[GRASS-SVN] r43462 - grass-addons/imagery/i.landsat.acca
svn_grass at osgeo.org
Tue Sep 14 01:51:41 EDT 2010
Author: hamish
Date: 2010-09-14 05:51:41 +0000 (Tue, 14 Sep 2010)
New Revision: 43462
grass-addons/imagery/i.landsat.acca/main.c
option, i18n cleanup
Modified: grass-addons/imagery/i.landsat.acca/main.c
--- grass-addons/imagery/i.landsat.acca/main.c 2010-09-14 05:29:17 UTC (rev 43461)
+++ grass-addons/imagery/i.landsat.acca/main.c 2010-09-14 05:51:41 UTC (rev 43462)
@@ -109,25 +109,21 @@
_("Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)");
input = G_define_option();
- input->key = _("band_prefix");
+ input->key = "band_prefix";
input->type = TYPE_STRING;
input->required = YES;
- input->gisprompt = _("input,cell,raster");
+ input->gisprompt = "input,cell,raster";
input->description =
_("Base name of the landsat band rasters ([band_prefix].[band_number])");
- output = G_define_option();
- output->key = _("output");
- output->type = TYPE_STRING;
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
output->required = YES;
- output->gisprompt = _("input,cell,raster");
- output->description = _("Output file name");
hist = G_define_option();
- hist->key = _("histogram");
+ hist->key = "histogram";
hist->type = TYPE_INTEGER;
hist->required = NO;
- hist->gisprompt = _("input,integer");
hist->description =
_("Number of classes in the cloud temperature histogram");
hist->answer = "100";
@@ -138,7 +134,7 @@
filter = G_define_flag();
filter->key = 'f';
- filter->description = _("Use final filter holes");
+ filter->description = _("Apply post-processing filter to remove small holes");
pass2 = G_define_flag();
pass2->key = '2';
@@ -146,11 +142,12 @@
shadow = G_define_flag();
shadow->key = 's';
- shadow->description = _("Add class for cloud shadows");
+ shadow->description = _("Include a category for cloud shadows");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* stores OPTIONS and FLAGS to variables */
hist_n = atoi(hist->answer);
@@ -172,7 +169,7 @@
snprintf(out.name, 127, "%s", out_name);
if (G_legal_filename(out_name) < 0)
- G_fatal_error(_("[%s] is an illegal name"), out.name);
+ G_fatal_error(_("<%s> is an illegal map name"), out.name);
