[GRASS-SVN] r43573 -
	grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon
    svn_grass at osgeo.org
    Tue Sep 21 08:38:04 EDT 2010
Author: neteler
Date: 2010-09-21 12:38:04 +0000 (Tue, 21 Sep 2010)
New Revision: 43573
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/list.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c
backport: detect & bailout on error (trac #718); use G_malloc(); +new debug msg; malloc to G_malloc, whitespace; strip away config file path if it is present and if it matches the config dir
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2010-09-21 12:26:40 UTC (rev 43572)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2010-09-21 12:38:04 UTC (rev 43573)
@@ -57,6 +57,7 @@
     g = (g_areas) G_malloc(sizeof(struct generatore));
     l = (list) G_malloc(sizeof(struct lista));
     mypid = getpid();
     /* create report pipe */
     reportChannelName = G_tempfile();
     if (mkfifo(reportChannelName, 0644) == -1)
@@ -96,15 +97,23 @@
     /*open reportChannel */
     receiveChannel = open(reportChannelName, O_RDONLY, 0755);
        -----------------create area queue----------------------
+    /* strip off leading path if present */
+    char testpath[GPATH_MAX];
+    sprintf(testpath, "%s%s", G_home(), "/.r.li/history/");
+    if(strncmp(file, testpath, strlen(testpath)) == 0)
+	file += strlen(testpath);
     /* TODO: check if this path is portable */
-    sprintf(pathSetup, "%s/.r.li/history/%s", getenv("HOME"), file);
-    G_debug(1, "r.li.daemon pathSetup: %s", pathSetup);
+    sprintf(pathSetup, "%s/.r.li/history/%s", G_home(), file);
+    G_debug(1, "r.li.daemon pathSetup: [%s]", pathSetup);
     parsed = parseSetup(pathSetup, l, g, raster);
        -----------------open output file ---------------------
@@ -123,20 +132,20 @@
 	    G_fatal_error(_("Cannot create random access file"));
     else {
-	/*check if ~/.r.li/output exist */
-	sprintf(out, "%s/.r.li/", getenv("HOME"));
+	/* check if ~/.r.li/output exists */
+	sprintf(out, "%s/.r.li/", G_home());
 	doneDir = G_mkdir(out);
 	if (doneDir == -1 && errno != EEXIST)
 	    G_fatal_error(_("Cannot create %s/.r.li/ directory"),
-			  getenv("HOME"));
-	sprintf(out, "%s/.r.li/output", getenv("HOME"));
+			  G_home());
+	sprintf(out, "%s/.r.li/output", G_home());
 	    G_fatal_error(_("Cannot create %s/.r.li/output/ directory"),
-			  getenv("HOME"));
-	sprintf(out, "%s/.r.li/output/%s", getenv("HOME"), output);
-	res = open(out, O_WRONLY | O_CREAT | O_TRUNC, 0755);
+			  G_home());
+	sprintf(out, "%s/.r.li/output/%s", G_home(), output);
+	res = open(out, O_WRONLY | O_CREAT | O_TRUNC, 0644);
     i = 0;
@@ -219,7 +228,9 @@
 		/*printf("todo2 ");fflush(stdout); *//*TODO scrivere su raster */
 	i--;
 	while (j < WORKERS && donePid != child[j].pid)
 	    j++;
@@ -227,20 +238,24 @@
 	m.f.f_t.pid = mypid;
 	send(child[j].channel, &m);
 	wait(&status);
 	if (!(WIFEXITED(status)))
-	    G_message(_("r.li.worker (pid %i) exited with abnormal status %i"),
-		      donePid, status);
+	    G_warning(
+		    _("r.li.worker (pid %i) exited with abnormal status: %i"),
+		    donePid, status);
 	else
-	    G_message(_("r.li.worker (pid %i) terminated"), donePid);
+	    G_verbose_message(
+		    _("r.li.worker (pid %i) terminated successfully"),
+		    donePid);
-	/*remove pipe */
+	/* remove pipe */
 	if (close(child[j].channel) != 0)
 	    G_message(_("Cannot close %s file (PIPE)"), child[j].pipe);
 	if (unlink(child[j].pipe) != 0)
 	    G_message(_("Cannot delete %s file (PIPE)"), child[j].pipe);
-    /*kill childs without Job */
+    /* kill children without Job */
     for (i = withoutJob; i < WORKERS; i++) {
 	int status;
@@ -248,22 +263,28 @@
 	send(child[i].channel, &m);
 	wait(&status);
-		      child[i].pid, status);
+	    G_warning(
+		    child[i].pid, status);
 	else
-	    G_message(_("r.li.worker (pid %i) terminated"), child[i].pid);
-	/*remove pipe */
+		    child[i].pid);
+	/* remove pipe */
 	if (close(child[i].channel) != 0)
 	    G_message(_("Cannot close %s file (PIPE2)"), child[i].pipe);
 	if (unlink(child[i].pipe) != 0)
 	    G_message(_("Cannot delete %s file (PIPE2)"), child[i].pipe);
        --------------delete tmp files------------------
     if (parsed == MVWIN) {
 	write_raster(mv_fd, random_access, g);
 	close(random_access);
@@ -274,14 +295,16 @@
 	G_write_history(output, &history);
     if (close(receiveChannel) != 0)
 	G_message(_("Cannot close receive channel file"));
     if (unlink(reportChannelName) != 0)
 	G_message(_("Cannot delete %s file"), child[i].pipe);
     return 1;
 int parseSetup(char *path, list l, g_areas g, char *raster)
     struct stat s;
@@ -295,42 +318,46 @@
     int size;
     if (stat(path, &s) != 0)
-	G_fatal_error(_("Cannot make stat of %s configuration file"), path);
+	G_fatal_error(_("Cannot find configuration file <%s>"), path);
     size = s.st_size * sizeof(char);
     buf = G_malloc(size);
     setup = open(path, O_RDONLY, 0755);
     if (setup == -1)
 	G_fatal_error(_("Cannot read setup file"));
     letti = read(setup, buf, s.st_size);
     if (letti < s.st_size)
     token = strtok(buf, " ");
     if (strcmp("SAMPLINGFRAME", token) != 0)
-	G_fatal_error(_("Illegal configuration file"));
+	G_fatal_error(_("Unable to parse configuration file"));
     rel_x = atof(strtok(NULL, "|"));
     rel_y = atof(strtok(NULL, "|"));
     rel_rl = atof(strtok(NULL, "|"));
     rel_cl = atof(strtok(NULL, "\n"));
-    /*finding raster map */
+    /* find raster map */
     mapset = G_find_cell(raster, "");
     if (G_get_cellhd(raster, mapset, &cellhd) == -1)
 	G_fatal_error(_("Cannot read raster header file"));
-    /*calculating absolute sampling frame definition */
+    /* calculate absolute sampling frame definition */
     sf_x = (int)rint(cellhd.cols * rel_x);
     sf_y = (int)rint(cellhd.rows * rel_y);
     sf_rl = (int)rint(cellhd.rows * rel_rl);
     sf_cl = (int)rint(cellhd.cols * rel_cl);
-    /*calculating sample frame boundaries */
+    /* calculate sample frame boundaries */
     sf_n = cellhd.north - (cellhd.ns_res * sf_y);
     sf_s = sf_n - (cellhd.ns_res * sf_rl);
     sf_w = cellhd.west + (cellhd.ew_res * sf_x);
     sf_e = sf_w + (cellhd.ew_res * sf_cl);
-    /* parsing configuration file */
+    /* parse configuration file */
     token = strtok(NULL, " ");
     if (strcmp("SAMPLEAREA", token) == 0) {
@@ -344,7 +371,6 @@
 	    rel_sa_cl = atof(strtok(NULL, "\n"));
 	    if (rel_sa_x == -1.0 && rel_sa_y == -1.0) {
 		/* runtime disposition */
 		int sa_rl, sa_cl;
@@ -361,6 +387,7 @@
 		g->x = sf_x;
 		g->y = sf_y;
 		g->maskname = NULL;
 		return disposeAreas(l, g, strtok(NULL, "\n"));
 	    else {
@@ -377,10 +404,12 @@
 		aid++;
 		insertNode(l, m);
-	while ((token = strtok(NULL, " ")) != NULL &&
+	} while ((token = strtok(NULL, " ")) != NULL &&
 	       strcmp(token, "SAMPLEAREA") == 0);
 	close(setup);
 	return toReturn;
     else if (strcmp("MASKEDSAMPLEAREA", token) == 0) {
@@ -610,6 +639,7 @@
     return ERROR;
 int next_Area(int parsed, list l, g_areas g, msg * m)
     if (parsed == NORMAL) {
@@ -629,6 +659,7 @@
 int print_Output(int out, msg m)
     if (m.type != DONE)
@@ -639,6 +670,7 @@
 	sprintf(s, "RESULT %i|%f\n", m.f.f_d.aid, m.f.f_d.res);
 	len = strlen(s);
 	if (write(out, s, len) == len)
 	    return 1;
 	else
@@ -646,6 +678,7 @@
 int error_Output(int out, msg m)
     if (m.type != ERROR)
@@ -654,6 +687,7 @@
 	char s[100];
 	sprintf(s, "ERROR %i", m.f.f_d.aid);
 	if (write(out, s, strlen(s)) == strlen(s))
 	    return 1;
 	else
@@ -661,6 +695,7 @@
 int raster_Output(int fd, int aid, g_areas g, double res)
     double toPut = res;
@@ -670,11 +705,14 @@
 	G_message(_("Cannot make lseek"));
 	return -1;
     if (write(fd, &toPut, sizeof(double)) == 0)
 	return 1;
     else
 	return 0;
 int write_raster(int mv_fd, int random_access, g_areas g)
     int i = 0, j = 0, letti = 0;
@@ -686,24 +724,33 @@
     rows = g->rows;
     center = g->sf_x + ((int)g->cl / 2);
-    file_buf = malloc(cols * sizeof(double));
+    file_buf = G_malloc(cols * sizeof(double));
     lseek(random_access, 0, SEEK_SET);
     cell_buf = G_allocate_d_raster_buf();
     G_set_d_null_value(cell_buf, G_window_cols() + 1);
     for (i = 0; i < g->sf_y + ((int)g->rl / 2); i++) {
 	G_put_raster_row(mv_fd, cell_buf, DCELL_TYPE);
     for (i = 0; i < rows; i++) {
 	letti = read(random_access, file_buf, (cols * sizeof(double)));
 	if (letti == -1)
 	    G_message("%s", strerror(errno));
 	for (j = 0; j < cols; j++) {
 	    cell_buf[j + center] = file_buf[j];
     for (i = 0; i < G_window_rows() - g->sf_y - g->rows; i++)
     return 1;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/list.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/list.c	2010-09-21 12:26:40 UTC (rev 43572)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/list.c	2010-09-21 12:38:04 UTC (rev 43573)
@@ -29,11 +29,13 @@
     node new;
-    new = malloc(sizeof(node));
-    new->m = malloc(sizeof(msg));
+    new = G_malloc(sizeof(node));
+    new->m = G_malloc(sizeof(msg));
     if (new != NULL) {
 	memcpy(new->m, &mess, sizeof(msg));
 	new->next = new->prev = NULL;
 	if (l->head == NULL) {
 	    l->head = l->tail = new;
@@ -45,6 +47,7 @@
     else
 	G_message(_("Out of memory"));
     l->size++;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c	2010-09-21 12:26:40 UTC (rev 43572)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c	2010-09-21 12:38:04 UTC (rev 43573)
@@ -57,7 +57,8 @@
     fm = G_malloc(sizeof(struct fcell_memory_entry));
     dm = G_malloc(sizeof(struct dcell_memory_entry));
     pid = getpid();
-    ad = malloc(sizeof(struct area_entry));
+    ad = G_malloc(sizeof(struct area_entry));
     /* open raster map */
     fd = G_open_cell_old(raster, mapset);
@@ -65,6 +66,7 @@
 	G_message(_("CHILD[pid = %i] cannot open raster map"), pid);
 	exit(EXIT_FAILURE);
     /* read data type to allocate cache */
     data_type = G_raster_map_type(raster, mapset);
     /* calculate rows in cache */
@@ -112,6 +114,7 @@
     /* receive loop */
     receive(rec_ch, &toReceive);
     while (toReceive.type != TERM) {
 	if (toReceive.type == AREA) {
 	    aid = toReceive.f.f_ma.aid;
@@ -122,9 +125,7 @@
 	    ad->raster = raster;
 	    ad->mask = -1;
-	else {
-	    /* toReceive.type == MASKEDAREA */
+	else if (toReceive.type == MASKEDAREA) {
 	    ad->x = toReceive.f.f_ma.x;
 	    ad->y = toReceive.f.f_ma.y;
@@ -136,7 +137,7 @@
 	    ad->mask_name = mask_preprocessing(toReceive.f.f_ma.mask,
 					       raster, ad->rl, ad->cl);
 	    if (ad->mask_name == NULL) {
-		G_message(_("CHILD[pid = %i]: unable to open %s mask ... continue without!!!"),
+		G_message(_("CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"),
 			  pid, toReceive.f.f_ma.mask);
 		ad->mask = -1;
@@ -146,14 +147,15 @@
 		    erease_mask = 1;
 		ad->mask = open(ad->mask_name, O_WRONLY, 0755);
 		if (ad->mask == -1) {
+	else
+	    G_fatal_error("Program error, worker() toReceive.type=%d",
+			  toReceive.type);
 	/* memory menagement */
 	if (ad->rl > used) {
 	    /* allocate cache */
@@ -228,11 +230,16 @@
     CELL *old;
     double add_row, add_col;
-    buf = malloc(cl * sizeof(int));
+    buf = G_malloc(cl * sizeof(int));
+    G_debug(3, "daemon mask preproc: raster=[%s] mask=[%s]  rl=%d cl=%d",
+	    raster, mask, rl, cl);
     /* open raster */
     if (G_get_cellhd(raster, mapset, &cell) == -1)
 	return NULL;
     mapset = G_find_cell(mask, "");
     /* open raster */
     if (G_get_cellhd(mask, mapset, &oldcell) == -1)
@@ -240,10 +247,12 @@
     add_row = 1.0 * oldcell.rows / rl;
     add_col = 1.0 * oldcell.cols / cl;
     tmp_file = G_tempfile();
     mask_fd = open(tmp_file, O_RDWR | O_CREAT, 0755);
     old_fd = G_open_cell_old(mask, mapset);
     old = G_allocate_cell_buf();
     for (i = 0; i < rl; i++) {
 	int riga;
