[GRASS-SVN] r43426 - grass/branches/develbranch_6/gui/tcltk/gis.m
svn_grass at osgeo.org
Wed Sep 8 10:18:26 EDT 2010
Author: marisn
Date: 2010-09-08 14:18:26 +0000 (Wed, 08 Sep 2010)
New Revision: 43426
grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl
grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl
gis.m Fix PS Label placement problems on zoom-in/out
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl 2010-09-07 22:29:20 UTC (rev 43425)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl 2010-09-08 14:18:26 UTC (rev 43426)
@@ -709,10 +709,10 @@
cd $currdir
+ # cvdisplay might need new canvas coordinates. Coordconv has to be run first!
+ MapCanvas::coordconv $mon
GmTree::cvdisplay "root"
- set drawprog 100
- MapCanvas::coordconv $mon
set drawprog 0
$mapframe($mon) showstatusbar status
return
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl 2010-09-07 22:29:20 UTC (rev 43425)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl 2010-09-08 14:18:26 UTC (rev 43426)
@@ -28,6 +28,7 @@
variable array tree ;# mon
variable optlist
variable array dup ;# layer
+ variable canvasId ;# List of canvas item ID's for deletion on update
@@ -36,6 +37,7 @@
variable count
variable optlist
variable dup
+ variable canvasId
global mon
global iconpath
@@ -104,7 +106,9 @@
foreach key $optlist {
set opt($count,0,$key) $opt($count,1,$key)
+ set canvasId [ list ] ;# CanvasId is an empty list
incr count
return $node
@@ -298,10 +302,13 @@
variable tree
variable dup
variable count
+ variable canvasId
set tree($mon) $GmTree::tree($mon)
set id [GmTree::node_id $node]
+ # No need to do anything, if we are invisible/unset.
+ if { ! ( $opt($id,1,_check) ) } { return }
if {$opt($id,1,labels) == "" } {return}
set can($mon) $MapCanvas::can($mon)
@@ -312,8 +319,6 @@
} else {
set labelpath "$env(GISDBASE)/$env(LOCATION_NAME)/$env(MAPSET)/paint/labels/$opt($id,1,labels)"
- if { ! ( $opt($id,1,_check) ) } { return }
# open the v.label file for reading
if { [catch {set labelfile [open $labelpath r]} err ] } {
@@ -321,6 +326,10 @@
return
+ # Delete current labels on Canvas and empty ID list
+ $can($mon) delete canvasId
#loop through coordinates and options for each label
while { [gets $labelfile in] > -1 } {
set key ""
@@ -484,68 +493,69 @@
} else { set wdth $ropt($id,1,lbwidth) }
# create box around text
- switch $ropt($id,1,anchor) {
- "ne" {
- set boxcenter_x [expr {$ropt($id,1,xcoord) - ($wid-4) / 2}]
- set boxcenter_y [expr {$ropt($id,1,ycoord) + ($lineh+4) / 2}]
- "n" {
- set boxcenter_x $ropt($id,1,xcoord)
- set boxcenter_y [expr {$ropt($id,1,ycoord) - ($lineh+4) / 2}]
- "nw" {
- set boxcenter_x [expr {$ropt($id,1,xcoord) + ($wid-4) / 2}]
- "e" {
- set boxcenter_y $ropt($id,1,ycoord)
- "center" {
- "w" {
- "se" {
- "s" {
- "sw" {
- default {
+ if {$opt($id,1,lboxenable)} {
+ switch $ropt($id,1,anchor) {
+ "ne" {
+ set boxcenter_x [expr {$ropt($id,1,xcoord) - ($wid-4) / 2}]
+ set boxcenter_y [expr {$ropt($id,1,ycoord) + ($lineh+4) / 2}]
+ "n" {
+ set boxcenter_x $ropt($id,1,xcoord)
+ set boxcenter_y [expr {$ropt($id,1,ycoord) - ($lineh+4) / 2}]
+ "nw" {
+ set boxcenter_x [expr {$ropt($id,1,xcoord) + ($wid-4) / 2}]
+ "e" {
+ set boxcenter_y $ropt($id,1,ycoord)
+ "center" {
+ "w" {
+ "se" {
+ "s" {
+ "sw" {
+ default {
# draw recangle around label
- $can($mon) create rectangle \
+ lappend canvasId [$can($mon) create rectangle \
[expr {$boxcenter_x - $opt($id,1,lhoffset) - $wid / 2}] \
[expr {$boxcenter_y -2- $opt($id,1,lvoffset) - $lineh / 2}]\
[expr {$boxcenter_x + $opt($id,1,lhoffset) + $wid / 2}] \
[expr {$boxcenter_y + $opt($id,1,lvoffset) + $lineh / 2}]\
-width $wdth \
-outline $ropt($id,1,lborder) \
- -fill $lbackground
+ -fill $lbackground]
- $can($mon) create text $ropt($id,1,xcoord) $ropt($id,1,ycoord) \
+ lappend canvasId [$can($mon) create text $ropt($id,1,xcoord) $ropt($id,1,ycoord) \
-anchor $ropt($id,1,anchor) \
-justify $opt($id,1,ljust) \
-width $wid \
-fill $ropt($id,1,lfill) \
-font $ropt($id,1,lfont) \
- -text $ropt($id,1,ltxt)
+ -text $ropt($id,1,ltxt)]
default {
#for anything else, just move on
