[GRASS-SVN] r44027 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Oct 24 07:56:41 EDT 2010
Author: martinl
Date: 2010-10-24 04:56:41 -0700 (Sun, 24 Oct 2010)
New Revision: 44027
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI: fix zooming to RBG layers
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-10-24 10:46:27 UTC (rev 44026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-10-24 11:56:41 UTC (rev 44027)
@@ -443,7 +443,10 @@
vect.append(mapLayer.GetName())
elif mltype == '3d-raster':
rast3d.append(mapLayer.GetName())
+ elif mltype == 'rgb':
+ for rname in mapLayer.GetName().splitlines():
+ rast.append(rname)
cmd = ['g.region']
if rast:
cmd.append('rast=%s' % ','.join(rast))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-10-24 10:46:27 UTC (rev 44026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-10-24 11:56:41 UTC (rev 44027)
@@ -1870,9 +1870,8 @@
self.propwin[type] = propwin
def OnZoomToMap(self, event):
- Set display extents to match selected raster (including NULLs)
- or vector map.
+ """!Set display extents to match selected raster (including
+ NULLs) or vector map.
self.MapWindow.ZoomToMap()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-10-24 10:46:27 UTC (rev 44026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-10-24 11:56:41 UTC (rev 44027)
@@ -914,8 +914,7 @@
return True
def DrawCompRegionExtent(self):
- Draw computational region extent in the display
+ """!Draw computational region extent in the display
Display region is drawn as a blue box inside the computational region,
computational region inside a display region as a red box).
@@ -2735,12 +2734,12 @@
or vector map(s).
- @param layer list of layers to be zoom to
- @param ignoreNulls True to ignore null-values
+ @param layers list of layers to be zoom to
+ @param ignoreNulls True to ignore null-values (valid only for rasters)
@param render True to re-render display
zoomreg = {}
if not layers:
layers = self.GetSelectedLayer(multi = True)
@@ -2763,7 +2762,10 @@
updated = True
else:
vect.append(l.name)
+ elif l.type == 'rgb':
+ for rname in l.GetName().splitlines():
if not updated:
self.Map.GetRegion(rast = rast,
vect = vect,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-10-24 10:46:27 UTC (rev 44026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-10-24 11:56:41 UTC (rev 44027)
@@ -251,7 +251,7 @@
return int (self.opacity * 100)
- def GetName(self, fullyQualified=True):
+ def GetName(self, fullyQualified = True):
"""!Get map layer name
@param fullyQualified if True return 'name at mapset' otherwise
