[GRASS-SVN] r43478 - grass/trunk/raster/r.walk
svn_grass at osgeo.org
Thu Sep 16 06:13:16 EDT 2010
Author: mmetz
Date: 2010-09-16 10:13:16 +0000 (Thu, 16 Sep 2010)
New Revision: 43478
grass/trunk/raster/r.walk/main.c
fix wrong directions
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2010-09-16 07:25:59 UTC (rev 43477)
+++ grass/trunk/raster/r.walk/main.c 2010-09-16 10:13:16 UTC (rev 43478)
@@ -123,7 +123,7 @@
const char *dtm_mapset, *cost_mapset, *search_mapset;
void *dtm_cell, *cost_cell, *cum_cell, *dir_cell, *cell2 = NULL;
SEGMENT cost_seg, dir_seg;
- const char *in_file, *dir_out_file;
+ const char *in_file, *dir_out_file = NULL;
double *value;
char buf[400];
extern struct Cell_head window;
@@ -132,7 +132,6 @@
double min_cost, old_min_cost;
double cur_dir;
double zero = 0.0;
- int at_percent = 0;
int col = 0, row = 0, nrows = 0, ncols = 0;
int maxcost, par_number;
int nseg;
@@ -140,7 +139,7 @@
int segments_in_memory;
int cost_fd, cum_fd, dtm_fd, dir_fd;
int have_stop_points = 0, dir = 0;
- int in_fd, dir_out_fd;
+ int in_fd, dir_out_fd = 0;
double my_dtm, my_cost, check_dtm;
double null_cost, dnullval;
double a, b, c, d, lambda, slope_factor;
@@ -159,7 +158,9 @@
struct start_pt *pres_start_pt = NULL;
struct start_pt *pres_stop_pt = NULL;
struct cc {
- double cost_in, cost_out, dtm;
+ double dtm; /* elevation model */
+ double cost_in; /* friction costs */
+ double cost_out; /* cumulative costs */
} costs;
void *ptr1, *ptr2;
@@ -614,7 +615,7 @@
/* read required maps cost and dtm */
- int i, skip_nulls;
+ int skip_nulls;
double p_dtm, p_cost;
Rast_set_d_null_value(&dnullval, 1);
@@ -639,7 +640,7 @@
ptr1 = cost_cell;
ptr2 = dtm_cell;
- for (i = 0; i < ncols; i++) {
+ for (col = 0; col < ncols; col++) {
if (Rast_is_null_value(ptr1, cost_data_type)) {
p_cost = null_cost;
if (skip_nulls) {
@@ -682,7 +683,7 @@
costs.dtm = p_dtm;
- segment_put(&cost_seg, &costs, row, i);
+ segment_put(&cost_seg, &costs, row, col);
ptr1 = G_incr_void_ptr(ptr1, cost_dsize);
ptr2 = G_incr_void_ptr(ptr2, dtm_dsize);
@@ -693,13 +694,11 @@
if (dir == 1) {
- int i;
G_message(_("Initializing directional output "));
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- segment_put(&dir_seg, &dnullval, row, i);
+ segment_put(&dir_seg, &dnullval, row, col);
G_percent(1, 1, 1);
@@ -893,9 +892,10 @@
* 3) Free the memory allocated to the present cell.
+ G_debug(1, "total cells: %ld", total_cells);
+ G_debug(1, "nrows x ncols: %d", nrows * ncols);
G_message(_("Finding cost path"));
n_processed = 0;
- at_percent = 0;
pres_cell = get_lowest();
while (pres_cell != NULL) {
@@ -930,11 +930,17 @@
my_dtm = costs.dtm;
- if (Rast_is_d_null_value(&my_dtm))
+ if (Rast_is_d_null_value(&my_dtm)) {
+ delete(pres_cell);
+ pres_cell = get_lowest();
continue;
my_cost = costs.cost_in;
- if (Rast_is_d_null_value(&my_cost))
+ if (Rast_is_d_null_value(&my_cost)) {
continue;
G_percent(n_processed++, total_cells, 1);
@@ -1033,6 +1039,7 @@
if (col < 0 || col >= ncols)
continue;
+ min_cost = dnullval;
segment_get(&cost_seg, &costs, row, col);
switch (neighbor) {
case 1:
@@ -1320,9 +1327,8 @@
if (Rast_is_d_null_value(&min_cost))
continue;
+ segment_get(&cost_seg, &costs, row, col);
old_min_cost = costs.cost_out;
- if (dir == 1)
- segment_put(&dir_seg, &cur_dir, row, col);
if (Rast_is_d_null_value(&old_min_cost)) {
costs.cost_out = min_cost;
@@ -1331,16 +1337,12 @@
if (dir == 1)
- else {
- if (old_min_cost > min_cost) {
+ else if (old_min_cost > min_cost) {
- new_cell = insert(min_cost, row, col);
- if (dir == 1)
- else {
+ new_cell = insert(min_cost, row, col);
+ if (dir == 1)
+ segment_put(&dir_seg, &cur_dir, row, col);
