[GRASS-SVN] r44048 - in grass/trunk: gui/wxpython/xml imagery/i.landsat.toar
Mon Oct 25 19:29:15 EDT 2010
Author: martinl
Date: 2010-10-25 16:29:15 -0700 (Mon, 25 Oct 2010)
New Revision: 44048
   grass/trunk/gui/wxpython/xml/menudata.xml
   grass/trunk/imagery/i.landsat.toar/main.c
i.landsat.acca added to wxGUI menu
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2010-10-25 23:14:20 UTC (rev 44047)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2010-10-25 23:29:15 UTC (rev 44048)
@@ -720,7 +720,7 @@
 	    <separator />
 	    <menuitem>
 	      <label>Change working environment</label>
-	      <help>Change current mapset.</help>
+	      <help>Changes current mapset.</help>
 	      <keywords>general,settings</keywords>
               <handler>OnMenuCmd</handler>
 	      <command>g.mapset</command>
@@ -845,8 +845,8 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Timestamp</label>
-	      <help>Print/add/remove a timestamp for a raster map.</help>
-	      <keywords>raster</keywords>
+	      <help>Modifies a timestamp for a raster map.</help>
+	      <keywords>raster,metadata,timestamp</keywords>
 	      <command>r.timestamp</command>
 	    </menuitem>
@@ -2643,6 +2643,13 @@
 	      <command>i.landsat.toar</command>
 	    </menuitem>
 	    <menuitem>
+	      <label>Landsat cloud cover assessment</label>
+	      <help>Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).</help>
+	      <keywords>imagery,landsat,acca</keywords>
+	      <handler>OnMenuCmd</handler>
+	      <command>i.landsat.acca</command>
+	    </menuitem>
+	    <menuitem>
 	      <label>Modis quality control</label>
 	      <help>Extract quality control parameters from Modis QC layers</help>
 	      <keywords>QC,Quality Control,surface reflectance,Modis</keywords>
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c	2010-10-25 23:14:20 UTC (rev 44047)
+++ grass/trunk/imagery/i.landsat.toar/main.c	2010-10-25 23:29:15 UTC (rev 44048)
@@ -6,6 +6,7 @@
  * AUTHOR(S):    E. Jorge Tizado - ej.tizado at unileon.es
  *		 Hamish Bowman (small grassification cleanups)
  *               Yann Chemin (v7 + L5TM _MTL.txt support)
+ *               Adopted for GRASS 7 by Martin Landa <landa.martin gmail.com>
  * PURPOSE:      Calculate TOA Radiance or Reflectance and Kinetic Temperature
  *               for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
