[GRASS-SVN] r44040 - in grass/trunk: . include/Make
svn_grass at osgeo.org
Mon Oct 25 17:36:34 EDT 2010
Author: martinl
Date: 2010-10-25 14:36:34 -0700 (Mon, 25 Oct 2010)
New Revision: 44040
grass/trunk/Makefile
grass/trunk/include/Make/Docs.make
grass/trunk/include/Make/Doxyfile_arch_html.in
grass/trunk/include/Make/Doxyfile_arch_latex.in
grass/trunk/include/Make/Doxygen.make
attempt to recover programmers manual
Modified: grass/trunk/Makefile
--- grass/trunk/Makefile 2010-10-25 21:34:01 UTC (rev 44039)
+++ grass/trunk/Makefile 2010-10-25 21:36:34 UTC (rev 44040)
@@ -122,10 +122,11 @@
-rm -f include/config.h include/version.h
-rm -f include/Make/Platform.make include/Make/Doxyfile_arch_html include/Make/Doxyfile_arch_latex 2>/dev/null
-DOXNAME=grass
include $(MODULE_TOPDIR)/include/Make/Install.make
include $(MODULE_TOPDIR)/include/Make/Docs.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+DOXNAME=grass
.PHONY: default libs
.PHONY: cleandistdirs cleanscriptstrings clean libsclean distclean
Modified: grass/trunk/include/Make/Docs.make
--- grass/trunk/include/Make/Docs.make 2010-10-25 21:34:01 UTC (rev 44039)
+++ grass/trunk/include/Make/Docs.make 2010-10-25 21:36:34 UTC (rev 44040)
@@ -8,13 +8,12 @@
# generate programmer's manual as single HTML document:
htmldocs-single:
+ $(MAKE) -C . htmldox-single
for dir in lib rfc gui/wxpython ; do \
- $(MAKE) -C $$dir htmldocs-single ; \
+ $(MAKE) -C $$dir htmldox-single ; \
done
# generate programmer's manual as multiple HTML documents:
-htmldocs:
docs_dirs = \
lib/db \
lib/g3d \
@@ -34,25 +33,26 @@
latexdocs_dirs := $(patsubst %,%/latex,$(docs_dirs))
htmldocs:
for dir in $(docs_dirs) ; do \
- $(MAKE) -C $$dir htmldocs ; \
+ $(MAKE) -C $$dir htmldox ; \
done
packagehtmldocs: htmldocs
tar chvfz $(GRASS_NAME)refman_$(DATE)_html.tar.gz $(htmldocs_dirs)
#alternatively, the docs can be generated as single PDF document (see doxygen FAQ for 'TeX capacity exceeded'):
-# (cd lib/ ; make pdfdocs)
+# (cd lib/ ; make pdfdox)
pdfdocs:
- $(MAKE) -C $$dir pdfdocs ; \
+ $(MAKE) -C $$dir pdfdox ; \
done
@echo "Written PDF docs in: $(latexdocs_dirs)"
cleandocs:
- $(MAKE) -C $$dir cleandocs ; \
+ $(MAKE) -C $$dir cleandox ; \
done
indices = \
Modified: grass/trunk/include/Make/Doxyfile_arch_html.in
--- grass/trunk/include/Make/Doxyfile_arch_html.in 2010-10-25 21:34:01 UTC (rev 44039)
+++ grass/trunk/include/Make/Doxyfile_arch_html.in 2010-10-25 21:36:34 UTC (rev 44040)
@@ -448,17 +448,18 @@
# excluded from the INPUT source files. This way you can easily exclude a
# subdirectory from a directory tree whose root is specified with the INPUT tag.
-EXCLUDE = bin.* \
+EXCLUDE = bin. at ARCH@ \
db \
debian \
demolocation \
display \
- dist.* \
+ dist. at ARCH@ \
doc \
general \
gui/wxpython/vdigit \
gui/wxpython/nviz \
imagery \
+ include \
lib/python/ctypes \
locale \
macosx \
Modified: grass/trunk/include/Make/Doxyfile_arch_latex.in
--- grass/trunk/include/Make/Doxyfile_arch_latex.in 2010-10-25 21:34:01 UTC (rev 44039)
+++ grass/trunk/include/Make/Doxyfile_arch_latex.in 2010-10-25 21:36:34 UTC (rev 44040)
-EXCLUDE = bin.* \
db \
debian \
demolocation \
display \
- dist.* \
+ dist. at ARCH@ \
doc \
general \
gui/wxpython/nviz \
imagery \
+ include \
lib/python/ctypes \
locale \
macosx \
Modified: grass/trunk/include/Make/Doxygen.make
--- grass/trunk/include/Make/Doxygen.make 2010-10-25 21:34:01 UTC (rev 44039)
+++ grass/trunk/include/Make/Doxygen.make 2010-10-25 21:36:34 UTC (rev 44040)
@@ -8,12 +8,12 @@
@(type doxygen > /dev/null || (echo "ERROR: Install 'doxygen' software first (get from http://www.doxygen.org)" && exit 1))
# generate docs as single HTML document:
-htmldocs-single: checkdoxygen cleandocs
+htmldox-single: checkdoxygen cleandox
doxygen $(MODULE_TOPDIR)/include/Make/Doxyfile_arch_html
@echo "HTML reference in directory ./html/index.html"
# generate docs as multiple HTML documents:
-htmldocs: checkdoxygen cleandocs
+htmldox: checkdoxygen cleandox
# hack needed to get main page at beginning:
@mv $(DOXINPUT) $(DOXINPUT).org
@sed 's+/\*! \\page +/\*! \\mainpage +g' $(DOXINPUT).org > $(DOXINPUT)
@@ -22,7 +22,7 @@
# NOTE: stubs/ and sqlp/ are excluded in ./Doxyfile_arch_latex
-latexdocs: checkdoxygen cleandocs
+latexdox: checkdoxygen cleandox
test ! -d latex || (cd ./latex && $(MAKE) clean)
@@ -34,7 +34,7 @@
@mv $(DOXINPUT).org $(DOXINPUT)
@echo "Latex reference in directory ./latex/refman.dvi"
-pdfdocs: checkdoxygen cleandocs
+pdfdox: checkdoxygen cleandox
@@ -46,5 +46,5 @@
@echo "PDF reference in directory ./latex/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}$(DOXOUTPUT)_`date '+%Y_%m_%d'`_refman.pdf"
-cleandocs:
+cleandox:
rm -rf ./latex ./html
