[GRASS-SVN] r44099 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 30 08:38:20 EDT 2010
Author: martinl
Date: 2010-10-30 05:38:20 -0700 (Sat, 30 Oct 2010)
New Revision: 44099
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: use platform specific shlex.split() in command prompt
(merge r44088 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-10-30 12:22:38 UTC (rev 44098)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2010-10-30 12:38:20 UTC (rev 44099)
@@ -613,7 +613,7 @@
if cmdString[:2] == 'd.' and not self.parent.curr_page:
self.parent.NewDisplay(show=True)
- cmd = shlex.split(str(cmdString))
+ cmd = utils.split(cmdString)
if len(cmd) > 1:
self.parent.RunCmd(cmd, switchPage = True)
else:
@@ -888,9 +888,9 @@
# parse command into list
try:
- cmd = shlex.split(str(line))
+ cmd = utils.split(str(line))
except UnicodeError:
- cmd = shlex.split(utils.EncodeString((line)))
+ cmd = utils.split(utils.EncodeString((line)))
# send the command list to the processor
self.parent.RunCmd(cmd)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-10-30 12:22:38 UTC (rev 44098)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-10-30 12:38:20 UTC (rev 44099)
@@ -18,6 +18,7 @@
import string
import glob
import locale
+import shlex
import globalvar
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
@@ -31,6 +32,10 @@
"""!Remove redundant whitespace from a string"""
return string.join(string.split(text), ' ')
+def split(s):
+ """!Platform spefic shlex.split"""
+ return shlex.split(s, posix = (sys.platform != "win32"))
def GetTempfile(pref=None):
Creates GRASS temporary file using defined prefix.
