[GRASS-SVN] r43486 - grass/trunk/vector/v.surf.bspline
svn_grass at osgeo.org
Fri Sep 17 08:58:06 EDT 2010
Author: mmetz
Date: 2010-09-17 12:58:06 +0000 (Fri, 17 Sep 2010)
New Revision: 43486
grass/trunk/vector/v.surf.bspline/main.c
add masking option to v.surf.bspline
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c 2010-09-17 12:57:28 UTC (rev 43485)
+++ grass/trunk/vector/v.surf.bspline/main.c 2010-09-17 12:58:06 UTC (rev 43486)
@@ -49,6 +49,7 @@
double **raster_matrix; /* Matrix to store the auxiliar raster values */
double *TN, *Q, *parVect; /* Interpolating and least-square vectors */
double **N, **obsVect; /* Interpolation and least-square matrix */
+ char **mask_matrix; /* matrix for masking */
/* Structs declarations */
int raster;
@@ -57,7 +58,7 @@
struct GModule *module;
struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *stepE_opt,
- *stepN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt;
+ *stepN_opt, *lambda_f_opt, *type_opt, *dfield_opt, *col_opt, *mask_opt;
struct Flag *cross_corr_flag, *spline_step_flag, *withz_flag;
struct Reg_dimens dims;
@@ -114,6 +115,12 @@
out_map_opt->key = "raster";
out_map_opt->required = NO;
+ mask_opt = G_define_standard_option(G_OPT_R_INPUT);
+ mask_opt->key = "mask";
+ mask_opt->label = _("Raster map to use for masking (applies to raster output only)");
+ mask_opt->description = _("Only cells that are not NULL and not zero are interpolated");
+ mask_opt->required = NO;
stepE_opt = G_define_option();
stepE_opt->key = "sie";
stepE_opt->type = TYPE_DOUBLE;
@@ -394,7 +401,43 @@
if (!(raster_matrix = G_alloc_matrix(nrows, ncols)))
G_fatal_error(_("Cannot allocate memory for auxiliar matrix."
"Consider changing region resolution"));
+ if (mask_opt->answer) {
+ int row, col, maskfd;
+ DCELL dval, *drastbuf;
+ G_message(_("Load masking map"));
+ mask_matrix = (char **)G_calloc(nrows, sizeof(char *));
+ mask_matrix[0] = (char *)G_calloc(nrows * ncols, sizeof(char));
+ for (row = 1; row < nrows; row++)
+ mask_matrix[row] = mask_matrix[row - 1] + ncols;
+ maskfd = Rast_open_old(mask_opt->answer, "");
+ drastbuf = Rast_allocate_buf(DCELL_TYPE);
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ Rast_get_d_row(maskfd, drastbuf, row);
+ for (col = 0; col < ncols; col++) {
+ dval = drastbuf[col];
+ if (Rast_is_d_null_value(&dval) || dval == 0)
+ mask_matrix[row][col] = 0;
+ else
+ mask_matrix[row][col] = 1;
+ G_free(drastbuf);
+ Rast_close(maskfd);
+ else
+ mask_matrix = NULL;
+ else
| Subdividing and working with tiles:
@@ -646,7 +689,7 @@
subregion_row, subregion_col);
raster_matrix =
P_Regular_Points(&elaboration_reg, &original_reg, general_box,
- overlap_box, raster_matrix, NULL, parVect,
+ overlap_box, raster_matrix, mask_matrix, parVect,
stepN, stepE, dims.overlap, mean,
nsplx, nsply, nrows, ncols, bilin);
