[GRASS-SVN] r43534 - grass/branches/develbranch_6/vector/v.in.ogr
svn_grass at osgeo.org
Mon Sep 20 04:04:56 EDT 2010
Author: mmetz
Date: 2010-09-20 08:04:55 +0000 (Mon, 20 Sep 2010)
New Revision: 43534
grass/branches/develbranch_6/vector/v.in.ogr/geom.c
grass/branches/develbranch_6/vector/v.in.ogr/global.h
speed up vector polygon import, backport from trunk
Modified: grass/branches/develbranch_6/vector/v.in.ogr/geom.c
--- grass/branches/develbranch_6/vector/v.in.ogr/geom.c 2010-09-20 08:03:41 UTC (rev 43533)
+++ grass/branches/develbranch_6/vector/v.in.ogr/geom.c 2010-09-20 08:04:55 UTC (rev 43534)
@@ -25,6 +25,8 @@
#include "ogr_api.h"
#include "global.h"
+int split_line(struct Map_info *Map, int otype, struct line_pnts *Points,
+ struct line_cats *Cats);
/* Add categories to centroids inside polygon */
int
@@ -166,6 +168,35 @@
return 0;
+/* count polygons and isles */
+int poly_count(OGRGeometryH hGeom)
+ int i, nr, ret;
+ OGRwkbGeometryType eType;
+ OGRGeometryH hRing;
+ eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
+ if (eType == wkbPolygon) {
+ G_debug(3, "Polygon");
+ nr = OGR_G_GetGeometryCount(hGeom);
+ n_polygon_boundaries += nr;
+ else if (eType == wkbGeometryCollection || eType == wkbMultiPolygon) {
+ G_debug(3, "GeometryCollection or MultiPolygon");
+ for (i = 0; i < nr; i++) {
+ hRing = OGR_G_GetGeometryRef(hGeom, i);
+ ret = poly_count(hRing);
+ if (ret == -1) {
+ G_warning(_("Cannot read part of geometry"));
+ return 0;
/* Write geometry to output map */
int
geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
@@ -223,7 +254,11 @@
otype = GV_BOUNDARY;
else
otype = GV_LINE;
- Vect_write_line(Map, otype, Points, Cats);
+ if (split_distance > 0 && otype == GV_BOUNDARY)
+ split_line(Map, otype, Points, Cats);
+ else
+ Vect_write_line(Map, otype, Points, Cats);
else if (eType == wkbPolygon) {
@@ -256,7 +291,7 @@
size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
if (size < min_area) {
- G_warning(_("Area size [%.1e], area not imported"), size);
+ G_debug(2, "Area size [%.1e], area not imported", size);
return 0;
@@ -264,8 +299,12 @@
otype = GV_LINE;
else
- Vect_write_line(Map, otype, Points, BCats);
+ else
/* Isles */
IPoints =
(struct line_pnts **)G_malloc((nr - 1) *
@@ -298,7 +337,7 @@
IPoints[valid_isles]->y,
IPoints[valid_isles]->n_points);
- G_warning(_("Island size [%.1e], island not imported"),
+ G_debug(2, "Island size [%.1e], island not imported",
size);
else {
@@ -306,7 +345,11 @@
otype = GV_LINE;
else
- Vect_write_line(Map, otype, IPoints[valid_isles], BCats);
+ split_line(Map, otype, IPoints[valid_isles], BCats);
+ else
+ Vect_write_line(Map, otype, IPoints[valid_isles],
+ BCats);
valid_isles++;
@@ -383,3 +426,52 @@
return 0;
+ int i;
+ double dist = 0., seg_dist, dx, dy;
+ struct line_pnts *OutPoints;
+ /* don't write zero length boundaries */
+ Vect_line_prune(Points);
+ if (Points->n_points < 2)
+ return 0;
+ /* can't split boundaries with only 2 vertices */
+ if (Points->n_points == 2) {
+ return 0;
+ OutPoints = Vect_new_line_struct();
+ Vect_append_point(OutPoints, Points->x[0], Points->y[0], Points->z[0]);
+ Vect_append_point(OutPoints, Points->x[1], Points->y[1], Points->z[1]);
+ dx = Points->x[1] - Points->x[0];
+ dy = Points->y[1] - Points->y[0];
+ dist = sqrt(dx * dx + dy * dy);
+ /* trying to keep line length smaller than split_distance
+ * alternative, less code: write line as soon as split_distance is exceeded */
+ for (i = 2; i < Points->n_points; i++) {
+ dx = Points->x[i] - Points->x[i - 1];
+ dy = Points->y[i] - Points->y[i - 1];
+ seg_dist = sqrt(dx * dx + dy * dy);
+ dist += seg_dist;
+ if (dist > split_distance) {
+ Vect_write_line(Map, otype, OutPoints, Cats);
+ Vect_reset_line(OutPoints);
+ dist = seg_dist;
+ Vect_append_point(OutPoints, Points->x[i - 1], Points->y[i - 1],
+ Points->z[i - 1]);
+ Vect_append_point(OutPoints, Points->x[i], Points->y[i],
+ Points->z[i]);
+ Vect_destroy_line_struct(OutPoints);
+ return 0;
Modified: grass/branches/develbranch_6/vector/v.in.ogr/global.h
--- grass/branches/develbranch_6/vector/v.in.ogr/global.h 2010-09-20 08:03:41 UTC (rev 43533)
+++ grass/branches/develbranch_6/vector/v.in.ogr/global.h 2010-09-20 08:04:55 UTC (rev 43534)
@@ -26,11 +26,14 @@
#ifdef MAIN
int n_polygons = 0;
+int n_polygon_boundaries;
+double split_distance;
#else
extern int n_polygons;
+extern int n_polygon_boundaries;
+extern double split_distance;
#endif
/* centroid structure */
typedef struct
