[GRASS-SVN] r43547 - grass/trunk/raster/r.out.mpeg
Mon Sep 20 20:50:44 EDT 2010
Author: hamish
Date: 2010-09-21 00:50:44 +0000 (Tue, 21 Sep 2010)
New Revision: 43547
   grass/trunk/raster/r.out.mpeg/main.c
   grass/trunk/raster/r.out.mpeg/write.c
remove quiet flag, portable /dev/null, partial merge of cleanups from devbr6
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c	2010-09-21 00:38:11 UTC (rev 43546)
+++ grass/trunk/raster/r.out.mpeg/main.c	2010-09-21 00:50:44 UTC (rev 43547)
@@ -54,7 +54,7 @@
 /* global variables */
-int nrows, ncols, numviews, quality, quiet = 0;
+int nrows, ncols, numviews, quality, quiet = FALSE;
 char *vfiles[MAXVIEWS][MAXIMAGES];
 char outfile[GPATH_MAX];
 const char *encoder;
@@ -80,7 +80,7 @@
     status = G_spawn_ex(
 	encoder, encoder,
-	SF_REDIRECT_FILE, SF_STDERR, SF_MODE_OUT, "/dev/null",
+	SF_REDIRECT_FILE, SF_STDERR, SF_MODE_OUT, G_DEV_NULL,
 	NULL);
     G_suppress_warnings(prev);
@@ -100,8 +100,11 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
-    module->description = _("Raster file series to MPEG movie conversion program.");
+    G_add_keyword(_("animation"));
+    module->description =
+	_("Raster map series to MPEG movie conversion.");
     for (i = 0; i < MAXVIEWS; i++) {
 	char buf[BUFSIZ];
 	viewopts[i] = G_define_option();
@@ -133,22 +136,19 @@
     qual->description =
 	_("Quality factor (1 = highest quality, lowest compression)");
-    qt = G_define_flag();
-    qt->key = 'q';
-    qt->description = _("Quiet - suppress progress report");
     conv = G_define_flag();
     conv->key = 'c';
-    conv->description =
-	_("Convert on the fly, use less disk space\n\t(requires r.out.ppm with stdout option)");
+    conv->label = _("Convert on the fly, uses less disk space");
+    conv->description =	_("(requires r.out.ppm with stdout option)");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     parse_command(viewopts, vfiles, &numviews, &frames);
-    if (qt->answer)
-	quiet = 1;
+    if (G_verbose() <= G_verbose_min())
+	quiet = TRUE;
     r_out = 0;
     if (conv->answer)
@@ -194,7 +194,7 @@
     scale = 1.0;
-    {				/* find animation image size */
+    {	/* find animation image size */
 	int max, min;
 	char *p;
@@ -296,9 +296,9 @@
 	    name = vfiles[vnum][cnt];
-	    if (!quiet)
-		G_message("\r%s <%s>", _("Reading file"), name);
+	    G_message(_("Reading file <%s> ..."), name);
 	    fd = Rast_open_old(name, "");
 	    if (Rast_read_colors(name, "", &colors) < 0)
@@ -345,8 +345,8 @@
     if (quiet)
 	ret = G_spawn(encoder, encoder, mpfilename,
-		      SF_REDIRECT_FILE, SF_STDOUT, SF_MODE_OUT, "/dev/null",
+		      SF_REDIRECT_FILE, SF_STDOUT, SF_MODE_OUT, G_DEV_NULL,
 		      NULL);
     else
 	ret = G_spawn(encoder, encoder, mpfilename, NULL);
@@ -378,8 +378,8 @@
     if (quiet)
 		      NULL);
     else
@@ -505,7 +505,3 @@
Modified: grass/trunk/raster/r.out.mpeg/write.c
--- grass/trunk/raster/r.out.mpeg/write.c	2010-09-21 00:38:11 UTC (rev 43546)
+++ grass/trunk/raster/r.out.mpeg/write.c	2010-09-21 00:50:44 UTC (rev 43547)
@@ -333,6 +333,3 @@
 	remove(files[i]);
