[GRASS-SVN] r43480 - grass-addons/grass7/raster/r.clump2
Thu Sep 16 12:06:56 EDT 2010
Author: mmetz
Date: 2010-09-16 16:06:56 +0000 (Thu, 16 Sep 2010)
New Revision: 43480
   grass-addons/grass7/raster/r.clump2/main.c
   grass-addons/grass7/raster/r.clump2/pq.c
   grass-addons/grass7/raster/r.clump2/r.clump2.html
add start point option
Modified: grass-addons/grass7/raster/r.clump2/main.c
--- grass-addons/grass7/raster/r.clump2/main.c	2010-09-16 13:00:46 UTC (rev 43479)
+++ grass-addons/grass7/raster/r.clump2/main.c	2010-09-16 16:06:56 UTC (rev 43480)
@@ -38,7 +38,8 @@
     struct Option *opt_in;
     struct Option *opt_out;
     struct Option *opt_title;
-    struct Flag *sides_flag;
+    struct Option *opt_coord;
+    struct Flag *flag_sides;
     CELL clump_no, *out_buf;
     struct Cell_head window, cellhd;
     int nrows, ncols, r, c;
@@ -48,7 +49,7 @@
     FLAG *inlist;
     int ramseg;
     long index, index_nbr;
-    int sides, s, r_nbr, c_nbr;
+    int sides, s, r_nbr, c_nbr, have_seeds = 0, *id_map = NULL;
     int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
     int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
@@ -73,12 +74,19 @@
     opt_title->type = TYPE_STRING;
     opt_title->required = NO;
     opt_title->description = _("Title");
+    opt_coord = G_define_option();
+    opt_coord->key = "coordinate";
+    opt_coord->type = TYPE_STRING;
+    opt_coord->key_desc = "x,y";
+    opt_coord->multiple = YES;
+    opt_coord->description =
+	_("Map grid coordinates of starting points (E,N)");
-    sides_flag = G_define_flag();
-    sides_flag->key = 'e';
-    sides_flag->description = _("Ignore diagonal cells");
+    flag_sides = G_define_flag();
+    flag_sides->key = 'e';
+    flag_sides->description = _("Ignore diagonal cells");
     /* parse options */
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -91,7 +99,7 @@
     if (out_fd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), opt_out->answer);
-    if (sides_flag->answer)
+    if (flag_sides->answer)
 	sides = 4;
     else
 	sides = 8;
@@ -148,9 +156,6 @@
     Rast_close(in_fd);
     G_free(in_buf);
-    /* determine clumps */
-    G_message(_("determine clumps ..."));
     ncells = nrows * ncols;
     counter = 1;
@@ -158,12 +163,60 @@
     init_pq(nrows * ncols * 0.02);
     clump_no = 1;
-    index = SEG_INDEX(ramseg, 0, 0);
-    if (clump_id[index] != 0)
-	clump_id[index] = clump_no++;
-    add_pnt(index);
-    FLAG_SET(inlist, 0, 0);
+    if (opt_coord->answers) {
+	int col, row, i;
+	double east, north;
+	char **answers = opt_coord->answers;
+	struct Cell_head window;
+	/* get start point coordinates */
+	G_message(_("get start point coordinates ..."));
+	G_get_window(&window);
+	for (; *answers != NULL; answers += 2) {
+	    if (!G_scan_easting(*answers, &east, G_projection()))
+		G_fatal_error(_("Illegal x coordinate <%s>"), *answers);
+	    if (*(answers + 1) == NULL)
+		G_fatal_error(_("Missing y corrdinate"));
+	    if (!G_scan_northing(*(answers + 1), &north, G_projection()))
+		G_fatal_error(_("Illegal y coordinate <%s>"), *(answers + 1));
+	    if (east < window.west || east > window.east ||
+		north < window.south || north > window.north) {
+		G_warning(_("Warning, ignoring point outside window: %.4f,%.4f"),
+			  east, north);
+		continue;
+	    row = (window.north - north) / window.ns_res;
+	    col = (east - window.west) / window.ew_res;
+	    index = SEG_INDEX(ramseg, row, col);
+	    if (clump_id[index] != 0) {
+		/* add seed points with decreasing clump ID: first point will seed first clump */
+		clump_id[index] = clump_no++;
+		add_pnt(index);
+		FLAG_SET(inlist, row, col);
+	id_map = G_malloc(clump_no * sizeof(int));
+	for (i = 0; i < clump_no; i++)
+	    id_map[i] = i;
+	have_seeds = 1;
+    else {
+	index = SEG_INDEX(ramseg, 0, 0);
+	add_pnt(index);
+	FLAG_SET(inlist, 0, 0);
+    /* determine clumps */
+    G_message(_("determine clumps ..."));
     while (pqsize > 0) {
 	int start_new = 1;
@@ -192,27 +245,53 @@
 		    else if (clump_id[index] == 0 && clump_id[index_nbr] == 0) {
-			add_pnt(index_nbr);
-			FLAG_SET(inlist, r_nbr, c_nbr);
+			if (!have_seeds) {
+			    add_pnt(index_nbr);
+			    FLAG_SET(inlist, r_nbr, c_nbr);
 		    else if (clump_id[index] != 0) {
 			if (clump_id[index_nbr] != 0)
 			    clump_id[index_nbr] = clump_id[index];
+			if (!have_seeds ||
+			    (have_seeds && clump_id[index_nbr] != 0)) {
+		else if (have_seeds) {
+		    /* safety check */
+		    index_nbr = SEG_INDEX(ramseg, r_nbr, c_nbr);
+		    if (clump_id[index] != clump_id[index_nbr]) {
+			G_warning(_("%d. and %d. start point are in the same clump, ignoring %d. start point"),
+			          clump_id[index], clump_id[index_nbr], clump_id[index_nbr]);
+			id_map[clump_id[index_nbr]] = clump_id[index];
+			clump_id[index_nbr] = clump_id[index];
     free_pq();
-    if (counter < ncells)
-	G_warning("missed some cells!");
-    flag_destroy(inlist);
+    if (counter < ncells) {
+	if (!have_seeds)
+	    G_warning("missed some cells!");
+	else
+	    G_percent(ncells, ncells, 1);
+    if (have_seeds && clump_no > 1) {
+	int i;
+	for (i = 1; i < clump_no; i++) {
+	    if (id_map[i] - id_map[i - 1] > 1)
+		id_map[i] = id_map[i - 1] + 1;
     /* write output */
     G_message(_("write output map ..."));
     out_buf = Rast_allocate_buf(CELL_TYPE);
@@ -220,6 +299,13 @@
 	G_percent(r, nrows, 2);
 	for (c = 0; c < ncols; c++) {
 	    index = SEG_INDEX(ramseg, r, c);
+	    if (have_seeds) {
+		if ((FLAG_GET(inlist, r, c)) == 0) {
+		    clump_id[index] = 0;
+		else
+		    clump_id[index] = id_map[clump_id[index]];
 	    if (clump_id[index] == 0)
 		Rast_set_c_null_value(&out_buf[c], 1);
 	    else
@@ -232,7 +318,11 @@
     G_free(out_buf);
     Rast_close(out_fd);
     G_free(clump_id);
+    flag_destroy(inlist);
+    if (id_map)
+	G_free(id_map);
     G_debug(1, "Creating support files...");
     /* build title */
Modified: grass-addons/grass7/raster/r.clump2/pq.c
--- grass-addons/grass7/raster/r.clump2/pq.c	2010-09-16 13:00:46 UTC (rev 43479)
+++ grass-addons/grass7/raster/r.clump2/pq.c	2010-09-16 16:06:56 UTC (rev 43480)
@@ -27,6 +27,15 @@
 static int heap_step;
 static long *heap_index;
+int cmp_clump(long cid1, long cid2)
+    if (!cid1)
+	return 0;
+    if (!cid2)
+	return 1;
+    return (cid1 < cid2);
 int init_pq(int step)
     pqsize = 0;
@@ -57,7 +66,7 @@
 	parent = GET_PARENT(child);
 	/* child is larger */
-	if (clump_id[child_pnt] > clump_id[heap_index[parent]]) {
+	if (cmp_clump(clump_id[child_pnt], clump_id[heap_index[parent]])) {
 	    /* push parent point down */
 	    heap_index[child] = heap_index[parent];
 	    child = parent;
@@ -120,8 +129,8 @@
 	    i = child + 3;
 	    /* get largest child */
 	    while (childr < i && childr <= pqsize) {
-		if (clump_id[heap_index[childr]] >
-		    clump_id[heap_index[child]]) {
+		if (cmp_clump(clump_id[heap_index[childr]],
+		    clump_id[heap_index[child]])) {
 		    child = childr;
 		childr++;
Modified: grass-addons/grass7/raster/r.clump2/r.clump2.html
--- grass-addons/grass7/raster/r.clump2/r.clump2.html	2010-09-16 13:00:46 UTC (rev 43479)
+++ grass-addons/grass7/raster/r.clump2/r.clump2.html	2010-09-16 16:06:56 UTC (rev 43480)
@@ -3,7 +3,8 @@
 <em>r.clump2</em> finds all areas of contiguous cell category values in the
 input raster map layer <em>name.</em> It assigns a unique category value
 to each such area ("clump") in the resulting output raster map layer
-<em>name.</em>
+<em>name.</em> Optionally <em>r.clump2</em> uses start points and finds
+only those clumps where the start points are falling into.
 <h4>Differences to r.clump</h4>
