[GRASS-SVN] r43602 - grass/branches/releasebranch_6_4/mswindows
Tue Sep 21 21:57:32 EDT 2010
Author: hamish
Date: 2010-09-22 01:57:31 +0000 (Wed, 22 Sep 2010)
New Revision: 43602
   grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi
Helmut: set set PROJ_LIB and GDAL_DATA for proj4/cs2cs in windows (bug #1165, backport r43520 and r43542 from devbr6)
Modified: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi	2010-09-22 01:40:50 UTC (rev 43601)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi	2010-09-22 01:57:31 UTC (rev 43602)
@@ -670,6 +670,12 @@
 	FileWrite $0 'rem Path to the proj files (notably the epsg projection list)$\r$\n'
 	FileWrite $0 'set GRASS_PROJSHARE=%GRASSDIR%\proj$\r$\n'
 	FileWrite $0 '$\r$\n'
+	FileWrite $0 'rem Set GDAL_DATA$\r$\n'
+	FileWrite $0 'set GDAL_DATA=%GRASSDIR%\etc\ogr_csv$\r$\n'
+	FileWrite $0 '$\r$\n'
+	FileWrite $0 'rem Set PROJ_LIB$\r$\n'
+	FileWrite $0 'set PROJ_LIB=%GRASSDIR%\proj$\r$\n'
 	FileWrite $0 'rem Path to the python directory$\r$\n'
 	FileWrite $0 'set PYTHONHOME=%GRASSDIR%\Python25$\r$\n'
 	FileWrite $0 'if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python$\r$\n'
@@ -781,6 +787,13 @@
 	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
 	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
+	FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
+	FileWrite $0 'GDAL_DATA="$INSTALL_DIR\etc\ogr_csv"$\r$\n'
+	FileWrite $0 'export GDAL_DATA$\r$\n'
+	FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
+	FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
+	FileWrite $0 'export PROJ_LIB $\r$\n'
 	FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
 	FileClose $0
 	done_create_grass_command:
