[GRASS-SVN] r43561 -
grass/branches/releasebranch_6_4/raster/r.proj.seg
svn_grass at osgeo.org
Tue Sep 21 06:31:42 EDT 2010
Author: neteler
Date: 2010-09-21 10:31:42 +0000 (Tue, 21 Sep 2010)
New Revision: 43561
grass/branches/releasebranch_6_4/raster/r.proj.seg/description.html
backport: manual cosmetics + example
Modified: grass/branches/releasebranch_6_4/raster/r.proj.seg/description.html
--- grass/branches/releasebranch_6_4/raster/r.proj.seg/description.html 2010-09-21 10:27:06 UTC (rev 43560)
+++ grass/branches/releasebranch_6_4/raster/r.proj.seg/description.html 2010-09-21 10:31:42 UTC (rev 43561)
@@ -9,7 +9,7 @@
<h3>Introduction</h3>
-<h4>Map projections</h4>
+<h5>Map projections</h5>
Map projections are a method of representing information from a
curved surface (usually a spheroid) in two dimensions, typically to allow
@@ -34,7 +34,7 @@
of projecting coordinates from a geographic reference frame
(latitude-longitude) into a projected cartesian reference frame (eg metres)
is governed by these equations. Inverse projections can also be achieved.
-The public-domain Unix software package <i>PROJ</i> [1] has been designed to
+The public-domain Unix software package <i>PROJ.4</i> [1] has been designed to
perform these transformations, and the user's manual contains a detailed
description of over 100 useful projections. This also includes a
programmers library of the projection methods to support other software
@@ -69,7 +69,9 @@
<i><a href="http://proj.maptools.org/">cs2cs</a></i> [1]. This is an easy
method for converting an ASCII file containing a list of coordinate points,
since there is no topology to be preserved and <i>cs2cs</i> can be used to
-process simple lists using a one-line command.
+process simple lists using a one-line command. The <em>m.proj</em> module
+provides a handy front end to <tt>cs2cs</tt>.
<p>
The format of files containing vector maps with <b>lines</b> and <b>arcs</b> is
generally more complex, as parts of the data stored in the files will describe
@@ -109,7 +111,7 @@
with categorical data, since the cell values will be altered.
<p>
If nearest neighbor assignment is used, the output map has the same raster
-format as the input map. If any of the both interpolations is used, the
+format as the input map. If any of the interpolations is used, the
output map is written as floating point.
<p>
@@ -129,11 +131,13 @@
<em>PROJ.4</em> co-ordinate system translation library.
</p>
<h2>NOTES</h2>
To avoid excessive time consumption when reprojecting a map the region and
resolution of the target location should be set appropriately beforehand.
-A simple way to do this is to generate a vector "box" map of the region in
+A simple way to do this is to generate a vector "box" map of the region in
the source location using <em><a href="v.in.region.html">v.in.region</a></em>.
This "box" map is then reprojected into the target location with
<em><a href="v.proj.html">v.proj</a></em>.
@@ -150,16 +154,45 @@
impossible) to find in projections other than latitude-longitude so results
may be odd with trimming.
+<h2>EXAMPLES</h2>
+<h3>v.in.region method</h3>
+<div class="code"><pre>
+# In the source location, use v.in.region to generate a bounding box around the
+# region of interest:
+v.in.region output=bounds type=area
+# Now switch to the target location and import the vector bounding box
+# (you can run v.proj -l to get a list of vector maps in the source location):
+v.proj input=bounds location=source_location_name output=bounds_reprojected
+# Set the region in the target location with that of the newly-imported vector
+# bounds map, and align the resolution to the desired cell resolution of the
+# final, reprojected raster map:
+g.region vect=bounds_reprojected res=5 -a
+# Now reproject the raster into the target location
+r.proj input=elevation.dem output=elevation.dem.reproj \
+location=source_location_name mapset=PERMANENT res=5 method=cubic
+</pre></div>
<h2>REFERENCES</h2>
-[1] Evenden, G.I. (1990) <a href="http://proj.maptools.org/">Cartographic projection procedures for
+[1] Evenden, G.I. (1990) <a href="http://proj.osgeo.org">Cartographic projection procedures for
the UNIX environment - a user's manual.</a> USGS Open-File Report 90-284 (OF90-284.pdf)
See also there: Interim Report and 2nd Interim Report on Release 4, Evenden 1994).
<p>
Richards, John A. (1993), Remote Sensing Digital Image Analysis,
Springer-Verlag, Berlin, 2nd edition.
<p>
-<a href=http://proj.maptools.org/>PROJ.4</a>: Projection/datum support library.
+<a href="http://proj.osgeo.org">PROJ.4</a>: Projection/datum support library.
<p>
<b>Further reading</b>
<ul>
@@ -169,6 +202,7 @@
<li> <a href="http://www.crs-geo.eu">Information and Service System for European Coordinate Reference Systems - CRS</a>
</ul>
<h2>SEE ALSO</h2>
<em>
@@ -176,6 +210,7 @@
<a href="g.proj.html">g.proj</a>,
<a href="g.setproj.html">g.setproj</a>,
<a href="i.rectify.html">i.rectify</a>,
+<a href="m.proj.html">m.proj</a>,
<a href="r.support.html">r.support</a>,
<a href="r.stats.html">r.stats</a>,
<a href="v.proj.html">v.proj</a>,
@@ -185,6 +220,7 @@
The 'gdalwarp' and 'gdal_translate' utilities are available from the
<a href="http://www.gdal.org">GDAL</a> project.
<h2>AUTHORS</h2>
Martin Schroeder, University of Heidelberg, Germany<p>
@@ -194,4 +230,5 @@
<p>
Datum tranformation support and cleanup by Paul Kelly
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
