[GRASS-SVN] r43443 - grass-addons/gui/wxpython/wx.class
svn_grass at osgeo.org
Fri Sep 10 01:11:34 EDT 2010
Author: rashadkm
Date: 2010-09-10 05:11:34 +0000 (Fri, 10 Sep 2010)
New Revision: 43443
grass-addons/gui/wxpython/wx.class/wx.class.py
fixed fro grass6.4.0RC6
Modified: grass-addons/gui/wxpython/wx.class/wx.class.py
--- grass-addons/gui/wxpython/wx.class/wx.class.py 2010-09-09 23:45:31 UTC (rev 43442)
+++ grass-addons/gui/wxpython/wx.class/wx.class.py 2010-09-10 05:11:34 UTC (rev 43443)
@@ -24,6 +24,7 @@
import math
import tempfile
import copy
+import time
gbase = os.getenv("GISBASE")
pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
@@ -57,8 +58,14 @@
from preferences import globalSettings as UserSettings
from icon import Icons
from mapdisp import Command
-from mapdisp_window import BufferedWindow
-from mapdisp_window import MapWindow
+grassversion = os.getenv("GRASS_VERSION")
+if grassversion.rfind("6.4") != 0:
+ from mapdisp_window import BufferedWindow
+ from mapdisp_window import MapWindow
+else:
+ from mapdisp import BufferedWindow
+ from mapdisp import MapWindow
from mapdisp import MapFrame
from debug import Debug
import images
@@ -153,6 +160,7 @@
# Add statusbar
self.statusbar = self.CreateStatusBar(number=4, style=0)
self.statusbar.SetStatusWidths([-5, -2, -1, -1])
self.statusbarWin = dict()
@@ -213,8 +221,9 @@
value="", style=wx.TE_PROCESS_ENTER,
size=(300, -1))
self.statusbarWin['goto'].Hide()
- self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+ #self.statusbar.Bind(wx.EVT_TEXT_ENTER, MapFrame.OnGoTo, self.statusbarWin['goto'])
# projection
self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
label=_("Use defined projection"))
@@ -236,8 +245,67 @@
self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
range=0, style=wx.GA_HORIZONTAL)
self.statusbarWin['progress'].Hide()
+ if grassversion.rfind("6.4") != 0:
+ self.StatusbarReposition() # reposition statusbar
+ else:
+ self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
+ choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+ self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
+ self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
+ # auto-rendering checkbox
+ self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Render"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.autoRender)
+ self.autoRender.SetValue(UserSettings.Get(group='display', key='autoRendering', subkey='enabled'))
+ self.autoRender.SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+ # show region
+ self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Show computational extent"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.showRegion)
+ self.showRegion.SetValue(False)
+ self.showRegion.Hide()
+ self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
+ "region extent (set with g.region). "
+ "Display region drawn as a blue box inside the "
+ "computational region, "
+ "computational region inside a display region "
+ "as a red box).")))
+ # set resolution
+ self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+ label=_("Constrain display resolution to computational settings"))
+ self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
+ self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+ self.compResolution.Hide()
+ self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
+ "to computational region settings. "
+ "Default value for new map displays can "
+ "be set up in 'User GUI settings' dialog.")))
+ # map scale
+ self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+ value="", style=wx.TE_PROCESS_ENTER,
+ size=(150, -1))
+ self.mapScale.Hide()
+ self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.mapScale)
+ # mask
+ self.maskInfo = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+ label = '')
+ self.maskInfo.SetForegroundColour(wx.Colour(255, 0, 0))
+ # on-render gauge
+ self.onRenderGauge = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+ range=0, style=wx.GA_HORIZONTAL)
+ self.onRenderGauge.Hide()
- self.StatusbarReposition() # reposition statusbar
# Init map display (buffered DC & set default cursor)
@@ -245,7 +313,7 @@
Map=self.Map, tree=self.tree, lmgr=self.gismanager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
- self.MapWindow.Bind(wx.EVT_MOTION, self.MapWindow.OnMotion)
+ self.MapWindow.Bind(wx.EVT_MOTION, MapFrame.OnMotion)
self.MapWindow.SetCursor(self.cursors["default"])
# used by Nviz (3D display mode)
self.MapWindow3D = None
@@ -977,6 +1045,8 @@
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
+ self.tree = tree
+ self.Map = Map
# variables for drawing on DC
self.pen = None # pen for drawing zoom boxes, etc.
self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
@@ -993,7 +1063,12 @@
self.Bind(wx.EVT_IDLE, self.OnIdle)
### self.Bind(wx.EVT_MOTION, self.MouseActions)
self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
- self.Bind(wx.EVT_MOTION, self.OnMotion)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
self.processMouse = True
@@ -1021,8 +1096,17 @@
# This might result in OnSize getting called twice on some
# platforms at initialization, but little harm done.
### self.OnSize(None)
+ self.DefinePseudoDC()
+ else:
+ self.pdc = wx.PseudoDC()
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = wx.PseudoDC()
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = wx.PseudoDC()
- self.DefinePseudoDC()
# redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
self.redrawAll = True
@@ -1149,7 +1233,182 @@
self.pdc.EndDrawing()
self.Refresh()
+ def UpdateMap(self, render=True, renderVector=True):
+ Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ @param render re-render map composition
+ @param renderVector re-render vector map layer enabled for editing (used for digitizer)
+ start = time.clock()
+ self.resize = False
+ # if len(self.Map.GetListOfLayers()) == 0:
+ # return False
+ if self.img is None:
+ render = True
+ # initialize process bar (only on 'render')
+ if render is True or renderVector is True:
+ self.parent.statusbarWin['progress'].Show()
+ if self.parent.statusbarWin['progress'].GetRange() > 0:
+ self.parent.statusbarWin['progress'].SetValue(1)
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder == True:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ if render:
+ # update display size
+ self.Map.ChangeMapSize(self.GetClientSize())
+ if self.parent.statusbarWin['resolution'].IsChecked():
+ # use computation region resolution for rendering
+ windres = True
+ else:
+ windres = False
+ self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+ windres=windres)
+ else:
+ self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+ self.img = self.GetImage() # id=99
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype='clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
+ self.Draw(self.pdc, self.img, drawid=id)
+ # render vector map layer
+ digitToolbar = self.parent.toolbars['vdigit']
+ if renderVector and digitToolbar and \
+ digitToolbar.GetLayer():
+ # set region
+ self.parent.digit.driver.UpdateRegion()
+ # re-calculate threshold for digitization tool
+ self.parent.digit.driver.GetThreshold()
+ # draw map
+ if self.pdcVector:
+ self.pdcVector.Clear()
+ self.pdcVector.RemoveAll()
+ try:
+ item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+ except TypeError:
+ item = None
+ if item and self.tree.IsItemChecked(item):
+ self.parent.digit.driver.DrawMap()
+ # translate tmp objects (pointer position)
+ if digitToolbar.GetAction() == 'moveLine':
+ if hasattr(self, "vdigitMove") and \
+ self.vdigitMove.has_key('beginDiff'):
+ # move line
+ for id in self.vdigitMove['id']:
+ self.pdcTmp.TranslateId(id,
+ self.vdigitMove['beginDiff'][0],
+ self.vdigitMove['beginDiff'][1])
+ del self.vdigitMove['beginDiff']
+ # render overlays
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ self.Draw(self.pdc, img=img, drawid=id,
+ pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ for id in self.textdict.keys():
+ self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+ pdctype='text', coords=[10, 10, 10, 10])
+ # optionally draw computational extent box
+ self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ if not self.parent.IsStandalone() and \
+ self.parent.GetLayerManager().georectifying:
+ # -> georectifier (redraw GCPs)
+ if self.parent.toolbars['georect']:
+ coordtype = 'gcpcoord'
+ else:
+ coordtype = 'mapcoord'
+ self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
+ # clear measurement
+ if self.mouse["use"] == "measure":
+ self.ClearLines(pdc=self.pdcTmp)
+ self.polycoords = []
+ self.mouse['use'] = 'pointer'
+ self.mouse['box'] = 'point'
+ self.mouse['end'] = [0, 0]
+ self.SetCursor(self.parent.cursors["default"])
+ stop = time.clock()
+ # hide process bar
+ self.parent.statusbarWin['progress'].Hide()
+ # update statusbar
+ ### self.Map.SetRegion()
+ self.parent.StatusbarUpdate()
+ if grass1.find_file(name = 'MASK', element = 'cell')['name']:
+ # mask found
+ self.parent.statusbarWin['mask'].SetLabel(_('MASK'))
+ else:
+ self.parent.statusbarWin['mask'].SetLabel('')
+ Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ (render, renderVector, (stop-start)))
+ return True
class IClassApp(wx.App):
MapApp class
