[GRASS-SVN] r43493 -
grass/branches/releasebranch_6_4/scripts/d.rast.leg
svn_grass at osgeo.org
Sat Sep 18 10:33:40 EDT 2010
Author: neteler
Date: 2010-09-18 14:33:40 +0000 (Sat, 18 Sep 2010)
New Revision: 43493
grass/branches/releasebranch_6_4/scripts/d.rast.leg/d.rast.leg
backported legend positioning improvements
Modified: grass/branches/releasebranch_6_4/scripts/d.rast.leg/d.rast.leg
--- grass/branches/releasebranch_6_4/scripts/d.rast.leg/d.rast.leg 2010-09-18 12:41:57 UTC (rev 43492)
+++ grass/branches/releasebranch_6_4/scripts/d.rast.leg/d.rast.leg 2010-09-18 14:33:40 UTC (rev 43493)
@@ -51,7 +51,7 @@
#% key: map
#% type: string
#% gisprompt: old,cell,raster
-#% description: Name of raster map
+#% description: Name of raster map to display
#% required : yes
#%end
#%option
@@ -77,21 +77,23 @@
#% key: position
#% type: double
#% description: Position of vertical map-legend separator (in percent)
-#% answer: 65
+#% answer: 80
#% required : no
#%end
if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
+ exec g.parser "$0" "$@"
fi
if [ $GIS_FLAG_N -eq 1 ] ; then
OMIT="-n"
+else
+ OMIT=""
fi
if [ $GIS_FLAG_F -eq 1 ] ; then
@@ -111,18 +113,23 @@
exit 1
fi
filemapset="${mapset}"
+# would it be better to search for cats/ file ??
eval `g.gisenv`
HISTFILEDIR=$GISDBASE/$LOCATION_NAME/$filemapset/cell_misc/
+eval `r.info -t "$GIS_OPT_MAP"`
# for rast=
-if [ ! -z $GIS_OPT_RAST ] ; then
- eval `g.findfile el=cell file=$GIS_OPT_RAST`
- if [ ! "$file" ] ; then
- g.message -e "Raster map '$GIS_OPT_RAST' not found in mapset search path"
- exit 1
- fi
+if [ -n "$GIS_OPT_RAST" ] ; then
+ eval `g.findfile el=cell file="$GIS_OPT_RAST"`
+ if [ ! "$file" ] ; then
+ g.message -e "Raster map '$GIS_OPT_RAST' not found in mapset search path"
+ exit 1
+ else
+ eval `r.info -t "$GIS_OPT_RAST"`
+ fi
fi
# save defined font setting
FONTCMD=`d.frame -l | grep d.font | sed 's+"++1'| sed 's+"++1'`
d.frame -e
@@ -133,32 +140,34 @@
XPOS=$GIS_OPT_POSITION
#at=bottom,top,left,right
+if [ "$datatype" = "CELL" ] ; then
+ # using at= turns off automatic font resize to fit in frame
+ LEG_AT=""
+else
+ LEG_AT="at=7,93,3,18"
+fi
-if [ -z "$GIS_OPT_NUM_OF_LINES" ]
-then
+if [ -z "$GIS_OPT_NUM_OF_LINES" ] ; then
#draw title
- d.frame -s at=90,100,$XPOS,100 frame=title
-# if test -f $GISBASE/bin/d.text.freetype ; then
-# d.text.freetype -sp text=$GIS_OPT_MAP col=black size=18 \
-# east_north=20,20 path=/usr/X11R6/lib/X11/fonts/TTF/luximb.ttf
-# else
- echo "$MAPNAME" | d.text col=black size=30
-# fi
+ d.frame -s at=90,100,$XPOS,100 frame=title
+ echo "$MAPNAME" | d.text col=black size=30
#draw legend
d.frame -s at=0,90,$XPOS,100 frame=right
- if [ -z $GIS_OPT_RAST ] ; then
+ if [ -z "$GIS_OPT_RAST" ] ; then
+ g.message -d "No lines; own legend"
if test -f $HISTFILEDIR/$GIS_OPT_MAP/histogram ; then
- d.legend $FLIP -n map=$GIS_OPT_MAP
+ d.legend $FLIP -n map="$GIS_OPT_MAP" $LEG_AT
else
- d.legend $FLIP $OMIT map=$GIS_OPT_MAP
+ d.legend $FLIP $OMIT map="$GIS_OPT_MAP" $LEG_AT
fi
else
+ g.message -d "No lines; external legend"
if test -f $HISTFILEDIR/$GIS_OPT_RAST/histogram ; then
- d.legend $FLIP -n map=$GIS_OPT_RAST
+ d.legend $FLIP -n map="$GIS_OPT_RAST" $LEG_AT
else
- d.legend $FLIP $OMIT map=$GIS_OPT_RAST
+ d.legend $FLIP $OMIT map="$GIS_OPT_RAST" $LEG_AT
fi
fi
@@ -169,33 +178,32 @@
else
#draw title
-# else
-# fi
#draw legend
+ g.message -d message="Lines=$GIS_OPT_NUM_OF_LINES; own legend"
- d.legend $FLIP -n map=$GIS_OPT_MAP lines=$GIS_OPT_NUM_OF_LINES
+ d.legend $FLIP -n map="$GIS_OPT_MAP" \
+ lines="$GIS_OPT_NUM_OF_LINES" $LEG_AT
else
fi
else
+ g.message -d message="Lines=$GIS_OPT_NUM_OF_LINES; external legend"
- d.legend $FLIP -n map=$GIS_OPT_RAST lines=$GIS_OPT_NUM_OF_LINES
+ d.legend $FLIP -n map="$GIS_OPT_RAST" \
else
fi
fi
#draw map
d.frame -s at=0,100,0,$XPOS frame=left
- d.rast map=$GIS_OPT_MAP
+ d.rast map="$GIS_OPT_MAP"
fi
