[GRASS-SVN] r44064 - grass/trunk/imagery/i.rectify
svn_grass at osgeo.org
Thu Oct 28 03:20:54 EDT 2010
Author: mmetz
Date: 2010-10-28 00:20:54 -0700 (Thu, 28 Oct 2010)
New Revision: 44064
Added:
grass/trunk/imagery/i.rectify/lanczos.c
add lanczos and lanczos fallback to i.rectify, next try
Added: grass/trunk/imagery/i.rectify/lanczos.c
--- grass/trunk/imagery/i.rectify/lanczos.c (rev 0)
+++ grass/trunk/imagery/i.rectify/lanczos.c 2010-10-28 07:20:54 UTC (rev 44064)
@@ -0,0 +1,109 @@
+ * Name
+ * lanczos.c -- use lanczos interpolation for given row, col
+ * Description
+ * lanczos returns the value in the buffer that is the result of
+ * lanczos interpolation for the given row, column indices.
+ * If the given row or column is outside the bounds of the input map,
+ * the corresponding point in the output map is set to NULL.
+ * If single surrounding points in the interpolation matrix are
+ * NULL they where filled with their neighbor
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <math.h>
+#include "global.h"
+void p_lanczos(struct cache *ibuffer, /* input buffer */
+ void *obufptr, /* ptr in output buffer */
+ int cell_type, /* raster map type of obufptr */
+ double *row_idx, /* row index (decimal) */
+ double *col_idx, /* column index (decimal) */
+ struct Cell_head *cellhd /* information of output map */
+ int row; /* row indices for interp */
+ int col; /* column indices for interp */
+ int i, j, k;
+ DCELL t, u; /* intermediate slope */
+ DCELL result; /* result of interpolation */
+ DCELL cell[25];
+ /* cut indices to integer */
+ row = (int)floor(*row_idx);
+ col = (int)floor(*col_idx);
+ /* check for out of bounds of map - if out of bounds set NULL value */
+ if (row - 2 < 0 || row + 2 >= cellhd->rows ||
+ col - 2 < 0 || col + 2 >= cellhd->cols) {
+ Rast_set_null_value(obufptr, 1, cell_type);
+ return;
+ k = 0;
+ for (i = 0; i < 5; i++) {
+ for (j = 0; j < 5; j++) {
+ const DCELL *cellp = CPTR(ibuffer, row - 2 + i, col - 2 + j);
+ if (Rast_is_d_null_value(cellp)) {
+ return;
+ cell[k++] = *cellp;
+ /* do the interpolation */
+ t = *col_idx - 0.5 - col;
+ u = *row_idx - 0.5 - row;
+ result = Rast_interp_lanczos(u, t, cell);
+ Rast_set_d_value(obufptr, result, cell_type);
+void p_lanczos_f(struct cache *ibuffer, /* input buffer */
+ DCELL *cellp, cell;
+ /* check for out of bounds - if out of bounds set NULL value */
+ if (row < 0 || row >= cellhd->rows || col < 0 || col >= cellhd->cols) {
+ return;
+ cellp = CPTR(ibuffer, row, col);
+ /* if nearest is null, all the other interps will be null */
+ return;
+ cell = *cellp;
+ p_lanczos(ibuffer, obufptr, cell_type, row_idx, col_idx, cellhd);
+ /* fallback to bicubic if lanczos is null */
+ if (Rast_is_d_null_value(obufptr)) {
+ p_cubic(ibuffer, obufptr, cell_type, row_idx, col_idx, cellhd);
+ /* fallback to bilinear if cubic is null */
+ p_bilinear(ibuffer, obufptr, cell_type, row_idx, col_idx, cellhd);
+ /* fallback to nearest if bilinear is null */
+ Rast_set_d_value(obufptr, cell, cell_type);
