[GRASS-SVN] r43396 - grass-addons/imagery/i.topo.corr
svn_grass at osgeo.org
Fri Sep 3 11:58:49 EDT 2010
Author: ejtizado
Date: 2010-09-03 15:58:49 +0000 (Fri, 03 Sep 2010)
New Revision: 43396
grass-addons/imagery/i.topo.corr/correction.c
grass-addons/imagery/i.topo.corr/description.html
grass-addons/imagery/i.topo.corr/local_proto.h
grass-addons/imagery/i.topo.corr/main.c
Two bugs corrected
Modified: grass-addons/imagery/i.topo.corr/correction.c
--- grass-addons/imagery/i.topo.corr/correction.c 2010-09-03 15:44:49 UTC (rev 43395)
+++ grass-addons/imagery/i.topo.corr/correction.c 2010-09-03 15:58:49 UTC (rev 43396)
@@ -83,25 +83,22 @@
/* Calculating Constants */
switch (method) {
case MINNAERT:
- cka = cos_z;
- ckb = 0.;
+ cka = ckb = 0.;
kk = m;
G_message("Minnaert constant = %lf", kk);
break;
case C_CORRECT:
- cka = cos_z + a / m;
- ckb = a / m;
+ cka = ckb = m / a;
kk = 1.;
- G_message("C-factor constant = %lf (a=%.4f; m=%.4f)", a / m, a, m);
+ G_message("C-factor constant = %lf (a=%.4f; m=%.4f)", cka, a, m);
break;
case PERCENT:
- cka = 2.;
+ cka = 2. - cos_z;
ckb = 1.;
kk = 1.;
break;
default: /* COSINE */
- cka = cos_z;
- ckb = 0.;
+ cka = ckb = 0.;
kk = 1.;
/* Topographic correction */
@@ -135,21 +132,12 @@
else {
ref_i = (double)*((DCELL *) pref);
- if (method == MINNAERT) {
- G_debug(3,
- "Old val: %f, cka: %f, cos_i: %f, ckb: %f, kk: %f, New val: %f",
- ref_i, cka, cos_i, ckb, kk, (DCELL) (ref_i * pow(cos_z / cos_i, kk)));
- ((DCELL *) out->rast)[col] =
- (DCELL) (ref_i * pow(cos_z / cos_i, kk));
- else {
- G_debug(3,
- ref_i, cka, cos_i, ckb, kk, (DCELL) (ref_i * (cka / (cos_i + ckb))));
- (DCELL) (ref_i * (cka / (cos_i + ckb)));
+ ((DCELL *) out->rast)[col] =
+ (DCELL) (ref_i * pow((cos_z + cka) / (cos_i + ckb), kk));
+ G_debug(3,
+ "Old val: %f, cka: %f, cos_i: %f, ckb: %f, kk: %f, New val: %f",
+ ref_i, cka, cos_i, ckb, kk,
+ ((DCELL *) out->rast)[col]);
G_put_raster_row(out->fd, out->rast, out->type);
Modified: grass-addons/imagery/i.topo.corr/description.html
--- grass-addons/imagery/i.topo.corr/description.html 2010-09-03 15:44:49 UTC (rev 43395)
+++ grass-addons/imagery/i.topo.corr/description.html 2010-09-03 15:58:49 UTC (rev 43396)
@@ -36,7 +36,7 @@
<li>ref_c = ref_o · (cos_z + c)/ (cos_i + c)</li>
</ul>
where,
-<em>c</em> is a/m from ref_o = a + m cos_i.</p>
+<em>c</em> is m/a from ref_o = a + m cos_i.</p>
<H3>Method: percent</H3>
Modified: grass-addons/imagery/i.topo.corr/local_proto.h
--- grass-addons/imagery/i.topo.corr/local_proto.h 2010-09-03 15:44:49 UTC (rev 43395)
+++ grass-addons/imagery/i.topo.corr/local_proto.h 2010-09-03 15:58:49 UTC (rev 43396)
@@ -7,11 +7,11 @@
typedef struct
- int fd;
- char name[128];
- char * mapset;
- void * rast;
- RASTER_MAP_TYPE type;
+ int fd;
+ char name[128];
+ char *mapset;
+ void *rast;
+ RASTER_MAP_TYPE type;
} Gfile;
#define LAMBERTIAN 0
@@ -21,8 +21,9 @@
#define MINNAERT 11
#define C_CORRECT 12
-void eval_cosi(Gfile *, Gfile *, double, double);
+void eval_c_cosi(Gfile *, Gfile *, double, double);
+void eval_f_cosi(Gfile *, Gfile *, double, double);
+void eval_d_cosi(Gfile *, Gfile *, double, double);
void eval_tcor(int, Gfile *, Gfile *, Gfile *, double);
#endif
Modified: grass-addons/imagery/i.topo.corr/main.c
--- grass-addons/imagery/i.topo.corr/main.c 2010-09-03 15:44:49 UTC (rev 43395)
+++ grass-addons/imagery/i.topo.corr/main.c 2010-09-03 15:58:49 UTC (rev 43396)
@@ -22,10 +22,6 @@
#include "local_proto.h"
-extern void eval_c_cosi(Gfile *, Gfile *, double, double);
-extern void eval_f_cosi(Gfile *, Gfile *, double, double);
-extern void eval_d_cosi(Gfile *, Gfile *, double, double);
int full_open_old(Gfile * gf, char *fname)
gf->fd = -1;
@@ -259,6 +255,5 @@
G_close_cell(dem.fd);
- G_done_msg(" ");
exit(EXIT_SUCCESS);
