[GRASS-SVN] r43466 - grass-addons/imagery/i.landsat.acca
svn_grass at osgeo.org
Tue Sep 14 19:50:07 EDT 2010
Author: hamish
Date: 2010-09-14 23:50:07 +0000 (Tue, 14 Sep 2010)
New Revision: 43466
grass-addons/imagery/i.landsat.acca/algorithm.c
grass-addons/imagery/i.landsat.acca/main.c
grass-addons/imagery/i.landsat.acca/tools.c
standardized messages for i18n
Modified: grass-addons/imagery/i.landsat.acca/algorithm.c
--- grass-addons/imagery/i.landsat.acca/algorithm.c 2010-09-14 22:16:33 UTC (rev 43465)
+++ grass-addons/imagery/i.landsat.acca/algorithm.c 2010-09-14 23:50:07 UTC (rev 43466)
@@ -166,7 +166,7 @@
fprintf(stdout, " Skewness: %.2lf\n", value[SKEW]);
fprintf(stdout, " 97.50 percentile: %.2lf K\n", value[KUPPER]);
fprintf(stdout, " 83.50 percentile: %.2lf K\n", value[KLOWER]);
- // fprintf(stdout, " 50.00 percentile: %.2lf K\n", quantile(0.5,hist_cold) + K_BASE);
+ /* fprintf(stdout, " 50.00 percentile: %.2lf K\n", quantile(0.5,hist_cold) + K_BASE); */
else {
if (signa[KMEAN] < 295.) {
@@ -212,10 +212,10 @@
/* Creation of output file */
out->rast = G_allocate_raster_buf(CELL_TYPE);
if ((out->fd = G_open_raster_new(out->name, CELL_TYPE)) < 0)
- G_fatal_error(_("Could not open <%s>"), out->name);
+ G_fatal_error(_("Unable to create raster map <%s>"), out->name);
- fprintf(stdout, "Pass one processing ... \n");
+ G_message(_("Pass one processing ..."));
stats[SUM_COLD] = 0.;
stats[SUM_WARM] = 0.;
@@ -226,13 +226,11 @@
ncols = G_window_cols();
for (row = 0; row < nrows; row++) {
- if (verbose) {
- G_percent(row, nrows, 2);
for (i = BAND2; i <= BAND6; i++) {
if (G_get_d_raster_row(band[i].fd, band[i].rast, row) < 0)
- G_fatal_error(_("Could not read row from <%s>"),
- band[i].name);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"),
+ band[i].name, row);
for (col = 0; col < ncols; col++) {
code = NO_DEFINED;
@@ -328,9 +326,11 @@
((CELL *) out->rast)[col] = code;
- if (G_put_raster_row(out->fd, out->rast, CELL_TYPE) < 0) {
- G_fatal_error(_("Cannot write row to <%s>"), out->name);
+ if (G_put_raster_row(out->fd, out->rast, CELL_TYPE) < 0)
+ G_fatal_error(_("Failed writing raster map <%s> row %d"), out->name, row);
+ G_percent(row, nrows, 2);
@@ -354,21 +354,21 @@
/* Open to read */
mapset = G_find_cell2(out->name, "");
if (mapset == NULL)
- G_fatal_error("cell file [%s] not found", out->name);
+ G_fatal_error(_("Raster map <%s> not found"), out->name);
if ((out->fd = G_open_cell_old(out->name, mapset)) < 0)
- G_fatal_error("Cannot open cell file [%s]", out->name);
+ G_fatal_error(_("Unable to open raster map <%s>"), out->name);
/* Open to write */
sprintf(tmp.name, "_%d.BBB", getpid());
tmp.rast = G_allocate_raster_buf(CELL_TYPE);
if ((tmp.fd = G_open_raster_new(tmp.name, CELL_TYPE)) < 0)
- G_fatal_error(_("Could not open <%s>"), tmp.name);
+ G_fatal_error(_("Unable to create raster map <%s>"), tmp.name);
if (upper == 0.)
- fprintf(stdout, "Removing ambiguous pixels ... \n");
+ G_message(_("Removing ambiguous pixels ..."));
else
- fprintf(stdout, "Pass two processing ... \n");
+ G_message(_("Pass two processing ..."));
nrows = G_window_rows();
@@ -378,9 +378,9 @@
if (G_get_d_raster_row(band.fd, band.rast, row) < 0)
- G_fatal_error(_("Could not read from <%s>"), band.name);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), band.name, row);
if (G_get_c_raster_row(out->fd, out->rast, row) < 0)
- G_fatal_error(_("Could not read from <%s>"), out->name);
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row);
if (G_is_c_null_value((void *)((CELL *) out->rast + col))) {
Modified: grass-addons/imagery/i.landsat.acca/main.c
--- grass-addons/imagery/i.landsat.acca/main.c 2010-09-14 22:16:33 UTC (rev 43465)
+++ grass-addons/imagery/i.landsat.acca/main.c 2010-09-14 23:50:07 UTC (rev 43466)
@@ -55,27 +55,27 @@
mapset = G_find_cell2(raster_name, "");
if (mapset == NULL) {
- G_message("cell file [%s] not found", raster_name);
+ G_warning(_("Raster map <%s> not found"), raster_name);
return -1;
if (G_legal_filename(raster_name) < 0) {
- G_message("[%s] is an illegal name", raster_name);
+ G_warning(_("<%s> is an illegal file name"), raster_name);
return -1;
if ((raster_fd = G_open_cell_old(raster_name, mapset)) < 0) {
- G_message("Cannot open cell file [%s]", raster_name);
+ G_warning(_("Unable to open raster map <%s>"), raster_name);
return -1;
if (G_get_cellhd(raster_name, mapset, &cellhd) < 0) {
- G_message("Cannot read file header of [%s]", raster_name);
+ G_warning(_("Unable to read header of raster map <%s>"), raster_name);
return -1;
if (G_set_window(&cellhd) < 0) {
- G_message("Unable to set region");
+ G_warning(_("Cannot reset current region"));
return -1;
if ((map_type = G_raster_map_type(raster_name, mapset)) != DCELL_TYPE) {
- G_message("Map is not of DCELL_TYPE");
+ G_warning(_("Map is not DCELL type (process DN to radiance first)"));
return -1;
return raster_fd;
@@ -160,7 +160,7 @@
snprintf(band[i].name, 127, "%s.%d%c", in_name, i + 2,
(i == BAND6 && !sat5->answer ? '1' : '\0'));
if ((band[i].fd = check_raster(band[i].name)) < 0) {
- G_fatal_error(_("Error in filename [%s]!"), band[i].name);
+ G_fatal_error(_("Error in map name <%s>!"), band[i].name);
band[i].rast = G_allocate_raster_buf(DCELL_TYPE);
@@ -169,7 +169,7 @@
snprintf(out.name, 127, "%s", out_name);
if (G_legal_filename(out_name) < 0)
- G_fatal_error(_("<%s> is an illegal map name"), out.name);
+ G_fatal_error(_("<%s> is an illegal file name"), out.name);
Modified: grass-addons/imagery/i.landsat.acca/tools.c
--- grass-addons/imagery/i.landsat.acca/tools.c 2010-09-14 22:16:33 UTC (rev 43465)
+++ grass-addons/imagery/i.landsat.acca/tools.c 2010-09-14 23:50:07 UTC (rev 43466)
@@ -146,37 +146,38 @@
/* Open to read */
if (mapset == NULL)
arast = G_allocate_raster_buf(CELL_TYPE);
brast = G_allocate_raster_buf(CELL_TYPE);
crast = G_allocate_raster_buf(CELL_TYPE);
/* Open to write */
- fprintf(stdout, "Filling cloud holes ... \n");
+ G_message(_("Filling small holes in clouds ..."));
- if (verbose) {
/* Read row values */
if (row != 0) {
if (G_get_c_raster_row(out->fd, arast, row - 1) < 0)
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row - 1);
if (G_get_c_raster_row(out->fd, brast, row) < 0) {
if (row != (nrows - 1)) {
if (G_get_c_raster_row(out->fd, crast, row + 1) < 0)
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row + 1);
/* Analysis of all pixels */
@@ -267,14 +268,16 @@
- // pixel[1] = (row == 0 || col == 0) ? -1 : pval(arast, col - 1);
- // pixel[2] = (row == 0) ? -1 : pval(arast, col);
- // pixel[3] = (row == 0 || col == (ncols-1)) ? -1 : pval(arast, col + 1);
- // pixel[4] = (col == 0) ? -1 : pval(brast, col - 1);
- // pixel[5] = (col == (ncols-1)) ? -1 : pval(brast, col + 1);
- // pixel[6] = (row == (nrows-1) || col == 0) ? -1 : pval(crast, col - 1);
- // pixel[7] = (row == (nrows-1)) ? -1 : pval(crast, col);
- // pixel[8] = (row == (nrows-1) || col == (ncols-1)) ? -1 : pval(crast, col + 1);
+ pixel[1] = (row == 0 || col == 0) ? -1 : pval(arast, col - 1);
+ pixel[2] = (row == 0) ? -1 : pval(arast, col);
+ pixel[3] = (row == 0 || col == (ncols-1)) ? -1 : pval(arast, col + 1);
+ pixel[4] = (col == 0) ? -1 : pval(brast, col - 1);
+ pixel[5] = (col == (ncols-1)) ? -1 : pval(brast, col + 1);
+ pixel[6] = (row == (nrows-1) || col == 0) ? -1 : pval(crast, col - 1);
+ pixel[7] = (row == (nrows-1)) ? -1 : pval(crast, col);
+ pixel[8] = (row == (nrows-1) || col == (ncols-1)) ? -1 : pval(crast, col + 1);
cold = warm = shadow = nulo = 0;
for (i = 1; i < 9; i++) {
@@ -311,9 +314,11 @@
G_set_c_null_value((CELL *) tmp.rast + col, 1);
- if (G_put_raster_row(tmp.fd, tmp.rast, CELL_TYPE) < 0) {
- G_fatal_error(_("Cannot write to <%s>"), tmp.name);
+ if (G_put_raster_row(tmp.fd, tmp.rast, CELL_TYPE) < 0)
+ G_fatal_error(_("Failed writing raster map <%s> row %d"), tmp.name, row);
G_free(arast);
