[GRASS-SVN] r43577 - grass/trunk/lib/btree2
svn_grass at osgeo.org
Tue Sep 21 08:48:52 EDT 2010
Author: mmetz
Date: 2010-09-21 12:48:52 +0000 (Tue, 21 Sep 2010)
New Revision: 43577
grass/trunk/lib/btree2/rbtree.c
non-recursive tree destruction (see libavl), change towards standalone lib, eliminate obscure -O2/3 bug
Modified: grass/trunk/lib/btree2/rbtree.c
--- grass/trunk/lib/btree2/rbtree.c 2010-09-21 12:48:18 UTC (rev 43576)
+++ grass/trunk/lib/btree2/rbtree.c 2010-09-21 12:48:52 UTC (rev 43577)
@@ -34,7 +34,6 @@
#include <grass/rbtree.h>
/* internal functions */
-void rbtree_destroy2(struct RB_NODE *);
struct RB_NODE *rbtree_single(struct RB_NODE *, int);
struct RB_NODE *rbtree_double(struct RB_NODE *, int);
void *rbtree_first(struct RB_TRAV *);
@@ -48,7 +47,7 @@
struct RB_TREE *rbtree_create(rb_compare_fn *compare, size_t rb_datasize)
- struct RB_TREE *tree = G_malloc(sizeof(*tree));
+ struct RB_TREE *tree = (struct RB_TREE *)malloc(sizeof(struct RB_TREE));
if (tree == NULL) {
G_warning("RB tree: Out of memory!");
@@ -217,10 +216,10 @@
/* Replace and remove if found */
if (f != NULL) {
- G_free(f->data);
+ free(f->data);
f->data = q->data;
p->link[p->link[1] == q] = q->link[q->link[0] == NULL];
- G_free(q);
+ free(q);
tree->count--;
removed = 1;
@@ -410,18 +409,32 @@
/* destroy the tree */
void rbtree_destroy(struct RB_TREE *tree)
- rbtree_destroy2(tree->root);
- G_free(tree);
+ struct RB_NODE *it = tree->root;
+ struct RB_NODE *save;
-void rbtree_destroy2(struct RB_NODE *root)
- if (root != NULL) {
- rbtree_destroy2(root->link[0]);
- rbtree_destroy2(root->link[1]);
- G_free(root->data);
- G_free(root);
+ Rotate away the left links so that
+ we can treat this like the destruction
+ of a linked list
+ while ( it != NULL ) {
+ if ( it->link[0] == NULL ) {
+ /* No left links, just kill the node and move on */
+ save = it->link[1];
+ free(it->data);
+ free(it);
+ else {
+ /* Rotate away the left link and check again */
+ save = it->link[0];
+ it->link[0] = save->link[1];
+ save->link[1] = it;
+ it = save;
+ free(tree);
/* used for debugging: check for errors in tree structure */
@@ -486,12 +499,12 @@
/* add a new node to the tree */
struct RB_NODE *rbtree_make_node(size_t datasize, void *data)
- struct RB_NODE *new_node = G_malloc(sizeof(*new_node));
+ struct RB_NODE *new_node = (struct RB_NODE *)malloc(sizeof(*new_node));
if (new_node == NULL)
G_fatal_error("RB Search Tree: Out of memory!");
- new_node->data = G_malloc(datasize);
+ new_node->data = malloc(datasize);
if (new_node->data == NULL)
