[GRASS-SVN] r43508 -
grass/branches/releasebranch_6_4/imagery/i.his.rgb
svn_grass at osgeo.org
Sat Sep 18 12:11:30 EDT 2010
Author: neteler
Date: 2010-09-18 16:11:29 +0000 (Sat, 18 Sep 2010)
New Revision: 43508
grass/branches/releasebranch_6_4/imagery/i.his.rgb/closefiles.c
grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c
grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c
backport: metadata and cleanup
Modified: grass/branches/releasebranch_6_4/imagery/i.his.rgb/closefiles.c
--- grass/branches/releasebranch_6_4/imagery/i.his.rgb/closefiles.c 2010-09-18 16:09:43 UTC (rev 43507)
+++ grass/branches/releasebranch_6_4/imagery/i.his.rgb/closefiles.c 2010-09-18 16:11:29 UTC (rev 43508)
@@ -12,6 +12,7 @@
int i;
struct Colors colors;
struct Range range;
+ struct History history;
CELL min, max;
char *mapset;
@@ -22,6 +23,8 @@
mapset = G_mapset();
+ /* write colors */
+ /* set to 0,max_level instead of min,max ?? */
G_read_range(r_name, mapset, &range);
G_get_range_min_max(&range, &min, &max);
G_make_grey_scale_colors(&colors, min, max);
@@ -37,5 +40,21 @@
G_write_colors(b_name, mapset, &colors);
+ /* write metadata */
+ G_short_history(r_name, "raster", &history);
+ G_command_history(&history);
+ G_write_history(r_name, &history);
+ G_put_cell_title(r_name, "Image red");
+ G_short_history(g_name, "raster", &history);
+ G_write_history(g_name, &history);
+ G_put_cell_title(g_name, "Image green");
+ G_short_history(b_name, "raster", &history);
+ G_write_history(b_name, &history);
+ G_put_cell_title(b_name, "Image blue");
return 0;
Modified: grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c
--- grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c 2010-09-18 16:09:43 UTC (rev 43507)
+++ grass/branches/releasebranch_6_4/imagery/i.his.rgb/h2rmain.c 2010-09-18 16:11:29 UTC (rev 43508)
@@ -75,6 +75,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* get dimension of the image */
rows = G_window_rows();
cols = G_window_cols();
@@ -91,7 +92,7 @@
/* read in a row from each cell map */
for (band = 0; band < 3; band++)
if (G_get_map_row(fd_input[band], rowbuffer[band], i) < 0)
- G_fatal_error(_("Unable to read raster map row %d"), i);
+ G_fatal_error(_("Unable to read raster map row %ld"), i);
/* process this row of the map */
his2rgb(rowbuffer, cols);
@@ -100,9 +101,11 @@
if (G_put_raster_row(fd_output[band], rowbuffer[band], CELL_TYPE)
< 0)
- G_fatal_error(_("Failed writing raster map row %d"), i);
+ G_fatal_error(_("Failed writing raster map row %ld"), i);
+ G_percent(i, rows, 2);
closefiles(opt_red->answer, opt_green->answer, opt_blue->answer,
fd_output, rowbuffer);
Modified: grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c
--- grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c 2010-09-18 16:09:43 UTC (rev 43507)
+++ grass/branches/releasebranch_6_4/imagery/i.his.rgb/his2rgb.c 2010-09-18 16:11:29 UTC (rev 43508)
@@ -19,7 +19,7 @@
#include <grass/gis.h>
#include "globals.h"
-void his2rgb(CELL * rowbuffer[3], int columns)
+void his2rgb(CELL *rowbuffer[3], int columns)
long sample; /* sample indicator */
double red; /* the red band output */
@@ -121,16 +121,16 @@
else
blue = blue255;
- if (red > 254.5)
- red = 254.5;
+ if (red > 255. - 0.5)
+ red = 255. - 0.5;
if (red < 0.0)
red = 0.0;
- if (green > 254.5)
- green = 254.5;
+ if (green > 255. - 0.5)
+ green = 255. - 0.5;
if (green < 0.0)
green = 0.0;
- if (blue > 254.5)
- blue = 254.5;
+ if (blue > 255. - 0.5)
+ blue = 255. - 0.5;
if (blue < 0.0)
blue = 0.0;
