[GRASS-SVN] r44080 - grass/trunk/lib/gis
Fri Oct 29 05:36:45 EDT 2010
Author: huhabla
Date: 2010-10-29 02:36:45 -0700 (Fri, 29 Oct 2010)
New Revision: 44080
   grass/trunk/lib/gis/parser_wps.c
Support more mime types for raster and vector inputs and outputs in WPS
process description.
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c	2010-10-29 08:40:39 UTC (rev 44079)
+++ grass/trunk/lib/gis/parser_wps.c	2010-10-29 09:36:45 UTC (rev 44080)
@@ -28,6 +28,24 @@
 #define WPS_INPUT 0
 #define WPS_OUTPUT 1
+static void wps_print_mimetype_text_plain(void);
+static void wps_print_mimetype_raster_tiff(void);
+static void wps_print_mimetype_raster_tiff_other(void);
+static void wps_print_mimetype_raster_png(void);
+static void wps_print_mimetype_raster_gif(void);
+static void wps_print_mimetype_raster_jpeg(void);
+static void wps_print_mimetype_raster_hfa(void);
+static void wps_print_mimetype_raster_netCDF(void);
+static void wps_print_mimetype_raster_netCDF_other(void);
+static void wps_print_mimetype_raster_grass_binary(void);
+static void wps_print_mimetype_raster_grass_ascii(void);
+static void wps_print_mimetype_vector_gml212(void);
+static void wps_print_mimetype_vector_kml22(void);
+static void wps_print_mimetype_vector_dgn(void);
+static void wps_print_mimetype_vector_shape(void);
+static void wps_print_mimetype_vector_zipped_shape(void);
+static void wps_print_mimetype_vector_grass_ascii(void);
+static void wps_print_mimetype_vector_grass_binary(void);
 static void wps_print_process_descriptions_begin(void);
 static void wps_print_process_descriptions_end(void);
@@ -38,14 +56,6 @@
 static void wps_print_process_outputs_begin(void);
 static void wps_print_process_outputs_end(void);
 static void wps_print_bounding_box_data(void);
-static void wps_print_mimetype_text_plain(void);
-static void wps_print_mimetype_raster_tiff(void);
-static void wps_print_mimetype_raster_png(void);
-static void wps_print_mimetype_raster_grass_binary(void);
-static void wps_print_mimetype_raster_grass_ascii(void);
-static void wps_print_mimetype_vector_gml310(void);
-static void wps_print_mimetype_vector_grass_ascii(void);
-static void wps_print_mimetype_vector_grass_binary(void);
 static void wps_print_ident_title_abstract(const char *, const char *, const char *);
 static void wps_print_complex_input(int , int , const char *, const char *, const char *, int , int );
 static void wps_print_complex_output(const char *, const char *, const char *, int );
@@ -87,7 +97,7 @@
  * values and value options (range is missing)
  * Flags are supported as boolean values.
- * The mime types for vector maps are GML 3.1 and grass ascii and binary vectors.
+ * The mime types for vector maps are GML 2.1.2 and grass ascii and binary vectors.
  * mime type: application/grass-vector-ascii  -> a text file generated with v.out.asci
  * Example.: urn:file:///path/name
  * mime type: application/grass-vector-binary -> the binary vectors must be addressed with a non standard urn:
@@ -544,7 +554,7 @@
     else if(type == TYPE_VECTOR)
-            wps_print_mimetype_vector_gml310();
+            wps_print_mimetype_vector_gml212();
     else if(type == TYPE_PLAIN_TEXT)
@@ -554,22 +564,36 @@
     fprintf(stdout,"\t\t\t\t\t<Supported>\n");
     if(type == TYPE_RASTER)
-            wps_print_mimetype_raster_tiff();
-            /* These mime types are currently not meaningful */
-            if(1 == 0) {
-                wps_print_mimetype_raster_png();
-                wps_print_mimetype_raster_grass_ascii();
-                wps_print_mimetype_raster_grass_binary();
+	    /*The supported types for input and output are different*/
+            if(inout_type == WPS_INPUT) {
+            	wps_print_mimetype_raster_tiff();
+            	wps_print_mimetype_raster_tiff_other();
+            	wps_print_mimetype_raster_png();
+            	wps_print_mimetype_raster_gif();
+            	wps_print_mimetype_raster_jpeg();
+            	wps_print_mimetype_raster_hfa();
+            	wps_print_mimetype_raster_netCDF();
+            	wps_print_mimetype_raster_netCDF_other();
+	    } else {
-            if(1 == 0) {
-                wps_print_mimetype_vector_grass_ascii();
-                wps_print_mimetype_vector_grass_binary();
+            	wps_print_mimetype_vector_kml22();
+            	wps_print_mimetype_vector_dgn();
+            	wps_print_mimetype_vector_shape();
+            	wps_print_mimetype_vector_zipped_shape();
+	    } else {
@@ -731,12 +755,12 @@
     fprintf(stdout,"\t\t\t\t\t\t<Format>\n");
     fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>text/xml</MimeType>\n");
     fprintf(stdout,"\t\t\t\t\t\t\t<Encoding>UTF-8</Encoding>\n");
-    fprintf(stdout,"\t\t\t\t\t\t\t<Schema>http://schemas.opengis.net/gml/3.1.0/polygon.xsd</Schema>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<Schema>http://schemas.opengis.net/gml/2.1.2/feature.xsd</Schema>\n");
     fprintf(stdout,"\t\t\t\t\t\t</Format>\n");
@@ -758,6 +782,96 @@
+    fprintf(stdout,"\t\t\t\t\t\t<Format>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>image/gif</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t</Format>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>image/jpeg</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/x-erdas-hfa</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>image/geotiff</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/geotiff</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/x-geotiff</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/netcdf</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/x-netcdf</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>text/xml</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<Encoding>UTF-8</Encoding>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<Schema>http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd</Schema>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/dgn</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/shp</MimeType>\n");
+    fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/x-zipped-shp</MimeType>\n");
 /* Bounding box data input. Do not use! Under construction. A list of coordinate reference systems must be created.*/
