[GRASS-SVN] r43552 - grass/branches/develbranch_6/raster/r.surf.contour
Tue Sep 21 03:15:48 EDT 2010
Author: mmetz
Date: 2010-09-21 07:15:48 +0000 (Tue, 21 Sep 2010)
New Revision: 43552
Added:
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_close.c
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_get.c
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_open.c
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_put.c
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_read.c
   grass/branches/develbranch_6/raster/r.surf.contour/dseg_write.c
   grass/branches/develbranch_6/raster/r.surf.contour/seg.h
Removed:
   grass/branches/develbranch_6/raster/r.surf.contour/cseg.h
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_close.c
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_get.c
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_open.c
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_put.c
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_read.c
   grass/branches/develbranch_6/raster/r.surf.contour/cseg_write.c
   grass/branches/develbranch_6/raster/r.surf.contour/addpts.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_close.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_get.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_open.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_put.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_read.c
   grass/branches/develbranch_6/raster/r.surf.contour/bseg_write.c
   grass/branches/develbranch_6/raster/r.surf.contour/contour.h
   grass/branches/develbranch_6/raster/r.surf.contour/find_con.c
   grass/branches/develbranch_6/raster/r.surf.contour/main.c
add fp and NULL (nodata) support
Modified: grass/branches/develbranch_6/raster/r.surf.contour/addpts.c
--- grass/branches/develbranch_6/raster/r.surf.contour/addpts.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/addpts.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -3,7 +3,7 @@
 NODE *addpts_slow(NODE * zero, int r, int c, int rr, int cc, int *node_ct)
     NODE *add_in_slow();
-    CELL value;
+    char value;
     if (rr < nrows - 1) {
 	bseg_get(&bseen, &value, rr + 1, cc);
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_close.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_close.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_close.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,6 +1,6 @@
 #include <unistd.h>
 #include <grass/gis.h>
-#include "cseg.h"
+#include "seg.h"
 int bseg_close(BSEG * bseg)
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_get.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_get.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_get.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,18 +1,18 @@
-#include "cseg.h"
+#include "seg.h"
-int bseg_get(BSEG * bseg, CELL * value, int row, int col)
+int bseg_get(BSEG * bseg, char * value, int row, int col)
     unsigned char x;
     char errmsg[200];
-    if (segment_get(&(bseg->seg), (int *)&x, row, col >> 3) < 0) {
+    if (segment_get(&(bseg->seg), &x, row, col >> 3) < 0) {
 	sprintf(errmsg,
 		"bseg_get(): could not read segment file at r:%d c:%d",
 		(int)row, (int)col);
 	G_warning(errmsg);
 	return -1;
-    *value = (CELL) ((x & (1 << (col & 7))) ? 1 : 0);
+    *value = (char) ((x & (1 << (col & 7))) ? 1 : 0);
     return 0;
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_open.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_open.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_open.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -3,7 +3,7 @@
 #include <sys/stat.h>
 #include <fcntl.h>
-#include "cseg.h"
+#include "seg.h"
 int bseg_open(BSEG * bseg, int srows, int scols, int nsegs_in_memory)
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_put.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_put.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_put.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,12 +1,12 @@
-#include "cseg.h"
+#include "seg.h"
-int bseg_put(BSEG * bseg, CELL * value, int row, int col)
+int bseg_put(BSEG * bseg, char * value, int row, int col)
     unsigned char old_value;
     char errmsg[200];
-    if (segment_get(&(bseg->seg), (int *)&old_value, row, col >> 3) < 0) {
+    if (segment_get(&(bseg->seg), &old_value, row, col >> 3) < 0) {
 	sprintf(errmsg,
 		"bseg_put(): could not read segment file at r:%d c:%d",
@@ -17,7 +17,7 @@
 	old_value |= (1 << (col & 7));
     else
 	old_value &= ~(1 << (col & 7));
-    if (segment_put(&(bseg->seg), (int *)&old_value, row, col >> 3) < 0) {
+    if (segment_put(&(bseg->seg), &old_value, row, col >> 3) < 0) {
 	sprintf(errmsg,
 		"bseg_put(): could not write segment file at r:%d c:%d",
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_read.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_read.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_read.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,6 +1,6 @@
 #include <unistd.h>
-#include "cseg.h"
+#include "seg.h"
 static char *me = "bseg_read_cell";
@@ -11,6 +11,7 @@
     int map_fd;
     char msg[100];
     CELL *buffer;
+    char value;
     bseg->name = NULL;
     bseg->mapset = NULL;
@@ -35,7 +36,8 @@
 	    return -2;
 	for (col = ncols; col >= 0; col--) {
-	    bseg_put(bseg, &(buffer[col]), row, col);
+	    value = (char) buffer[col];
+	    bseg_put(bseg, &(value), row, col);
Modified: grass/branches/develbranch_6/raster/r.surf.contour/bseg_write.c
--- grass/branches/develbranch_6/raster/r.surf.contour/bseg_write.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/bseg_write.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,5 +1,5 @@
-#include "cseg.h"
+#include "seg.h"
 static char *me = "bseg_write_cell";
@@ -9,7 +9,7 @@
     int row, nrows;
     int col, ncols;
     CELL *buffer;
-    CELL value;
+    char value;
     map_fd = G_open_cell_new(map_name);
     if (map_fd < 0) {
Modified: grass/branches/develbranch_6/raster/r.surf.contour/contour.h
--- grass/branches/develbranch_6/raster/r.surf.contour/contour.h	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/contour.h	2010-09-21 07:15:48 UTC (rev 43552)
@@ -2,7 +2,7 @@
 #include <math.h>
 #include "flag.h"
-#include "cseg.h"
+#include "seg.h"
 #define NODE		struct _n_o_d_e_
 #define INIT_AR		64
@@ -31,11 +31,11 @@
 GLOBAL int maxr;
 GLOBAL int array_size;
 GLOBAL double i_val_l_f;
-GLOBAL CSEG con;
+GLOBAL DSEG con;
 GLOBAL FLAG *seen, *mask;
 GLOBAL BSEG bseen, bmask;
 GLOBAL NODE *zero;
-GLOBAL CELL on, off;
+GLOBAL char on, off;
 /* add_in.c */
 NODE *add_in_slow(int, int, int, int, NODE *, int *);
@@ -46,5 +46,5 @@
 NODE *addpts(NODE *, int, int, int, int, int *);
 /* find_con.c */
-int find_con_slow(int, int, double *, double *, CELL *, CELL *);
-int find_con(int, int, double *, double *, CELL *, CELL *);
+int find_con_slow(int, int, double *, double *, DCELL *, DCELL *);
+int find_con(int, int, double *, double *, DCELL *, DCELL *);
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg.h
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg.h	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg.h	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,64 +0,0 @@
-#include <grass/segment.h>
-#define CSEG struct _c_s_e_g_
-CSEG {
-    SEGMENT seg;		/* segment structure */
-    int fd;			/* fd for reading/writing segment file */
-    char *filename;		/* name of segment file */
-    char *name;			/* raster map read into segment file */
-    char *mapset;
-#define DSEG struct _d_s_e_g_
-DSEG {
-    char *mapset;
-#define BSEG struct _b_s_e_g_
-BSEG {
-    char *mapset;
-/* bseg_close.c */
-int bseg_close(BSEG *);
-/* bseg_get.c */
-int bseg_get(BSEG *, CELL *, int, int);
-/* bseg_open.c */
-int bseg_open(BSEG *, int, int, int);
-/* bseg_put.c */
-int bseg_put(BSEG *, CELL *, int, int);
-/* bseg_read.c */
-int bseg_read_cell(BSEG *, char *, char *);
-/* bseg_write.c */
-int bseg_write_cellfile(BSEG *, char *);
-/* cseg_close.c */
-int cseg_close(CSEG *);
-/* cseg_get.c */
-int cseg_get(CSEG *, int, int, CELL *);
-/* cseg_open.c */
-int cseg_open(CSEG *, int, int, int);
-/* cseg_put.c */
-int cseg_put(CSEG *, int, int, CELL);
-/* cseg_read.c */
-int cseg_read_cell(CSEG *, char *, char *);
-/* cseg_write.c */
-int cseg_write_cellfile(CSEG *, char *);
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_close.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_close.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_close.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,19 +0,0 @@
-#include <grass/gis.h>
-#include <unistd.h>
-#include "cseg.h"
-int cseg_close(CSEG * cseg)
-    segment_release(&(cseg->seg));
-    close(cseg->fd);
-    unlink(cseg->filename);
-    if (cseg->name) {
-	G_free(cseg->name);
-	cseg->name = NULL;
-    if (cseg->mapset) {
-	G_free(cseg->mapset);
-	cseg->mapset = NULL;
-    return 0;
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_get.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_get.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_get.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,11 +0,0 @@
-#include "cseg.h"
-int cseg_get(CSEG * cseg, int row, int col, CELL * value)
-    if (segment_get(&(cseg->seg), value, row, col) < 0) {
-	G_warning("cseg_get(): could not read segment file");
-	return -1;
-    return 0;
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_open.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_open.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_open.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,60 +0,0 @@
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include "cseg.h"
-int cseg_open(CSEG * cseg, int srows, int scols, int nsegs_in_memory)
-    char *filename;
-    int errflag;
-    int fd;
-    cseg->filename = NULL;
-    cseg->fd = -1;
-    filename = G_tempfile();
-    if (-1 == (fd = creat(filename, 0666))) {
-	G_warning("cseg_open(): unable to create segment file");
-	return -2;
-    if (0 >
-	(errflag =
-	 segment_format(fd, G_window_rows(), G_window_cols(), srows, scols,
-			sizeof(CELL)))) {
-	close(fd);
-	unlink(filename);
-	if (errflag == -1) {
-	    G_warning("cseg_open(): could not write segment file");
-	    return -1;
-	else {
-	    G_warning("cseg_open(): illegal configuration parameter(s)");
-	    return -3;
-    close(fd);
-    if (-1 == (fd = open(filename, 2))) {
-	unlink(filename);
-	G_warning("cseg_open(): unable to re-open segment file");
-	return -4;
-    if (0 > (errflag = segment_init(&(cseg->seg), fd, nsegs_in_memory))) {
-	close(fd);
-	unlink(filename);
-	    G_warning("cseg_open(): could not read segment file");
-	    return -5;
-	else {
-	    G_warning("cseg_open(): out of memory");
-	    return -6;
-    cseg->filename = filename;
-    cseg->fd = fd;
-    return 0;
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_put.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_put.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_put.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,11 +0,0 @@
-#include "cseg.h"
-int cseg_put(CSEG * cseg, int row, int col, CELL value)
-    if (segment_put(&(cseg->seg), &value, row, col) < 0) {
-	G_warning("cseg_put(): could not write segment file");
-	return -1;
-    return 0;
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_read.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_read.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_read.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,51 +0,0 @@
-#include "cseg.h"
-static char *me = "cseg_read_cell";
-int cseg_read_cell(CSEG * cseg, char *map_name, char *mapset)
-    int row, nrows;
-    int map_fd;
-    char msg[100];
-    CELL *buffer;
-    if ((map_fd = G_open_cell_old(map_name, mapset)) < 0) {
-	sprintf(msg, "%s(): unable to open file [%s] in [%s]",
-		me, map_name, mapset);
-	G_warning(msg);
-	return -3;
-    nrows = G_window_rows();
-    buffer = G_allocate_cell_buf();
-    for (row = 0; row < nrows; row++) {
-	if (G_get_map_row(map_fd, buffer, row) < 0) {
-	    G_free(buffer);
-	    G_close_cell(map_fd);
-	    sprintf(msg, "%s(): unable to read file [%s] in [%s]",
-	    G_warning(msg);
-	    return -2;
-	if (segment_put_row(&(cseg->seg), buffer, row) < 0) {
-	    G_free(buffer);
-	    sprintf(msg, "%s(): unable to segment put row for [%s] in [%s]",
-	    G_warning(msg);
-	    return (-1);
-    G_free(buffer);
-    cseg->name = G_store(map_name);
-    cseg->mapset = G_store(mapset);
-    return 0;
Deleted: grass/branches/develbranch_6/raster/r.surf.contour/cseg_write.c
--- grass/branches/develbranch_6/raster/r.surf.contour/cseg_write.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/cseg_write.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,36 +0,0 @@
-#include "cseg.h"
-static char *me = "cseg_write_cell";
-int cseg_write_cellfile(CSEG * cseg, char *map_name)
-    int map_fd;
-    int row, nrows;
-    char msg[100];
-    CELL *buffer;
-    map_fd = G_open_cell_new(map_name);
-    if (map_fd < 0) {
-	sprintf(msg, "%s(): unable to open new map layer [%s]", me, map_name);
-	G_warning(msg);
-	return -1;
-	segment_get_row(&(cseg->seg), buffer, row);
-	if (G_put_raster_row(map_fd, buffer, CELL_TYPE) < 0) {
-	    G_free(buffer);
-	    G_unopen_cell(map_fd);
-	    sprintf(msg,
-		    "%s(): unable to write new map layer [%s], row %d",
-		    me, map_name, row);
-	    G_warning(msg);
-	    return -2;
-    G_free(buffer);
-    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_close.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_close.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_close.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_close.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,19 @@
+#include <grass/gis.h>
+#include <unistd.h>
+#include "seg.h"
+int dseg_close(DSEG * dseg)
+    segment_release(&(dseg->seg));
+    close(dseg->fd);
+    unlink(dseg->filename);
+    if (dseg->name) {
+	G_free(dseg->name);
+	dseg->name = NULL;
+    if (dseg->mapset) {
+	G_free(dseg->mapset);
+	dseg->mapset = NULL;
+    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_get.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_get.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_get.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_get.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,11 @@
+#include "seg.h"
+int dseg_get(DSEG * dseg, int row, int col, DCELL * value)
+    if (segment_get(&(dseg->seg), value, row, col) < 0) {
+	G_warning("dseg_get(): could not read segment file");
+	return -1;
+    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_open.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_open.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_open.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_open.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,60 @@
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include "seg.h"
+int dseg_open(DSEG * dseg, int srows, int scols, int nsegs_in_memory)
+    char *filename;
+    int errflag;
+    int fd;
+    dseg->filename = NULL;
+    dseg->fd = -1;
+    filename = G_tempfile();
+    if (-1 == (fd = creat(filename, 0666))) {
+	G_warning("dseg_open(): unable to create segment file");
+	return -2;
+    if (0 >
+	(errflag =
+	 segment_format(fd, G_window_rows(), G_window_cols(), srows, scols,
+			sizeof(DCELL)))) {
+	close(fd);
+	unlink(filename);
+	if (errflag == -1) {
+	    G_warning("dseg_open(): could not write segment file");
+	    return -1;
+	else {
+	    G_warning("dseg_open(): illegal configuration parameter(s)");
+	    return -3;
+    close(fd);
+    if (-1 == (fd = open(filename, 2))) {
+	unlink(filename);
+	G_warning("dseg_open(): unable to re-open segment file");
+	return -4;
+    if (0 > (errflag = segment_init(&(dseg->seg), fd, nsegs_in_memory))) {
+	close(fd);
+	unlink(filename);
+	    G_warning("cseg_open(): could not read segment file");
+	    return -5;
+	else {
+	    G_warning("cseg_open(): out of memory");
+	    return -6;
+    dseg->filename = filename;
+    dseg->fd = fd;
+    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_put.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_put.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_put.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_put.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,11 @@
+#include "seg.h"
+int dseg_put(DSEG * dseg, int row, int col, DCELL value)
+    if (segment_put(&(dseg->seg), &value, row, col) < 0) {
+	G_warning("dseg_put(): could not write segment file");
+	return -1;
+    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_read.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_read.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_read.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_read.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,51 @@
+#include "seg.h"
+static char *me = "dseg_read_cell";
+int dseg_read_cell(DSEG * dseg, char *map_name, char *mapset)
+    int row, nrows;
+    int map_fd;
+    char msg[100];
+    DCELL *buffer;
+    if ((map_fd = G_open_cell_old(map_name, mapset)) < 0) {
+	sprintf(msg, "%s(): unable to open file [%s] in [%s]",
+		me, map_name, mapset);
+	G_warning(msg);
+	return -3;
+    nrows = G_window_rows();
+    buffer = G_allocate_d_raster_buf();
+    for (row = 0; row < nrows; row++) {
+	if (G_get_d_raster_row(map_fd, buffer, row) < 0) {
+	    G_free(buffer);
+	    G_close_cell(map_fd);
+	    sprintf(msg, "%s(): unable to read file [%s] in [%s]",
+	    G_warning(msg);
+	    return -2;
+	if (segment_put_row(&(dseg->seg), buffer, row) < 0) {
+	    G_free(buffer);
+	    sprintf(msg, "%s(): unable to segment put row for [%s] in [%s]",
+	    G_warning(msg);
+	    return (-1);
+    G_free(buffer);
+    dseg->name = G_store(map_name);
+    dseg->mapset = G_store(mapset);
+    return 0;
Copied: grass/branches/develbranch_6/raster/r.surf.contour/dseg_write.c (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg_write.c)
--- grass/branches/develbranch_6/raster/r.surf.contour/dseg_write.c	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/dseg_write.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,36 @@
+#include "seg.h"
+static char *me = "dseg_write_cell";
+int dseg_write_cellfile(DSEG * dseg, char *map_name)
+    int map_fd;
+    int row, nrows;
+    char msg[100];
+    DCELL *buffer;
+    map_fd = G_open_raster_new(map_name, DCELL_TYPE);
+    if (map_fd < 0) {
+	sprintf(msg, "%s(): unable to open new map layer [%s]", me, map_name);
+	G_warning(msg);
+	return -1;
+	segment_get_row(&(dseg->seg), buffer, row);
+	if (G_put_raster_row(map_fd, buffer, DCELL_TYPE) < 0) {
+	    G_free(buffer);
+	    G_unopen_cell(map_fd);
+	    sprintf(msg,
+		    "%s(): unable to write new map layer [%s], row %d",
+		    me, map_name, row);
+	    G_warning(msg);
+	    return -2;
+    G_free(buffer);
+    return 0;
Modified: grass/branches/develbranch_6/raster/r.surf.contour/find_con.c
--- grass/branches/develbranch_6/raster/r.surf.contour/find_con.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/find_con.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -1,16 +1,17 @@
 #include <math.h>
 #include "contour.h"
-int find_con_slow(int r, int c, double *d1, double *d2, CELL * con1,
-		  CELL * con2)
+int find_con_slow(int r, int c, double *d1, double *d2, DCELL * con1,
+		  DCELL * con2)
     int ct, low_ct, node_ct;
     int rr, cc, dor, doc;
     double dd, shortest;
-    CELL value;
+    DCELL value;
+    char mask_value;
-    *con1 = 0;
-    *con2 = 0;
+    G_set_d_null_value(con1, 1);
+    G_set_d_null_value(con2, 1);
     *d1 = *d2 = 1.0;
     shortest = nrows * ncols;
     for (rr = minr; rr <= maxr; rr++) {
@@ -43,13 +44,13 @@
 	cc = zero[ct].c;
 	dor = ABS(rr - r);
 	doc = ABS(cc - c);
-	bseg_get(&bmask, &value, rr, cc);
-	if (!value && rr >= 0 && cc >= 0 && rr < nrows && cc < ncols
+	bseg_get(&bmask, &mask_value, rr, cc);
+	if (!mask_value && rr >= 0 && cc >= 0 && rr < nrows && cc < ncols
 	    && zero[ct].d < shortest) {
-	    cseg_get(&con, rr, cc, &value);
-	    if (value == 0)
+	    dseg_get(&con, rr, cc, &value);
+	    if (G_is_d_null_value(&value))
 		zero = addpts_slow(zero, r, c, rr, cc, &node_ct);
-	    else if (*con1 == 0) {
+	    else if (G_is_d_null_value(con1)) {
 		*con1 = value;
 		*d1 = MIN(dor, doc) * 1.414 + ABS(dor - doc);
 		shortest = *d1 * 2.0 * i_val_l_f;
@@ -61,7 +62,7 @@
 		    shortest = dd * 2.0 * i_val_l_f;
-	    else if (*con2 == 0) {
+	    else if (G_is_d_null_value(con2)) {
 		*con2 = value;
 		*d2 = MIN(dor, doc) * 1.414 + ABS(dor - doc);
 		shortest = *d2;
@@ -74,15 +75,15 @@
-int find_con(int r, int c, double *d1, double *d2, CELL * con1, CELL * con2)
+int find_con(int r, int c, double *d1, double *d2, DCELL * con1, DCELL * con2)
-    CELL value;
+    DCELL value;
-    *con1 = 0;
-    *con2 = 0;
     *d1 = *d2 = 1.0;
@@ -114,10 +115,10 @@
 	doc = ABS(cc - c);
 	if (rr >= 0 && cc >= 0 && rr < nrows && cc < ncols
 	    && zero[ct].d < shortest && !flag_get(mask, rr, cc)) {
-	    if (value == 0)
 		zero = addpts(zero, r, c, rr, cc, &node_ct);
 		*con1 = value;
@@ -129,7 +130,7 @@
 		*con2 = value;
 		shortest = *d2;
Modified: grass/branches/develbranch_6/raster/r.surf.contour/main.c
--- grass/branches/develbranch_6/raster/r.surf.contour/main.c	2010-09-21 06:54:54 UTC (rev 43551)
+++ grass/branches/develbranch_6/raster/r.surf.contour/main.c	2010-09-21 07:15:48 UTC (rev 43552)
@@ -32,13 +32,14 @@
 int main(int argc, char *argv[])
     int r, c;
-    CELL con1, con2;
+    DCELL con1, con2;
     double d1, d2;
-    CELL *alt_row;
+    DCELL *alt_row;
     char *con_name, *alt_name, *con_mapset;
     int file_fd;
-    int fast_mode;
-    CELL value;
+    int fast_mode, n_segments, s_size;
+    DCELL value;
+    char mask_value;
     struct History history;
     struct GModule *module;
     struct Flag *flag1, *flag_slow;
@@ -97,33 +98,42 @@
     ncols = G_window_cols();
     i_val_l_f = nrows + ncols;
-    cseg_open(&con, 512, 512, 16);
-    cseg_read_cell(&con, con_name, con_mapset);
-    alt_row = (CELL *) G_malloc(ncols * sizeof(CELL));
+    s_size = 128;
+    n_segments = nrows / s_size + (nrows % s_size > 0) * s_size +
+                 ncols / s_size + (ncols % s_size > 0) * s_size;
+    /* limit memory consumption to about 100 MB */
+    if (n_segments > 800)
+	n_segments = 800;
+    G_debug(0, "n_segments: %d", n_segments);
+    dseg_open(&con, s_size, s_size, n_segments);
+    dseg_read_cell(&con, con_name, con_mapset);
+    alt_row = (DCELL *) G_malloc(ncols * sizeof(DCELL));
     if (fast_mode) {
 	seen = flag_create(nrows, ncols);
 	mask = flag_create(nrows, ncols);
     else {
-	bseg_open(&bseen, 64, 64, 16);
-	bseg_open(&bmask, 64, 64, 16);
+	bseg_open(&bseen, s_size, s_size, n_segments);
+	bseg_open(&bmask, s_size, s_size, n_segments);
     if (NULL != G_find_file("cell", "MASK", G_mapset())) {
 	if ((file_fd = G_open_cell_old("MASK", G_mapset())) < 0)
 	    G_fatal_error("Unable to open MASK");
 	if (fast_mode) {
 	    for (r = 0; r < nrows; r++) {
-		G_get_map_row_nomask(file_fd, alt_row, r);
+		G_get_d_raster_row_nomask(file_fd, alt_row, r);
 		for (c = 0; c < ncols; c++)
-		    if (!alt_row[c])
+		    if (G_is_d_null_value(&(alt_row[c])) || alt_row[c] == 0)
 			FLAG_SET(mask, r, c);
+		    else
+			FLAG_UNSET(mask, r, c);
 	else {
-		    if (!alt_row[c])
 			bseg_put(&bmask, &off, r, c);
@@ -134,23 +144,24 @@
     maxc = ncols - 1;
     maxr = nrows - 1;
     array_size = INIT_AR;
-    file_fd = G_open_cell_new(alt_name);
+    file_fd = G_open_raster_new(alt_name, DCELL_TYPE);
     if (!file_fd)
 	G_fatal_error("Unable to open output map");
 	G_percent(r, nrows, 1);
+	G_set_d_null_value(alt_row, ncols);
 	for (c = 0; c < ncols; c++) {
 	    if (fast_mode) {
 		if (FLAG_GET(mask, r, c))
 		    continue;
 	    else {
-		bseg_get(&bmask, &value, r, c);
-		if (value)
+		bseg_get(&bmask, &mask_value, r, c);
+		if (mask_value)
 		    continue;
-	    cseg_get(&con, r, c, &value);
-	    if (value != 0) {
+	    dseg_get(&con, r, c, &value);
+	    if (!G_is_d_null_value(&value)) {
 		alt_row[c] = value;
 		continue;
@@ -159,15 +170,15 @@
 	    else
 		find_con_slow(r, c, &d1, &d2, &con1, &con2);
 	    if (con2 > 0)
-		alt_row[c] = (CELL) (d2 * con1 / (d1 + d2) +
-				     d1 * con2 / (d1 + d2) + 0.5);
+		alt_row[c] = d2 * con1 / (d1 + d2) +
+			     d1 * con2 / (d1 + d2);
 	    else
 		alt_row[c] = con1;
-	G_put_raster_row(file_fd, alt_row, CELL_TYPE);
+	G_put_raster_row(file_fd, alt_row, DCELL_TYPE);
-    cseg_close(&con);
+    dseg_close(&con);
     if (fast_mode) {
 	flag_destroy(seen);
 	flag_destroy(mask);
Copied: grass/branches/develbranch_6/raster/r.surf.contour/seg.h (from rev 43540, grass/branches/develbranch_6/raster/r.surf.contour/cseg.h)
--- grass/branches/develbranch_6/raster/r.surf.contour/seg.h	                        (rev 0)
+++ grass/branches/develbranch_6/raster/r.surf.contour/seg.h	2010-09-21 07:15:48 UTC (rev 43552)
@@ -0,0 +1,55 @@
+#include <grass/segment.h>
+#define DSEG struct _d_s_e_g_
+DSEG {
+    SEGMENT seg;		/* segment structure */
+    int fd;			/* fd for reading/writing segment file */
+    char *filename;		/* name of segment file */
+    char *name;			/* raster map read into segment file */
+    char *mapset;
+#define BSEG struct _b_s_e_g_
+BSEG {
+    char *mapset;
+/* bseg_close.c */
+int bseg_close(BSEG *);
+/* bseg_get.c */
+int bseg_get(BSEG *, char *, int, int);
+/* bseg_open.c */
+int bseg_open(BSEG *, int, int, int);
+/* bseg_put.c */
+int bseg_put(BSEG *, char *, int, int);
+/* bseg_read.c */
+int bseg_read_cell(BSEG *, char *, char *);
+/* bseg_write.c */
+int bseg_write_cellfile(BSEG *, char *);
+/* dseg_close.c */
+int dseg_close(DSEG *);
+/* dseg_get.c */
+int dseg_get(DSEG *, int, int, DCELL *);
+/* dseg_open.c */
+int dseg_open(DSEG *, int, int, int);
+/* dseg_put.c */
+int dseg_put(DSEG *, int, int, DCELL);
+/* dseg_read.c */
+int dseg_read_cell(DSEG *, char *, char *);
+/* dseg_write.c */
+int dseg_write_cellfile(DSEG *, char *);
