[GRASS-SVN] r43484 - grass/trunk/lib/lidar
svn_grass at osgeo.org
Fri Sep 17 08:56:40 EDT 2010
Author: mmetz
Date: 2010-09-17 12:56:40 +0000 (Fri, 17 Sep 2010)
New Revision: 43484
grass/trunk/lib/lidar/lidar.h
grass/trunk/lib/lidar/zones.c
read raster and check masked cells in one go
Modified: grass/trunk/lib/lidar/lidar.h
--- grass/trunk/lib/lidar/lidar.h 2010-09-16 16:11:13 UTC (rev 43483)
+++ grass/trunk/lib/lidar/lidar.h 2010-09-17 12:56:40 UTC (rev 43484)
@@ -113,6 +113,7 @@
int *, /**/ int, /**/ int /**/);
struct Point *P_Read_Raster_Region_Map(double **, /**/
+ char **, /**/
struct Cell_head *, /**/
int *, /**/ int *, /**/ int /**/);
Modified: grass/trunk/lib/lidar/zones.c
--- grass/trunk/lib/lidar/zones.c 2010-09-16 16:11:13 UTC (rev 43483)
+++ grass/trunk/lib/lidar/zones.c 2010-09-17 12:56:40 UTC (rev 43484)
@@ -384,13 +384,13 @@
return obs;
-struct Point *P_Read_Raster_Region_Map(double **matrix,
+struct Point *P_Read_Raster_Region_Map(double **matrix, char **mask_matrix,
struct Cell_head *Elaboration,
struct Cell_head *Original,
int *num_points, int *num_nulls, int dim_vect)
int col, row, startcol, endcol, startrow, endrow, nrows, ncols;
- int pippo, npoints, nnulls;
+ int pippo, npoints, nnulls, all_masked = 0;
double x, y, z;
struct Point *obs;
struct bound_box elaboration_box;
@@ -404,6 +404,9 @@
npoints = nnulls = 0;
nrows = Original->rows;
ncols = Original->cols;
+ if (mask_matrix)
+ all_masked = 1;
if (Original->north > Elaboration->north)
startrow = (Original->north - Elaboration->north) / Original->ns_res - 1;
@@ -434,6 +437,12 @@
z = matrix[row][col];
if (!Rast_is_d_null_value(&z)) {
+ if (mask_matrix && all_masked) {
+ if (mask_matrix[row][col])
+ all_masked = 0;
x = Rast_col_to_easting((double)(col) + 0.5, Original);
y = Rast_row_to_northing((double)(row) + 0.5, Original);
@@ -460,8 +469,12 @@
+ /* num_nulls indicates how many points to interpolate */
+ if (all_masked)
+ *num_nulls = 0;
+ else
+ *num_nulls = nnulls;
*num_points = npoints;
- *num_nulls = nnulls;
return obs;
