[GRASS-SVN] r43420 - grass-addons/grass7/imagery/i.landsat.toar
Mon Sep 6 12:39:48 EDT 2010
Author: ejtizado
Date: 2010-09-06 16:39:48 +0000 (Mon, 06 Sep 2010)
New Revision: 43420
   grass-addons/grass7/imagery/i.landsat.toar/i.landsat.toar.html
   grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c
Reverted 127 to 255 qcalmax value in MSS sensors
Modified: grass-addons/grass7/imagery/i.landsat.toar/i.landsat.toar.html
--- grass-addons/grass7/imagery/i.landsat.toar/i.landsat.toar.html	2010-09-06 16:38:59 UTC (rev 43419)
+++ grass-addons/grass7/imagery/i.landsat.toar/i.landsat.toar.html	2010-09-06 16:39:48 UTC (rev 43420)
@@ -160,6 +160,7 @@
 <H2>REFERENCES</H2>
 <ol>
+  <li>Chander G., B.L. Markham and D.L. Helder: Remote Sensing of Environment, vol. 113, 2009.</li>
   <li>Chander G.H. and B. Markham: IEEE Transactions On Geoscience And Remote Sensing, vol. 41, no. 11, November 2003.</li>
   <li>Chavez P.S., jr. 1996. Image-based atmospheric corrections - Revisited and Improved. Photogrammetric Engineering and Remote Sensing 62 (9): 1025-1036.</li>
   <li>Huang et al: At-Satellite Reflectance: A First Order Normalization Of Landsat 7 ETM+ Images. 2002.</li>
Modified: grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c
--- grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c	2010-09-06 16:38:59 UTC (rev 43419)
+++ grass-addons/grass7/imagery/i.landsat.toar/landsat_set.c	2010-09-06 16:39:48 UTC (rev 43420)
@@ -54,7 +54,7 @@
 		lsat->band[i].wavemax = *(wmax + i);
 		lsat->band[i].wavemin = *(wmin + i);
 		lsat->band[i].qcalmax = 255.;
-		lsat->band[i].qcalmin = 0.;		/* modified in set_TM5 by date */
+		lsat->band[i].qcalmin = 0.;	/* Modified in set_TM5 by date */
 		lsat->band[i].thermal = (lsat->band[i].number == 6 ? 1 : 0);
 	return;
@@ -97,19 +97,19 @@
  * PURPOSE:     Store values of Landsat-1 MSS
- *              July 23, 1972 to January 6, 1978
+ *              July 23, 1972 to January 7, 1978
 void set_MSS1(lsat_data * lsat)
     int i, j;
-    /** Brian L. Markham and John L. Barker.
-        EOSAT Landsat Technical Notes, No. 1, 1986 */
+    /** Markham and Barker. EOSAT Landsat Technical Notes, No. 1, 1986;
+        Chander, Markham and Helder. Remote Sensing of Environment, 113 (2009)*/
     /* Spectral radiances at detector */
     double lmax[] = { 248., 200., 176., 153. };
     double lmin[] = {   0.,   0.,   0.,   0. };
     /* Solar exoatmospheric spectral irradiances */
-    double esun[] = { 1852., 1584., 1276., 904. };
+    double esun[] = { 1823., 1559., 1276., 880.1 };
     lsat->number = 1;
     sensor_MSS( lsat );
@@ -134,15 +134,15 @@
     int i, j;
     double julian, *lmax, *lmin;
-    double Lmax[][4] = { { 210., 156., 140., 138. },    /* before      July 16, 1975 */
-                         { 263., 176., 152., 130. } };  /* on or after July 16, 1975 */
+    double Lmax[][4] = { { 210., 156., 140., 138. },       /* before      July 16, 1975 */
+                         { 263., 176., 152., 130.333 } };  /* on or after July 16, 1975 */
     double Lmin[][4] = { {  10.,   7.,   7.,   5. },
-                         {   8.,   6.,   6.,   4. } };
+                         {   8.,   6.,   6.,   3.667 } };
-    double esun[] = { 1856., 1559., 1269., 906. };
+    double esun[] = { 1829., 1539., 1268., 886.6 };
     julian = julian_char(lsat->creation);
     if (julian < julian_char("1975-07-16")) i = 0;
@@ -175,15 +175,15 @@
     int i, j;
     double Lmax[][4] = { { 220., 175., 145., 147. },   /* before      June 1, 1978 */
                          { 259., 179., 149., 128. } }; /* on or after June 1, 1978 */
     double Lmin[][4] = { {   4.,   3.,   3.,   1. },
                          {   4.,   3.,   3.,   1. } };
-    double esun[] = { 1860., 1571., 1289., 910. };
+    double esun[] = { 1839., 1555., 1291., 887.9 };
     if (julian < julian_char("1978-06-01")) i = 0;
@@ -214,8 +214,8 @@
     int i, j;
     double Lmax[][4] = { { 250., 180., 150., 133. },     /* before      August 26, 1982 */
                          { 230., 180., 130., 133. },     /* between                     */
@@ -224,7 +224,7 @@
                          {   2.,   4.,   4.,   3. },
                          {   4.,   4.,   5.,   4. } };
-    double esun[] = { 1851., 1593., 1260., 878. };
+    double esun[] = { 1827., 1569., 1260., 866.4 };
     if (julian < julian_char("1982-08-26")) i = 0;
@@ -257,14 +257,13 @@
     double Lmax[][7] = { { 158.42, 308.17, 234.63, 224.32, 32.42, 15.64,  17.00 },   /* before August 1983      */
                          { 142.86, 291.25, 225.00, 214.29, 30.00, 12.40,  15.93 },   /* before January 15, 1984 */
-                         { 152.10, 296.80, 204.30, 206.20, 27.19, 15.60,  14.38 } }; /* after  Jaunary 15, 1984 */
+                         { 152.10, 296.81, 204.30, 206.20, 27.19, 15.3032,  14.38 } }; /* after  Jaunary 15, 1984 */
     double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  2.00,  -0.15 },
                          {   0.00,   0.00,   0.00,   0.00,  0.00,  4.84,   0.00 },
-                         {  -1.50,  -2.80,  -1.20,  -1.50, -0.37,  1.238, -0.15 } };
-    /** Gyanesh Chander and Brian Markham.
-        IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
+                         {  -1.50,  -2.80,  -1.20,  -1.50, -0.37,  1.2378, -0.15 } };
+    /** Chander, Markham and Helder. Remote Sensing of Environment, 113 (2009) */
-    double esun[] = { 1957., 1825., 1557., 1033., 214.9, 0., 80.72 };
+    double esun[] = { 1983., 1795., 1539., 1028., 219.8, 0., 83.49 };
     /* Thermal band calibration constants: K1 = 671.62   K2 = 1284.30 */
@@ -312,7 +311,7 @@
                          {   3.,   3.,   4.,   3. },
                          {   3.,   3.,   5.,   3. } };
-    double esun[] = { 1849., 1595., 1253., 870. };
+    double esun[] = { 1824., 1570., 1249., 853.4 };
     if (julian < julian_char("1984-04-06")) i = 0;
@@ -345,14 +344,13 @@
     double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303,  14.38 },    /* before May 4, 2003 */
                          { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303,  16.50 },    /* after May 4, 2003 */
-	/** Gyanesh Chander, Brian L. Markham, and Julia A. Barsi
-						 IEEE Geoscience And Remote Sensing Letters, Vol. 4, No. 3, July 2007 */
                          { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303,  16.50 } };  /* after April 2, 2007 */
     double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
                          {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 } };
-    double esun[] = { 1957., 1826., 1554., 1036., 215.0, 0., 80.67 };
+    double esun[] = { 1983., 1796., 1536., 1031., 220.0, 0., 83.44 };
     /* Thermal band calibration constants: K1 = 607.76   K2 = 1260.56 */
@@ -362,31 +360,28 @@
     lmax = Lmax[i];
     lmin = Lmin[i];
     if ( i == 2 ) { /* in Chander, Markham and Barsi 2007 */
-        jbuf = julian_char(lsat->date); /* Yes, here acquisition date */
-        if (jbuf >= julian_char("1992-01-01")) {
+        julian = julian_char(lsat->date); /* Yes, here acquisition date */
+        if (julian >= julian_char("1992-01-01")) {
             lmax[0] = 193.0;
             lmax[1] = 365.0;
+	jbuf = julian_char("2004-04-04");
+	if (julian >= jbuf) G_warning("Using QCalMin=1.0 as a NLAPS product processed after 4/4/2004");
     lsat->number = 5;
     sensor_TM( lsat );
-	jbuf = julian_char("2004-04-04");
-	if (julian >= jbuf) {
-		G_warning("Using QCalMin=1.0 as NLAPS products processed after 4/4/2004");
     lsat->dist_es = earth_sun(lsat->date);
-    for (i = 0; i < lsat->bands; i++)
+    for (i = 0; i < lsat->bands; i++) {
         j = lsat->band[i].number - 1;
-			lsat->band[i].qcalmin = 1.;
+		if (julian >= jbuf) lsat->band[i].qcalmin = 1.;
 	    lsat->band[i].esun = *(esun + j);
 	    lsat->band[i].lmax = *(lmax + j);
 	    lsat->band[i].lmin = *(lmin + j);
-        if (lsat->band[i].thermal )  {
+        if (lsat->band[i].thermal ) {
             lsat->band[i].K1 = 607.76;
             lsat->band[i].K2 = 1260.56;
@@ -408,17 +403,18 @@
         Landsat 7. Science Data Users Handbook. Last update: February 17, 2007 */
     /* - LOW GAIN - */
-    double LmaxL[][8] = { { 297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.600, 244.0 },      /* before      July 1, 2000 */
-                          { 293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.540, 243.1 } };    /* on or after July 1, 2000 */
+    double LmaxL[][8] = { { 297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.60, 244.0 },      /* before      July 1, 2000 */
+                          { 293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.54, 243.1 } };    /* on or after July 1, 2000 */
     double LminL[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5,  -1.0,  0.0,  -0.35,   -5.0 },
                           {  -6.2,  -6.4,  -5.0,  -5.1,  -1.0,  0.0,  -0.35,   -4.7 } };
     /* - HIGH GAIN - */
     double LmaxH[][8] = { { 194.3, 202.4, 158.6, 157.5, 31.76, 12.65, 10.932, 158.4 },
-                          { 191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.800, 158.3 } };
+                          { 191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.80, 158.3 } };
     double LminH[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5, -1.0,   3.2,  -0.35,   -5.0 },
                           {  -6.2,  -6.4,  -5.0,  -5.1, -1.0,   3.2,  -0.35,   -4.7 } };
-    double esun[] = { 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
+    double esun[] = { 1997., 1812., 1533., 1039., 230.8, 0., 84.90, 1362. };
     /*  Thermal band calibration constants: K1 = 666.09   K2 = 1282.71 */
