/remove a timestamp for a raster map.");
map = G_define_standard_option(G_OPT_R_MAP);
@@ -42,8 +43,9 @@
date->key_desc = "timestamp";
date->required = NO;
date->type = TYPE_STRING;
- date->description = _("Datetime, datetime1/datetime2, or none");
+ date->label = _("Datetime, datetime1/datetime2, or 'none' to remove");
+ date->description = _("Format: '15 jan 1994' (absolute) or '2 years' (relative)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
