[GRASS-SVN] r44054 - grass/branches/develbranch_6/mswindows
svn_grass at osgeo.org
Wed Oct 27 17:25:24 EDT 2010
Author: hellik
Date: 2010-10-27 14:25:24 -0700 (Wed, 27 Oct 2010)
New Revision: 44054
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
use correct set GDAL_DATA and GEOTIFF_CSV variables and include required files #1201
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-10-27 21:23:30 UTC (rev 44053)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-10-27 21:25:24 UTC (rev 44054)
@@ -671,11 +671,14 @@
FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
FileWrite $0 '$\r$\n'
FileWrite $0 'rem Set GDAL_DATA$\r$\n'
- FileWrite $0 'set GDAL_DATA=%GRASSDIR%\etc\ogr_csv$\r$\n'
+ FileWrite $0 'set GDAL_DATA=%GRASSDIR%\share\gdal$\r$\n'
FileWrite $0 'rem Set PROJ_LIB$\r$\n'
FileWrite $0 'set PROJ_LIB=%GRASSDIR%\proj$\r$\n'
+ FileWrite $0 'rem Set GEOTIFF_CSV$\r$\n'
+ FileWrite $0 'set GEOTIFF_CSV=%GRASSDIR%\share\epsg_csv$\r$\n'
+ FileWrite $0 '$\r$\n'
FileWrite $0 'rem Path to the python directory$\r$\n'
FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
FileWrite $0 'if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python$\r$\n'
@@ -792,11 +795,14 @@
FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
- FileWrite $0 'GDAL_DATA="$INSTALL_DIR\etc\ogr_csv"$\r$\n'
+ FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
FileWrite $0 'export GDAL_DATA$\r$\n'
FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
FileWrite $0 'export PROJ_LIB $\r$\n'
+ FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
+ FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
+ FileWrite $0 'export GEOTIFF_CSV $\r$\n'
FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
FileClose $0
@@ -961,11 +967,12 @@
RMDir /r "$INSTDIR\locale"
RMDir /r "$INSTDIR\msys"
RMDir /r "$INSTDIR\proj"
+ RMDir /r "$INSTDIR\share"
RMDir /r "$INSTDIR\Python25"
RMDir /r "$INSTDIR\scripts"
RMDir /r "$INSTDIR\sqlite"
RMDir /r "$INSTDIR\tcl-tk"
- RMDir /r "$INSTDIR\tools"
+ RMDir /r "$INSTDIR\tools"
;if empty, remove the install folder
RMDir "$INSTDIR"
Modified: grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
--- grass/branches/develbranch_6/mswindows/GRASS-Packager.bat 2010-10-27 21:23:30 UTC (rev 44053)
+++ grass/branches/develbranch_6/mswindows/GRASS-Packager.bat 2010-10-27 21:25:24 UTC (rev 44054)
@@ -106,6 +106,25 @@
@echo.
@echo -----------------------------------------------------------------------------------------------------------------------
+ at echo Copy shared GDAL files to PACKAGE_DIR\share\gdal
+ at echo -----------------------------------------------------------------------------------------------------------------------
+ at echo.
+mkdir %PACKAGE_DIR%\share
+mkdir %PACKAGE_DIR%\share\gdal
+xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
+ at echo.
+ at echo Copy shared GEOTIFF files to PACKAGE_DIR\share\epsg_csv
+ at echo.
+mkdir %PACKAGE_DIR%\share\epsg_csv
+xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
+ at echo.
@echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
@echo.
