[GRASS-SVN] r43559 - grass/branches/develbranch_6/raster/r.proj.seg
svn_grass at osgeo.org
Tue Sep 21 06:26:34 EDT 2010
Author: neteler
Date: 2010-09-21 10:26:34 +0000 (Tue, 21 Sep 2010)
New Revision: 43559
grass/branches/develbranch_6/raster/r.proj.seg/description.html
typo fixed
Modified: grass/branches/develbranch_6/raster/r.proj.seg/description.html
--- grass/branches/develbranch_6/raster/r.proj.seg/description.html 2010-09-21 09:21:37 UTC (rev 43558)
+++ grass/branches/develbranch_6/raster/r.proj.seg/description.html 2010-09-21 10:26:34 UTC (rev 43559)
@@ -147,7 +147,7 @@
<p>
A simple way to do this is to check the projected bounds of the input map
-inthe current location's projection using the <b>-p</b> flag. The <b>-g</b>
+in the current location's projection using the <b>-p</b> flag. The <b>-g</b>
flag reports the same thing, but in a form which can be directly cut and
pasted into a <em>g.region</em> command. After setting the region in that
way you might check the cell resolution with "<em>g.region -p</em>" then
