[GRASS-SVN] r43565 -
grass/branches/releasebranch_6_4/raster/r.horizon
svn_grass at osgeo.org
Tue Sep 21 06:46:11 EDT 2010
Author: neteler
Date: 2010-09-21 10:46:11 +0000 (Tue, 21 Sep 2010)
New Revision: 43565
grass/branches/releasebranch_6_4/raster/r.horizon/description.html
grass/branches/releasebranch_6_4/raster/r.horizon/main.c
backport: write out metadata; whitespace/msg cleanup
Modified: grass/branches/releasebranch_6_4/raster/r.horizon/description.html
--- grass/branches/releasebranch_6_4/raster/r.horizon/description.html 2010-09-21 10:44:09 UTC (rev 43564)
+++ grass/branches/releasebranch_6_4/raster/r.horizon/description.html 2010-09-21 10:46:11 UTC (rev 43565)
@@ -26,12 +26,14 @@
LOCATION with x,y coordinate system, where this correction is
not applied.
<H3>Flags:</H3>
<dl>
<dt><B>-d</B>
<dd>Output horizon height in degrees (the default is radians)</dl>
</dl>
<H3>Input parameters:</H3>
<P>The <I>elevin</I> parameter is an input elevation raster map. If
the buffer options are used (see below), this raster should extend
@@ -97,6 +99,7 @@
raster coordinates.
</p>
<H2>METHOD</H2>
<P>The calculation method is based on the method used in <B>r.sun</B>
to calculate shadows. It starts at a very shallow angle and walks
@@ -114,18 +117,21 @@
cardinal directions caused by the projection (see above).
</P>
<H2>EXAMPLE</H2>
Single point mode:
<div class="code"><pre>
-r.horizon elevin=DEM horizonstep=30 direction=15 bufferzone=200 coord=47.302,7.365 dist=0.7 > horizon.out
+r.horizon elevin=DEM horizonstep=30 direction=15 bufferzone=200 \
+ coord=47.302,7.365 dist=0.7 > horizon.out
</pre></div>
Raster map mode (for r.sun):
# we put a bufferzone of 10% of maxdistance around the study area
-r.horizon elevin=DEM horizonstep=30 bufferzone=200 horizon=horangle dist=0.7 maxdistance=2000
+r.horizon elevin=DEM horizonstep=30 bufferzone=200 horizon=horangle \
+ dist=0.7 maxdistance=2000
</pre></div>
@@ -133,8 +139,10 @@
<em>
<A HREF="r.sun.html">r.sun</A>,
+<A HREF="r.sunmask.html">r.sunmask</A>,
<A HREF="r.los.html">r.los</A></em>
<H2>REFERENCES</H2>
<P>Hofierka J., 1997. Direct solar radiation modelling within an
open GIS environment. Proceedings of JEC-GI'97 conference in Vienna,
@@ -155,6 +163,7 @@
Photovoltaic Assessments. <A HREF="http://www.blackwellpublishing.com/toc.asp?ref=1361-1682">Transactions
in GIS</A>, 8(2), 175-190</P>
<H2>AUTHORS</H2>
Thomas Huld, Joint Research Centre of
the European Commission, Ispra, Italy
@@ -174,4 +183,5 @@
<A HREF="mailto:Marcel.Suri at jrc.it">Marcel.Suri at jrc.it</A>
</ADDRESS>
-<P><I>Last changed: $Date$</I>
+<P>
+<I>Last changed: $Date$</I>
Modified: grass/branches/releasebranch_6_4/raster/r.horizon/main.c
--- grass/branches/releasebranch_6_4/raster/r.horizon/main.c 2010-09-21 10:44:09 UTC (rev 43564)
+++ grass/branches/releasebranch_6_4/raster/r.horizon/main.c 2010-09-21 10:46:11 UTC (rev 43565)
@@ -49,7 +49,7 @@
#define SMALL 1.e-20
#define EPS 1.e-4
#define DIST "1.0"
-#define DEGREEINMETERS 111120.
+#define DEGREEINMETERS 111120. /* 1852m/nm * 60nm/degree = 111120 m/deg */
#define TANMINANGLE 0.008727 /* tan of minimum horizon angle (0.5 deg) */
#define AMAX1(arg1, arg2) ((arg1) >= (arg2) ? (arg1) : (arg2))
@@ -71,7 +71,7 @@
char *horizon = NULL;
char *mapset = NULL;
char *per;
-char shad_filename[256];
+char shad_filename[GNAME_MAX];
struct Cell_head cellhd;
struct Key_value *in_proj_info, *in_unit_info;
@@ -108,7 +108,7 @@
int ip, jp, ip100, jp100;
int n, m, m100, n100;
-int degreeOutput = 0;
+int degreeOutput = FALSE;
float **z, **z100, **horizon_raster;
double stepx, stepy, stepxhalf, stepyhalf, stepxy, xp, yp, op, dp, xg0, xx0,
yg0, yy0, deltx, delty;
@@ -139,9 +139,10 @@
mode = val;
-int ll_correction = 0;
+int ll_correction = FALSE;
double coslatsq;
+/* use G_distance() instead ??!?! */
double distance(double x1, double x2, double y1, double y2)
if (ll_correction) {
@@ -463,10 +464,9 @@
deltx = fabs(new_cellhd.east - new_cellhd.west);
delty = fabs(new_cellhd.north - new_cellhd.south);
- n /*n_cols */ = new_cellhd.cols;
- m /*n_rows */ = new_cellhd.rows;
- /*G_debug(3,"%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax);
+ n /* n_cols */ = new_cellhd.cols;
+ m /* n_rows */ = new_cellhd.rows;
+ /* G_debug(3,"%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax); */
n100 = ceil(n / 100.);
m100 = ceil(m / 100.);
@@ -498,8 +498,6 @@
G_fatal_error(_("Unable to set up lat/long projection parameters"));
/**********end of parser - ******************************/
@@ -515,7 +513,7 @@
exit(EXIT_FAILURE);
- /*sorry, I've moved OUTGR to calculate() - into the loop */
+ /* sorry, I've moved OUTGR() to calculate() - into the loop */
/* if(isMode(WHOLE_RASTER))
OUTGR(cellhd.rows,cellhd.cols);
@@ -529,6 +527,7 @@
/**********************end of main.c*****************/
int INPUT(void)
FCELL *cell1;
@@ -569,7 +568,7 @@
G_close_cell(fd1);
- /*create low resolution array 100 */
+ /* create low resolution array 100 */
for (i = 0; i < m100; i++) {
lmax = (i + 1) * 100;
if (lmax > m)
@@ -591,11 +590,10 @@
- /*find max Z */
+ /* find max Z */
for (i = 0; i < m; i++) {
for (j = 0; j < n; j++) {
zmax = amax1(zmax, z[i][j]);
@@ -643,13 +641,10 @@
G_put_f_raster_row(fd1, cell1);
} /* End loop over rows. */
G_close_cell(fd1);
return 1;
@@ -761,7 +756,6 @@
double calculate_shadow_onedirection(double shadow_angle)
shadow_angle = horizon_height();
return shadow_angle;
@@ -970,20 +964,20 @@
mindel = min(delx, dely);
- /*G_debug(3,"%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);*/
+ /* G_debug(3,"%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);*/
yy0 = yy0 + (mindel * stepsinangle);
xx0 = xx0 + (mindel * stepcosangle);
- /*G_debug(3," %lf %lf\n",xx0,yy0);*/
+ /* G_debug(3," %lf %lf\n",xx0,yy0);*/
return (3);
else {
- return (1); /*change of low res array - new cell is reaching limit for high resolution processing */
+ return (1); /* change of low res array - new cell is reaching limit for high resolution processing */
else {
- return (1); /*no change of low res array */
+ return (1); /* no change of low res array */
@@ -1003,9 +997,8 @@
if (succes != 1) {
break;
- curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
+ /* curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS)); */
curvature_diff = 0.5 * length * length * invEarth;
z2 = z_orig + curvature_diff + length * tanh0;
@@ -1050,8 +1043,8 @@
double delt_dist;
char formatString[10];
+ char msg_buff[256];
int hor_row_start = buffer_s;
int hor_row_end = m - buffer_n;
@@ -1068,7 +1061,7 @@
yindex = (int)((ycoord - ymin) / stepy);
if ((G_projection() == PROJECTION_LL)) {
- ll_correction = 1;
+ ll_correction = TRUE;
@@ -1116,9 +1109,8 @@
horizon_raster[j][i] = 0.;
- definition of horizon angle in loop
+ /* definition of horizon angle in loop */
if (step == 0.0) {
dfr_rad = 0;
arrayNumInt = 1;
@@ -1168,11 +1160,10 @@
if ((G_projection() != PROJECTION_LL)) {
- if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+ if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0)
G_fatal_error("Error in pj_do_proj");
latitude *= deg2rad;
longitude *= deg2rad;
@@ -1182,16 +1173,15 @@
twopi) ? inputAngle - twopi : inputAngle;
- delt_lat = -0.0001 * cos(inputAngle); /* Arbitrary small distance in latitude */
+ delt_lat = -0.0001 * cos(inputAngle); /* Arbitrary small distance in latitude */
delt_lon = 0.0001 * sin(inputAngle) / cos(latitude);
latitude = (latitude + delt_lat) * rad2deg;
longitude = (longitude + delt_lon) * rad2deg;
- if (pj_do_proj(&longitude, &latitude, &oproj, &iproj) < 0) {
+ if (pj_do_proj(&longitude, &latitude, &oproj, &iproj) < 0)
delt_east = longitude - xp;
@@ -1227,11 +1217,12 @@
maxlength =
(maxlength <
fixedMaxLength) ? maxlength : fixedMaxLength;
if (z_orig != UNDEFZ) {
- /*G_debug(3,"**************new line %d %d\n", i, j);
+ /* G_debug(3,"**************new line %d %d\n", i, j); */
if (degreeOutput) {
shadow_angle *= rad2deg;
@@ -1246,7 +1237,7 @@
horizon_raster[j - buffer_s][i - buffer_w] =
shadow_angle;
- } /* undefs */
+ } /* undefs */
@@ -1258,19 +1249,38 @@
- /*return back the buffered region */
+ /* return back the buffered region */
if (bufferZone > 0.) {
if (G_set_window(&new_cellhd) == -1)
exit(0);
+ /* write metadata */
G_short_history(shad_filename, "raster", &history);
+ sprintf(msg_buff,
+ "Angular height of terrain horizon, map %01d of %01d",
+ (k + 1), arrayNumInt);
+ G_put_cell_title(shad_filename, msg_buff);
+ if (degreeOutput)
+ G_write_raster_units(shad_filename, "degrees");
+ else
+ G_write_raster_units(shad_filename, "radians");
G_command_history(&history);
- G_write_history(shad_filename, &history);
+ /* insert a blank line */
+ history.edhist[history.edlinecnt][0] = '\0';
+ history.edlinecnt++;
+ sprintf(msg_buff,
+ "Horizon view from azimuth angle %.2f degrees CCW from East",
+ angle * rad2deg);
+ strcpy(history.edhist[history.edlinecnt], msg_buff);
+ G_write_history(shad_filename, &history);
