[GRASS-SVN] r44060 - grass/trunk/raster/r.resamp.interp
svn_grass at osgeo.org
Thu Oct 28 02:42:20 EDT 2010
Author: mmetz
Date: 2010-10-27 23:42:20 -0700 (Wed, 27 Oct 2010)
New Revision: 44060
grass/trunk/raster/r.resamp.interp/main.c
grass/trunk/raster/r.resamp.interp/r.resamp.interp.html
add lanczos
Modified: grass/trunk/raster/r.resamp.interp/main.c
--- grass/trunk/raster/r.resamp.interp/main.c 2010-10-28 06:37:15 UTC (rev 44059)
+++ grass/trunk/raster/r.resamp.interp/main.c 2010-10-28 06:42:20 UTC (rev 44060)
@@ -4,7 +4,8 @@
* MODULE: r.resamp.interp
* AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor),
* Paul Kelly <paul-grass stjohnspoint.co.uk>,
- * Dylan Beaudette, Hamish Bowman <hamish_b yahoo.com>
+ * Dylan Beaudette, Hamish Bowman <hamish_b yahoo.com>,
+ * Markus Metz (lanczos)
* PURPOSE:
* COPYRIGHT: (C) 2006-2007 by the GRASS Development Team
@@ -13,6 +14,9 @@
* for details.
+/* TODO: add fallback methods, see e.g. r.proj */
#include <stdlib.h>
#include <string.h>
#include <math.h>
@@ -21,7 +25,7 @@
#include <grass/glocale.h>
static int neighbors;
-static DCELL *bufs[4];
+static DCELL *bufs[5];
static int cur_row;
static void read_rows(int infile, int row)
@@ -82,7 +86,7 @@
method->type = TYPE_STRING;
method->required = NO;
method->description = _("Interpolation method");
- method->options = "nearest,bilinear,bicubic";
+ method->options = "nearest,bilinear,bicubic,lanczos";
method->answer = "bilinear";
if (G_parser(argc, argv))
@@ -94,6 +98,8 @@
neighbors = 2;
else if (G_strcasecmp(method->answer, "bicubic") == 0)
neighbors = 4;
+ else if (G_strcasecmp(method->answer, "lanczos") == 0)
+ neighbors = 5;
else
G_fatal_error(_("Invalid method: %s"), method->answer);
@@ -106,11 +112,11 @@
double north = Rast_row_to_northing(0.5, &dst_w);
double south = Rast_row_to_northing(dst_w.rows - 0.5, &dst_w);
- int r0 = (int)floor(Rast_northing_to_row(north, &src_w) - 0.5) - 1;
+ int r0 = (int)floor(Rast_northing_to_row(north, &src_w) - 0.5) - 2;
int r1 = (int)floor(Rast_northing_to_row(south, &src_w) - 0.5) + 3;
double west = Rast_col_to_easting(0.5, &dst_w);
double east = Rast_col_to_easting(dst_w.cols - 0.5, &dst_w);
- int c0 = (int)floor(Rast_easting_to_col(west, &src_w) - 0.5) - 1;
+ int c0 = (int)floor(Rast_easting_to_col(west, &src_w) - 0.5) - 2;
int c1 = (int)floor(Rast_easting_to_col(east, &src_w) - 0.5) + 3;
src_w.south -= src_w.ns_res * (r1 - src_w.rows);
@@ -277,6 +283,76 @@
Rast_put_d_row(outfile, outbuf);
break;
+ case 5: /* lanczos */
+ for (row = 0; row < dst_w.rows; row++) {
+ double north = Rast_row_to_northing(row + 0.5, &dst_w);
+ double maprow_f = Rast_northing_to_row(north, &src_w) - 0.5;
+ int maprow1 = (int)floor(maprow_f + 0.5);
+ int maprow0 = maprow1 - 2;
+ double v = maprow_f - maprow1;
+ G_percent(row, dst_w.rows, 2);
+ read_rows(infile, maprow0);
+ for (col = 0; col < dst_w.cols; col++) {
+ double east = Rast_col_to_easting(col + 0.5, &dst_w);
+ double mapcol_f = Rast_easting_to_col(east, &src_w) - 0.5;
+ int mapcol2 = (int)floor(mapcol_f + 0.5);
+ int mapcol0 = mapcol2 - 2;
+ int mapcol1 = mapcol2 - 1;
+ int mapcol3 = mapcol2 + 1;
+ int mapcol4 = mapcol2 + 2;
+ double u = mapcol_f - mapcol2;
+ double c[25];
+ int i = 0, do_lanczos = 1;
+ c[i++] = bufs[0][mapcol0];
+ c[i++] = bufs[0][mapcol1];
+ c[i++] = bufs[0][mapcol2];
+ c[i++] = bufs[0][mapcol3];
+ c[i++] = bufs[0][mapcol4];
+ c[i++] = bufs[1][mapcol0];
+ c[i++] = bufs[1][mapcol1];
+ c[i++] = bufs[1][mapcol2];
+ c[i++] = bufs[1][mapcol3];
+ c[i++] = bufs[1][mapcol4];
+ c[i++] = bufs[2][mapcol0];
+ c[i++] = bufs[2][mapcol1];
+ c[i++] = bufs[2][mapcol2];
+ c[i++] = bufs[2][mapcol3];
+ c[i++] = bufs[2][mapcol4];
+ c[i++] = bufs[3][mapcol0];
+ c[i++] = bufs[3][mapcol1];
+ c[i++] = bufs[3][mapcol2];
+ c[i++] = bufs[3][mapcol3];
+ c[i++] = bufs[3][mapcol4];
+ c[i++] = bufs[4][mapcol0];
+ c[i++] = bufs[4][mapcol1];
+ c[i++] = bufs[4][mapcol2];
+ c[i++] = bufs[4][mapcol3];
+ c[i++] = bufs[4][mapcol4];
+ for (i = 0; i < 25; i++) {
+ if (Rast_is_d_null_value(&(c[i]))) {
+ Rast_set_d_null_value(&outbuf[col], 1);
+ do_lanczos = 0;
+ if (do_lanczos) {
+ outbuf[col] = Rast_interp_lanczos(v, u, c);
+ Rast_put_d_row(outfile, outbuf);
+ break;
G_percent(dst_w.rows, dst_w.rows, 2);
Modified: grass/trunk/raster/r.resamp.interp/r.resamp.interp.html
--- grass/trunk/raster/r.resamp.interp/r.resamp.interp.html 2010-10-28 06:37:15 UTC (rev 44059)
+++ grass/trunk/raster/r.resamp.interp/r.resamp.interp.html 2010-10-28 06:42:20 UTC (rev 44060)
@@ -3,7 +3,7 @@
<em>r.resamp.interp</em> resamples an input raster map by interpolating between
the neighboring cells via a selectable resampling algorithm. All cells
present in the neighborhood of the input raster cell must be non-null to
-generate a non-null cell in the output raster map. A choice of three
+generate a non-null cell in the output raster map. A choice of four
interpolation methods is available; each uses the weighted values of a different
number of adjacent cells in the input map to determine the value of each
cell in the output map as follows:
@@ -11,6 +11,7 @@
<li>nearest neighbour (1 cell)</li>
<li>bilinear (4 cells)</li>
<li>bicubic (16 cells)</li>
+<li>lanczos (25 cells)</li>
</ul>
<p>
@@ -28,7 +29,7 @@
</p>
<p>
-Note that for bilinear and bicubic interpolation,
+Note that for bilinear, bicubic and lanczos interpolation,
cells of the output raster that cannot be bounded by the appropriate number
of input cell centers are set to NULL (NULL propagation). This could occur
due to the input cells being outside the current region, being NULL or MASKed.
