[GRASS-SVN] r43588 -
grass/branches/releasebranch_6_4/raster/r.terraflow
svn_grass at osgeo.org
Tue Sep 21 09:30:19 EDT 2010
Author: neteler
Date: 2010-09-21 13:30:18 +0000 (Tue, 21 Sep 2010)
New Revision: 43588
grass/branches/releasebranch_6_4/raster/r.terraflow/grass2str.h
grass/branches/releasebranch_6_4/raster/r.terraflow/main.cc
backport: i18N
Modified: grass/branches/releasebranch_6_4/raster/r.terraflow/grass2str.h
--- grass/branches/releasebranch_6_4/raster/r.terraflow/grass2str.h 2010-09-21 13:27:50 UTC (rev 43587)
+++ grass/branches/releasebranch_6_4/raster/r.terraflow/grass2str.h 2010-09-21 13:30:18 UTC (rev 43588)
@@ -21,6 +21,7 @@
#define _gras2str_H
#include <grass/iostream/ami.h>
+#include <grass/glocale.h>
#include "option.h"
#include "types.h"
#include "common.h"
@@ -48,21 +49,20 @@
char * foo;
str->name(&foo);
- *stats << "reading raster map " << cellname
- << "to stream " << foo << endl;
- if (opt->verbose)
- fprintf(stderr, "reading data from %s to stream %s: ", cellname, foo);
+ *stats << "Reading raster map <" << cellname
+ << "> to stream <" << foo << ">." << endl;
+ G_verbose_message(_("Reading data from <%s> to stream <%s>"), cellname, foo);
char *mapset;
mapset = G_find_cell (cellname, "");
if (mapset == NULL)
- G_fatal_error (_("Raster map <%s> not found"), cellname);
+ G_fatal_error(_("Raster map <%s> not found"), cellname);
/* open map */
int infd;
if ( (infd = G_open_cell_old (cellname, mapset)) < 0)
- G_fatal_error (_("Unable to open raster map <%s>"), cellname);
+ G_fatal_error(_("Unable to open raster map <%s>"), cellname);
/* determine map type (CELL/FCELL/DCELL) */
RASTER_MAP_TYPE data_type;
@@ -82,7 +82,7 @@
/* read input map */
if (G_get_raster_row (infd, inrast, i, data_type) < 0)
- G_fatal_error (_("Unable to read raster map <%s>, row %d"),cellname, i);
+ G_fatal_error(_("Unable to read raster map <%s>, row %d"),cellname, i);
for (int j=0; j<ncols; j++) {
@@ -119,9 +119,9 @@
} else {
/* check range */
if ((d > (DCELL)T_max_value) || (d < (DCELL)T_min_value)) {
- fprintf(stderr, "reading raster map %s at (i=%d,j=%d) value=%.1f\n",
- cellname, i, j, d);
- G_fatal_error("value out of range.");
+ G_fatal_error("Value out of range, reading raster map <%s> "
+ "at (i=%d, j=%d) value=%.1f",
+ cellname, i, j, d);
/* write x to stream */
@@ -140,7 +140,9 @@
G_free(inrast);
/* close map files */
G_close_cell (infd);
+ G_debug(3, "nrows=%d ncols=%d stream_len()=%d", nrows, ncols,
+ str->stream_len());
assert(nrows * ncols == str->stream_len());
rt_stop(rt);
stats->recordTime("reading raster map", rt);
@@ -168,15 +170,15 @@
char * foo;
str->name(&foo);
- *stats << "writing stream " << foo << " to raster map " << cellname << "\n";
- fprintf(stderr, "writing stream %s to raster map %s: ", foo, cellname);
+ *stats << "Writing stream <" << foo << "> to raster map <" << cellname << ">.\n";
+ G_verbose_message(_("Writing stream <%s> to raster map <%s>"), foo, cellname);
/* open output raster map */
int outfd;
- if ( (outfd = G_open_raster_new (cellname, mtype)) < 0) {
+ if ( (outfd = G_open_raster_new (cellname, mtype)) < 0)
G_fatal_error (_("Unable to create raster map <%s>"), cellname);
/* Allocate output buffer */
unsigned char *outrast;
@@ -191,8 +193,8 @@
ae = str->read_item(&elt);
if (ae != AMI_ERROR_NO_ERROR) {
str->sprint();
- fprintf(stderr, "reading stream failed at (%d,%d)\n", i,j);
- G_fatal_error("stream2cell failed");
+ G_fatal_error(_("stream2cell: Reading stream failed at (%d,%d)"),
+ i, j);
/* WRITE VALUE */
@@ -212,7 +214,7 @@
} /* for j*/
if (G_put_raster_row (outfd, outrast, mtype) < 0)
- G_fatal_error ("Cannot write to <%s>",cellname);
+ G_fatal_error(_("Cannot write to <%s>"), cellname);
G_percent(i, nrows, 2);
}/* for i */
@@ -253,14 +255,14 @@
char * foo;
str->name(&foo);
- *stats << "writing stream " << foo << "cellfile " << cellname << endl;
+ *stats << "Writing stream <" << foo << "> to raster map <" << cellname << ">." << endl;
int outfd;
if ( (outfd = G_open_raster_new (cellname, CELL_TYPE)) < 0) {
- G_fatal_error ("Could not open <%s>", cellname);
+ G_fatal_error(_("Could not open <%s>"), cellname);
@@ -291,7 +293,7 @@
} /* for j*/
if (G_put_raster_row (outfd, outrast, CELL_TYPE) < 0)
}/* for i */
@@ -327,14 +329,14 @@
char * foo;
str->name(&foo);
int outfd;
if ( (outfd = G_open_raster_new (cellname, FCELL_TYPE)) < 0) {
@@ -365,7 +367,7 @@
} /* for j*/
if (G_put_raster_row (outfd, outrast, FCELL_TYPE) < 0)
}/* for i */
@@ -408,7 +410,7 @@
assert(str);
#ifndef OUTPUT_TCI
/* this function should be used only if tci is wanted as output */
- fprintf(stderr, "use this function only if tci is wanted as output\n");
+ G_warning("Use this function only if tci is wanted as output");
exit(1);
#else
rt_start(rt);
@@ -417,20 +419,20 @@
char * foo;
str->name(&foo);
- *stats << "writing stream " << foo << "to raster maps "
- << cellname1 << ", " << cellname2 << endl;
- fprintf(stderr, "writing stream %s to raster maps %s, %s: ",
- foo, cellname1, cellname2);
+ *stats << "Writing stream <" << foo << "> to raster maps <"
+ << cellname1 << "> and <" << cellname2 << ">." << endl;
+ G_verbose_message(_("Writing stream <%s> to raster maps <%s> and <%s>"),
+ foo, cellname1, cellname2);
/* open raster maps */
int fd1;
if ( (fd1 = G_open_raster_new (cellname1, FCELL_TYPE)) < 0) {
- G_fatal_error ("Could not open <%s>", cellname1);
+ G_fatal_error (_("Could not open <%s>"), cellname1);
int fd2;
if ( (fd2 = G_open_raster_new (cellname2, FCELL_TYPE)) < 0) {
- G_fatal_error ("Could not open <%s>", cellname2);
+ G_fatal_error (_("Could not open <%s>"), cellname2);
@@ -474,9 +476,9 @@
} /* for j*/
if (G_put_raster_row (fd1, rast1, FCELL_TYPE) < 0)
- G_fatal_error ("Cannot write to <%s>", cellname1);
+ G_fatal_error(_("Cannot write to <%s>"), cellname1);
if (G_put_raster_row (fd2, rast2, FCELL_TYPE) < 0)
- G_fatal_error ("Cannot write to <%s>", cellname2);
+ G_fatal_error(_("Cannot write to <%s>"), cellname2);
Modified: grass/branches/releasebranch_6_4/raster/r.terraflow/main.cc
--- grass/branches/releasebranch_6_4/raster/r.terraflow/main.cc 2010-09-21 13:27:50 UTC (rev 43587)
+++ grass/branches/releasebranch_6_4/raster/r.terraflow/main.cc 2010-09-21 13:30:18 UTC (rev 43588)
@@ -2,7 +2,7 @@
* MODULE: r.terraflow
- * COPYRIGHT (C) 2007 Laura Toma
+ * COPYRIGHT (C) 2007, 2010 Laura Toma
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
@@ -70,32 +70,32 @@
struct Option *output_elev;
output_elev = G_define_standard_option(G_OPT_R_OUTPUT);
output_elev->key = "filled";
- output_elev->description= _("Output filled (flooded) elevation raster map");
+ output_elev->description= _("Name for output filled (flooded) elevation raster map");
/* output direction grid */
struct Option *output_dir;
output_dir = G_define_standard_option(G_OPT_R_OUTPUT);
output_dir->key = "direction";
- output_dir->description= _("Output flow direction raster map");
+ output_dir->description= _("Name for output flow direction raster map");
/* output sinkwatershed grid */
struct Option *output_watershed;
output_watershed = G_define_standard_option(G_OPT_R_OUTPUT);
output_watershed->key = "swatershed";
- output_watershed->description= _("Output sink-watershed raster map");
+ output_watershed->description= _("Name for output sink-watershed raster map");
/* output flow accumulation grid */
struct Option *output_accu;
output_accu = G_define_standard_option(G_OPT_R_OUTPUT);
output_accu->key = "accumulation";
- output_accu->description= _("Output flow accumulation raster map");
+ output_accu->description= _("Name for output flow accumulation raster map");
#ifdef OUTPUT_TCI
struct Option *output_tci;
output_tci = G_define_standard_option(G_OPT_R_OUTPUT);
output_tci->key = "tci";
output_tci->description=
- _("Output topographic convergence index (tci) raster map");
+ _("Name for output topographic convergence index (tci) raster map");
#endif
/* MFD/SFD flag */
@@ -103,7 +103,6 @@
sfd_flag = G_define_flag() ;
sfd_flag->key = 's';
sfd_flag->description= _("SFD (D8) flow (default is MFD)");
- /* sfd_flag->answer = 'n'; */
/* D8CUT value*/
struct Option *d8cut;
@@ -112,9 +111,10 @@
d8cut->type = TYPE_DOUBLE;
d8cut->required = NO;
d8cut->answer = G_store("infinity"); /* default value */
- d8cut->description =
+ d8cut->label = _("Routing using SFD (D8) direction");
+ d8cut->description =
_("If flow accumulation is larger than this value it is routed using "
- "SFD (D8) direction \n \t\t (meaningfull only for MFD flow)");
+ "SFD (D8) direction (meaningfull only for MFD flow)");
/* main memory */
struct Option *mem;
@@ -469,12 +469,12 @@
module = G_define_module();
#ifdef ELEV_SHORT
- module->description = _("Flow computation for massive grids (Integer version).");
+ module->description = _("Flow computation for massive grids (integer version).");
#endif
#ifdef ELEV_FLOAT
- module->description = _("Flow computation for massive grids (Float version).");
+ module->description = _("Flow computation for massive grids (float version).");
#endif
- module->keywords = _("raster");
+ module->keywords = _("raster, hydrology");
/* read user options; fill in global <opt> */
opt = (userOptions*)malloc(sizeof(userOptions));
