[GRASS-SVN] r43598 - grass/branches/develbranch_6/vector/v.to.db
svn_grass at osgeo.org
Tue Sep 21 11:26:17 EDT 2010
Author: neteler
Date: 2010-09-21 15:26:17 +0000 (Tue, 21 Sep 2010)
New Revision: 43598
grass/branches/develbranch_6/vector/v.to.db/description.html
typo fixed
Modified: grass/branches/develbranch_6/vector/v.to.db/description.html
--- grass/branches/develbranch_6/vector/v.to.db/description.html 2010-09-21 14:38:26 UTC (rev 43597)
+++ grass/branches/develbranch_6/vector/v.to.db/description.html 2010-09-21 15:26:17 UTC (rev 43598)
@@ -21,7 +21,7 @@
When using <em>option=coor</em> on a vector area map,
only coordinates of centroids with unique category will be reported.
<p>
-Line azimuth is calculaded as angle from the North direction to the line endnode
+Line azimuth is calculated as angle from the North direction to the line endnode
direction at the line statnode. By default it's reported in decimal degrees (0-360, CW) but
it also may be repored in radians with <em>unit=radians</em>. Azimuth value
<b>-1</b> is used to report closed line with it's startnode and endnode being in
