[GRASS-SVN] r44068 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Oct 28 12:43:17 EDT 2010
Author: martinl
Date: 2010-10-28 09:43:17 -0700 (Thu, 28 Oct 2010)
New Revision: 44068
grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
wxGUI/mcalc: load/save expression (based on Tim Michelsen's patch #669)
Modified: grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py 2010-10-28 11:11:16 UTC (rev 44067)
+++ grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py 2010-10-28 16:43:17 UTC (rev 44068)
@@ -13,6 +13,7 @@
@author Michael Barton, Arizona State University
@author Martin Landa <landa.martin gmail.com>
+ at author Tim Michelsen (load/save expression)
import os
@@ -138,6 +139,11 @@
self.btn_cmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Command dialog"))
self.btn_cmd.SetToolTipString(_('Open %s dialog') % self.cmd)
+ self.btn_save = wx.Button(parent = self.panel, id = wx.ID_SAVE)
+ self.btn_save.SetToolTipString(_('Save expression to file'))
+ self.btn_load = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("&Load"))
+ self.btn_load.SetToolTipString(_('Load expression from file'))
self.btn = dict()
self.btn['pow'] = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "^")
@@ -237,7 +243,9 @@
self.btn_run.Bind(wx.EVT_BUTTON, self.OnMCalcRun)
self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
self.btn_cmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
+ self.btn_save.Bind(wx.EVT_BUTTON, self.OnSaveExpression)
+ self.btn_load.Bind(wx.EVT_BUTTON, self.OnLoadExpression)
self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
self.function.Bind(wx.EVT_COMBOBOX, self.OnSelect)
self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
@@ -304,11 +312,17 @@
buttonSizer4 = wx.BoxSizer(wx.HORIZONTAL)
buttonSizer4.Add(item = self.btn_cmd,
flag = wx.ALL, border = 5)
- buttonSizer4.Add(item = self.btn_close,
+ buttonSizer4.AddSpacer(10)
+ buttonSizer4.Add(item = self.btn_load,
+ buttonSizer4.Add(item = self.btn_save,
+ flag = wx.ALL, border = 5)
+ buttonSizer4.Add(item = self.btn_help,
buttonSizer4.Add(item = self.btn_run,
- buttonSizer4.Add(item = self.btn_help,
+ buttonSizer4.Add(item = self.btn_close,
operatorSizer.Add(item = buttonSizer1, proportion = 0,
@@ -459,6 +473,62 @@
if display and display.IsAutoRendered():
display.GetWindow().UpdateMap(render = True)
+ def OnSaveExpression(self, event):
+ """!Saves expression to file
+ mctxt = self.newmaptxt.GetValue() + ' = ' + self.text_mcalc.GetValue() + os.linesep
+ #dialog
+ dlg = wx.FileDialog(parent = self,
+ message = _("Choose a file name to save the expression"),
+ wildcard = _("Expression file (*)|*"),
+ style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ if dlg.ShowModal() == wx.ID_OK:
+ path = dlg.GetPath()
+ if not path:
+ dlg.Destroy()
+ return
+ try:
+ fobj = open(path, 'w')
+ fobj.write(mctxt)
+ finally:
+ fobj.close()
+ dlg.Destroy()
+ def OnLoadExpression(self, event):
+ """!Load expression from file
+ message = _("Choose a file name to load the expression"),
+ style = wx.OPEN)
+ if not path:
+ dlg.Destroy()
+ return
+ try:
+ fobj = open(path,'r')
+ mctxt = fobj.read()
+ finally:
+ fobj.close()
+ try:
+ result, exp = mctxt.split('=', 1)
+ except ValueError:
+ result = ''
+ exp = mctxt
+ self.newmaptxt.SetValue(result.strip())
+ self.text_mcalc.SetValue(exp.strip())
+ self.text_mcalc.SetFocus()
+ self.text_mcalc.SetInsertionPointEnd()
+ dlg.Destroy()
def OnClear(self, event):
"""!Clears text area
