[GRASS-SVN] r44103 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 30 11:52:25 EDT 2010
Author: martinl
Date: 2010-10-30 08:52:25 -0700 (Sat, 30 Oct 2010)
New Revision: 44103
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
fix r44102
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-10-30 15:44:02 UTC (rev 44102)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2010-10-30 15:52:25 UTC (rev 44103)
@@ -698,32 +698,30 @@
self.console_progressbar.SetValue(0) # reset progress bar on '0%'
self.cmd_output_timer.Stop()
- # set focus on prompt
- if self.parent.GetName() == "LayerManager" and \
- event.cmd[0] in globalvar.grassCmd['all']:
+ if self.parent.GetName() == "LayerManager":
self.btn_abort.Enable(False)
+ if event.cmd[0] not in globalvar.grassCmd['all']:
+ return
display = self.parent.GetLayerTree().GetMapDisplay()
- if display and display.IsAutoRendered():
- mapLayers = map(lambda x: x.GetName(),
- display.GetRender().GetListOfLayers(l_type = 'raster') +
- display.GetRender().GetListOfLayers(l_type = 'vector'))
- task = menuform.GUI().ParseCommand(event.cmd, show = None)
- for p in task.get_options()['params']:
- if p.get('prompt', '') not in ('raster', 'vector'):
- continue
- mapName = p.get('value', '')
- if '@' not in mapName:
- mapName = mapName + '@' + grass.gisenv()['MAPSET']
- if mapName in mapLayers:
- display.GetWindow().UpdateMap(render = True)
- return
+ if not display or not display.IsAutoRendered():
+ return
+ mapLayers = map(lambda x: x.GetName(),
+ display.GetRender().GetListOfLayers(l_type = 'raster') +
+ display.GetRender().GetListOfLayers(l_type = 'vector'))
- else:
- # updated command dialog
+ task = menuform.GUI().ParseCommand(event.cmd, show = None)
+ for p in task.get_options()['params']:
+ if p.get('prompt', '') not in ('raster', 'vector'):
+ continue
+ mapName = p.get('value', '')
+ if '@' not in mapName:
+ mapName = mapName + '@' + grass.gisenv()['MAPSET']
+ if mapName in mapLayers:
+ display.GetWindow().UpdateMap(render = True)
+ return
+ else: # standalone dialogs
dialog = self.parent.parent
if hasattr(self.parent.parent, "btn_abort"):
dialog.btn_abort.Enable(False)
@@ -783,8 +781,6 @@
time.sleep(1)
dialog.Close()
- event.Skip()
def OnProcessPendingOutputWindowEvents(self, event):
self.ProcessPendingEvents()
