[GRASS-SVN] r43435 - grass-addons/imagery/i.landsat.toar
svn_grass at osgeo.org
Thu Sep 9 04:13:01 EDT 2010
Author: hamish
Date: 2010-09-09 08:13:01 +0000 (Thu, 09 Sep 2010)
New Revision: 43435
grass-addons/imagery/i.landsat.toar/landsat.c
grass-addons/imagery/i.landsat.toar/landsat_met.c
rm unused variables, {}
Modified: grass-addons/imagery/i.landsat.toar/landsat.c
--- grass-addons/imagery/i.landsat.toar/landsat.c 2010-09-09 08:06:28 UTC (rev 43434)
+++ grass-addons/imagery/i.landsat.toar/landsat.c 2010-09-09 08:13:01 UTC (rev 43435)
@@ -104,7 +104,7 @@
qcalmin) /
(lsat->band[i].qcalmax - lsat->band[i].qcalmin) +
lsat->band[i].lmin;
- double tv, Tv = 1.;
+ double Tv = 1.;
double Tz = 1.;
double Lp = 0.;
@@ -116,8 +116,8 @@
PI * Lp) / pi_d2;
Tz = 1 - (4 * pi_d2 * Lp) / (lsat->band[i].esun * sin_e);
Tv = exp(sin_e * log(Tz) / cos_v);
- // G_message("TAUv = %.5f (%.5f), TAUz = %.5f (%.5f) and Edown = %.5f\n", TAUv, Tv, TAUz, Tz, PI * Lp );
- // } while( abs(TAUv - Tv) > 0.0000001 || abs(TAUz - Tz) > 0.0000001);
+ // G_message("TAUv = %.5f (%.5f), TAUz = %.5f (%.5f) and Edown = %.5f\n", TAUv, Tv, TAUz, Tz, PI * Lp );
+ // } while( abs(TAUv - Tv) > 0.0000001 || abs(TAUz - Tz) > 0.0000001);
} while (TAUv != Tv && TAUz != Tz);
TAUz = (Tz < 1. ? Tz : 1.);
TAUv = (Tv < 1. ? Tv : 1.);
Modified: grass-addons/imagery/i.landsat.toar/landsat_met.c
--- grass-addons/imagery/i.landsat.toar/landsat_met.c 2010-09-09 08:06:28 UTC (rev 43434)
+++ grass-addons/imagery/i.landsat.toar/landsat_met.c 2010-09-09 08:13:01 UTC (rev 43435)
@@ -45,7 +45,7 @@
FILE *f;
char mettext[ETM_MET_SIZE];
char name[MAX_STR], value[MAX_STR];
- int i, j;
+ int i;
static int band[] = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
static int code[] = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
@@ -53,9 +53,9 @@
static double esun[] =
{ 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
- if ((f = fopen(metfile, "r")) == NULL) {
+ if ((f = fopen(metfile, "r")) == NULL)
G_fatal_error(_(".met file [%s] not found"), metfile);
fread(mettext, 1, ETM_MET_SIZE, f);
@@ -138,11 +138,12 @@
FILE *f;
char mettext[TM5_MET_SIZE];
- char metdate[MAX_STR], value[MAX_STR];
+ char value[MAX_STR];
+ /* char metdate[MAX_STR]; */
fread(mettext, 1, TM5_MET_SIZE, f);
