[GRASS-SVN] r43600 -
grass-addons/LandDyn/devs_landcover_scripts/r.soil.fertility.py
svn_grass at osgeo.org
Tue Sep 21 14:46:33 EDT 2010
Author: isaacullah
Date: 2010-09-21 18:46:33 +0000 (Tue, 21 Sep 2010)
New Revision: 43600
grass-addons/LandDyn/devs_landcover_scripts/r.soil.fertility.py/r.soil.fertility.py
Refactored r.soil.fertility.py to use internal GRASS python libs. Removed input variable "max" which was the maximum soil fertility value, and replaced with input variable "recovery" which is the rate at which soil recoveres fertiltiy per year. This is a more intuitive way to for the user to interact with the function of soil fertility recovery. All tags in the APSim DEVS agent model have been updated to accomodate these changes.
Modified: grass-addons/LandDyn/devs_landcover_scripts/r.soil.fertility.py/r.soil.fertility.py
--- grass-addons/LandDyn/devs_landcover_scripts/r.soil.fertility.py/r.soil.fertility.py 2010-09-21 15:44:54 UTC (rev 43599)
+++ grass-addons/LandDyn/devs_landcover_scripts/r.soil.fertility.py/r.soil.fertility.py 2010-09-21 18:46:33 UTC (rev 43600)
@@ -36,11 +36,11 @@
#%END
#%option
-#% key: max
+#% key: recovery
#% type: string
#% gisprompt: string
-#% description: maximum value for soil fertility maps (number for highest fertility)
-#% answer: 100
+#% description: The rate at which soil recovers it's fertility per cycle (max fertility is 100)
+#% answer: 1
#% required : yes
#%END
@@ -71,64 +71,49 @@
import os
import subprocess
import tempfile
-# first define some useful custom methods
+import random
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
-# m is a message (as a string) one wishes to have printed in the output window
-def grass_print(m):
- subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
- return
-# m is grass (or bash) command to execute (written as a string). script will wait for grass command to finish
-def grass_com(m):
- subprocess.Popen('%s' % m, shell='bash').wait()
- return
-# m is grass (or bash) command to execute (written as a string). script will not wait for grass command to finish
-def grass_com_nw(m):
- return
-# m is a grass/bash command that will generate some info to stdout. You must invoke this command in the form of "variable to be made" = out2var('command')
-def out2var(m):
- pn = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
- return pn.stdout.read()
-# m is a grass/bash command that will generate some list of info to stdout, n is the character that seperates individual pieces of information, and o is a defined blank list to write results to
-def out2list2(m, n, o):
- p1 = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
- p2 = p1.stdout.readlines()
- for y in p2:
- y0,y1 = y.split('%s' % n)
- o.append(y0)
- o.append(y1.strip('\n'))
#main block of code starts here
def main():
#setting up variables for use later on
inmap = os.getenv('GIS_OPT_inmap')
impacts = os.getenv('GIS_OPT_impacts')
outmap = os.getenv('GIS_OPT_outmap')
- max = os.getenv('GIS_OPT_max')
+ recovery = os.getenv('GIS_OPT_recovery')
sf_color = os.getenv('GIS_OPT_sf_color')
txtout = outmap + '_sfertil_stats.txt'
- #setting initial conditions of map area
- grass_com('g.region rast=' + inmap)
- grass_com('r.mask --quiet -o input=' + inmap + ' maskcats=*')
+ #Check to see if there is a MASK already, and if so, temporarily rename it
+ if "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']]:
+ ismask = 1
+ tempmask = 'mask_%i' % random.randint(0,100)
+ grass.run_command('g.rename', quiet = "True", rast = 'MASK,' + tempmask)
+ else:
+ ismask = 0
+ #Set MASK to input DEM
+ grass.run_command('r.mask', input = inmap)
#updating raw soil fertility category numbers
- grass_com('r.mapcalc "' + outmap + '=if(' + inmap + ' == ' + max + ' && isnull(' + impacts + '), ' + max + ', (if (' + inmap + ' < ' + max + ' && isnull(' + impacts + '), (' + inmap + ' + 1), if (' + inmap + ' > ' + max + ', (' + max + ' - ' + impacts + '), if (' + inmap + ' < 0, 0, (' + inmap + ' - ' + impacts + '))))))"')
- grass_com('r.colors --quiet map=' + outmap + ' rules=' + sf_color)
+ grass.mapcalc('${outmap}=if(isnull(${impacts}) && ${inmap} >= 100 - ${recovery}, 100, if(isnull(${impacts}), (${inmap} + ${recovery}), if(${inmap} >= ${impacts}, (${inmap} - ${impacts}), 0 )))', outmap = outmap, inmap = inmap, recovery = recovery, impacts =impacts )
+ grass.run_command('r.colors', quiet = 'True', map = outmap, rules = sf_color)
#checking total area of updated cells
- temparea = []
- out2list2('r.stats -a -n input=' + impacts + ' fs=, nv=* nsteps=1', ',', temparea)
- grass_print('\n\nTotal area of impacted zones = %s square meters\n\n' % temparea[1])
+ totarea = grass.read_command('r.stats', flags = 'an', input = impacts, fs = ',', nsteps = '1').split(',')
+ grass.message('\n\nTotal area of impacted zones = %s square meters\n\n' % totarea[1])
#creating optional output text file of stats
if os.getenv('GIS_FLAG_s') == '1':
f = file(txtout, 'wt')
- f.write('Stats for ' + outmap+ '\n\nTotal area of impacted zones = ' + temparea[1] + ' square meters\n\nSoil Fertility Value,Area (sq. m)\n\n')
- p1 = subprocess.Popen('r.stats -A -a -n input=' + outmap + ' fs=, nv=* nsteps=' + max, stdout=subprocess.PIPE, shell='bash')
- for y in p2:
- f.write(y)
+ f.write('Stats for ' + outmap+ '\n\nTotal area of impacted zones = ' + totarea[1] + ' square meters\n\nSoil Fertility Value,Area (sq. m)\n')
+ areadict = grass.parse_command('r.stats', flags = 'an', input = impacts)
+ for key in areadict:
+ f.write(key + '\n')
f.close()
- grass_print('\nCleaning up...\n\n')
- grass_com('g.remove --quiet rast=MASK')
- grass_print('DONE!\n\n')
+ grass.message('\nCleaning up...\n\n')
+ grass.run_command('r.mask', flags = 'r')
+ if ismask == 1:
+ grass.run_command('g.rename', quiet = "True", rast = tempmask +',MASK')
+ grass.message('DONE!\n\n')
# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
if __name__ == "__main__":
