[GRASS-SVN] r43594 - grass/branches/releasebranch_6_4/vector/v.info
svn_grass at osgeo.org
Tue Sep 21 10:13:40 EDT 2010
Author: neteler
Date: 2010-09-21 14:13:39 +0000 (Tue, 21 Sep 2010)
New Revision: 43594
grass/branches/releasebranch_6_4/vector/v.info/description.html
grass/branches/releasebranch_6_4/vector/v.info/main.c
backport: topology level 1 support
Modified: grass/branches/releasebranch_6_4/vector/v.info/description.html
--- grass/branches/releasebranch_6_4/vector/v.info/description.html 2010-09-21 13:51:32 UTC (rev 43593)
+++ grass/branches/releasebranch_6_4/vector/v.info/description.html 2010-09-21 14:13:39 UTC (rev 43594)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
<em>v.info</em> reports some basic information about a
-user-specified vector map layer and the topology status.
+user-specified vector map layer and the topology status.
<h2>EXAMPLE</h2>
@@ -38,8 +38,9 @@
</pre></div>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
+Radim Blazek, ITC-Irst, Trento, Italy,<br>
+Markus Metz (level 1 support)
<p><i>Last changed: $Date$</i></p>
Modified: grass/branches/releasebranch_6_4/vector/v.info/main.c
--- grass/branches/releasebranch_6_4/vector/v.info/main.c 2010-09-21 13:51:32 UTC (rev 43593)
+++ grass/branches/releasebranch_6_4/vector/v.info/main.c 2010-09-21 14:13:39 UTC (rev 43594)
@@ -4,15 +4,15 @@
* MODULE: v.info
* AUTHOR(S): CERL, updated to 5.7 by Markus Neteler
+ * Support for level 1 by Markus Metz (2009)
- * PURPOSE: print vector map info
+ * PURPOSE: Print vector map info
- * COPYRIGHT: (C) 2002 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
#include <string.h>
@@ -37,15 +37,14 @@
void format_double(double, char *);
+int level_one_info(struct Map_info *);
int main(int argc, char *argv[])
struct GModule *module;
struct Option *in_opt, *fieldopt;
struct Flag *histf, *columns, *gflag, *tflag, *mflag;
struct Map_info Map;
- struct dig_head v_head;
BOUND_BOX box;
char *mapset, line[200], buf[1001];
int i;
@@ -104,10 +103,19 @@
G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
- Vect_set_open_level(2);
- Vect_open_old_head(&Map, in_opt->answer, mapset);
+ /* try to open head-only on level 2 */
+ if (Vect_open_old_head(&Map, in_opt->answer, "") < 2) {
+ /* force level 1, open fully
+ * NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available */
+ Vect_close(&Map);
+ Vect_set_open_level(1); /* no topology */
+ if (Vect_open_old(&Map, in_opt->answer, "") < 1)
+ G_fatal_error(_("Unable to open vector map <%s>"), Vect_get_full_name(&Map));
+ if (!histf->answer && !mflag->answer && ((gflag->answer || tflag->answer) || !columns->answer))
+ level_one_info(&Map);
with_z = Vect_is_3d(&Map);
- v_head = Map.head;
if (histf->answer) {
Vect_hist_rewind(&Map);
@@ -258,7 +266,7 @@
printline(line);
- if (Vect_level(&Map) > 1) {
+ if (Vect_level(&Map) > 0) {
printline("");
sprintf(line,
_(" Number of points: %-9ld Number of areas: %-9ld"),
@@ -288,10 +296,6 @@
(long)Vect_get_num_dblinks(&Map));
printline(line);
- else { /* should not be reached */
- sprintf(line, _(" No topology present"));
- printline(line);
printline("");
/* this differs from r.info in that proj info IS taken from the map here, not the location settings */
@@ -329,7 +333,7 @@
printline(line);
sprintf(line, _(" Comments:"));
printline(line);
- sprintf(line, " %s", v_head.line_3);
+ sprintf(line, " %s", Vect_get_comment(&Map));
printline(line);
divider('+');
fprintf(stdout, "\n");
@@ -348,3 +352,93 @@
sprintf(buf, "%.8f", value);
G_trim_decimal(buf);
+/* code taken from Vect_build_nat() */
+int level_one_info(struct Map_info *Map)
+ struct Plus_head *plus;
+ int i, type, first = 1;
+ off_t offset;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ struct bound_box box;
+ int n_primitives, n_points, n_lines, n_boundaries, n_centroids;
+ int n_faces, n_kernels;
+ G_debug(1, "Count vector objects for level 1");
+ plus = &(Map->plus);
+ n_primitives = n_points = n_lines = n_boundaries = n_centroids = 0;
+ n_faces = n_kernels = 0;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_rewind(Map);
+ /* G_message(_("Registering primitives...")); */
+ i = 1;
+ while (1) {
+ /* register line */
+ type = Vect_read_next_line(Map, Points, Cats);
+ /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ if (type == -1) {
+ G_warning(_("Unable to read vector map"));
+ return 0;
+ else if (type == -2) {
+ break;
+ /* count features */
+ n_primitives++;
+ if (type & GV_POINT) /* probably most common */
+ n_points++;
+ else if (type & GV_LINE)
+ n_lines++;
+ else if (type & GV_BOUNDARY)
+ n_boundaries++;
+ else if (type & GV_CENTROID)
+ n_centroids++;
+ else if (type & GV_KERNEL)
+ n_kernels++;
+ else if (type & GV_FACE)
+ n_faces++;
+ offset = Map->head.last_offset;
+ G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
+ dig_line_box(Points, &box);
+ if (first == 1) {
+ Vect_box_copy(&(plus->box), &box);
+ first = 0;
+ else
+ Vect_box_extend(&(plus->box), &box);
+ /* can't print progress, unfortunately */
+ if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+ if (format == G_INFO_FORMAT_PLAIN)
+ fprintf(stderr, "%d..", i);
+ else
+ fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
+ i++;
+ /* save result in plus */
+ plus->n_lines = n_primitives;
+ plus->n_plines = n_points;
+ plus->n_llines = n_lines;
+ plus->n_blines = n_boundaries;
+ plus->n_clines = n_centroids;
+ plus->n_klines = n_kernels;
+ plus->n_flines = n_faces;
+ return 1;
