[GRASS-SVN] r43607 -
grass/branches/releasebranch_6_4/scripts/r.in.wms
svn_grass at osgeo.org
Wed Sep 22 05:31:49 EDT 2010
Author: hamish
Date: 2010-09-22 09:31:49 +0000 (Wed, 22 Sep 2010)
New Revision: 43607
grass/branches/releasebranch_6_4/scripts/r.in.wms/r.in.wms
grass/branches/releasebranch_6_4/scripts/r.in.wms/wms.request
backport many fixes from devbr6
Modified: grass/branches/releasebranch_6_4/scripts/r.in.wms/r.in.wms
--- grass/branches/releasebranch_6_4/scripts/r.in.wms/r.in.wms 2010-09-22 08:54:05 UTC (rev 43606)
+++ grass/branches/releasebranch_6_4/scripts/r.in.wms/r.in.wms 2010-09-22 09:31:49 UTC (rev 43607)
@@ -256,10 +256,6 @@
# Remember the intial field seperator
defaultIFS="$IFS"
-# Remember the previous path
-prevPATH="$PATH"
-PATH="$PATH:${GISBASE}/etc/r.in.wms/"
-export PATH
# name: message
@@ -280,9 +276,6 @@
exitprocedure()
g.message -e 'User break!'
- # is this bogus? won't PATH revert on exit anyway?
- PATH="$prevPATH"
- export PATH
\rm -f "${TEMPFILE}"*
exit 1
@@ -396,7 +389,9 @@
if [ -x "`which xml2`" ] ; then
cat "$CAPABILITIES_FILE" | xml2 | \
grep "Layer/SRS=\|Layer/Name=\|Layer/Title=\|Style/Name=\|Style/Title=\|Layer/Abstract=" | \
- sed -e "s/.*Layer\\/Name=/\n\nLAYER: /" \
+ sed -e 's/.*Layer\\/Name=/\
+LAYER: /' \
-e "s/.*Layer\\/SRS=/ SRS: /" \
-e "s/.*Layer\\/Title=/ Title: /" \
-e "s/.*Layer\\/Abstract=/ |/" \
@@ -406,13 +401,19 @@
else : # xml2 is not available
g.message -w "The 'xml2' program was not found. Proceeding with internal XML parsing which may not be as reliable."
- sed -e "s/<Layer/\n<Layer/g" \
- -e "s/<Name>/\n<Name>/g" \
- -e "s/<Style>/\n<Style>/g" \
- -e "s/<Title>/\n<Title>/g" \
+ sed -e 's/<Layer/\
+<Layer/g' \
+ -e 's/<Name>/\
+<Name>/g' \
+ -e 's/<Style>/\
+<Style>/g' \
+ -e 's/<Title>/\
+<Title>/g' \
"$CAPABILITIES_FILE" | \
grep "Name\|Title\|Style\|Layer" | \
- sed -e "s/<Layer .*>/-=-=-=-=-\n\nLAYER:/" \
+ sed -e 's/<Layer .*>/-=-=-=-=-\
+LAYER:/' \
-e "s/<\/Layer.*>//" \
-e "s/<Name>\s*\([^<]*\)/~\1~/g" \
-e "s/<\/Name>\n\?//g" \
@@ -511,7 +512,7 @@
if [ $GIS_FLAG_D -eq 0 ] ; then
message 1 "wms.request $REQUEST"
- eval "wms.request $REQUEST"
+ eval "\"$GISBASE/etc/r.in.wms/wms.request\" $REQUEST"
if [ $? -ne 0 ] ; then
g.message -e "wms.request failure"
exit 1
@@ -524,7 +525,7 @@
addargument DOWNLOAD curloptions "${GIS_OPT_CURLOPTIONS}"
message 1 "wms.download $DOWNLOAD"
-eval "wms.download $DOWNLOAD"
+eval "\"$GISBASE/etc/r.in.wms/wms.download\" $DOWNLOAD"
# Job 2: make list of files
@@ -560,7 +561,7 @@
fi
message 1 "r.in.gdalwarp $GDALWARP"
-eval "r.in.gdalwarp $GDALWARP"
+eval "\"$GISBASE/etc/r.in.wms/r.in.gdalwarp\" $GDALWARP"
g.message -e message="r.in.gdalwarp failed"
exit 1
Modified: grass/branches/releasebranch_6_4/scripts/r.in.wms/wms.request
--- grass/branches/releasebranch_6_4/scripts/r.in.wms/wms.request 2010-09-22 08:54:05 UTC (rev 43606)
+++ grass/branches/releasebranch_6_4/scripts/r.in.wms/wms.request 2010-09-22 09:31:49 UTC (rev 43607)
@@ -132,20 +132,7 @@
g.message -d "[wms.request]"
-SED="sed"
-GREP="grep"
-# check if we have sed
-if [ ! -x "`which $SED`" ] ; then
- g.message "$SED is required, please install it first"
- exit 1
-fi
-# check if we have grep
-if [ ! -x "`which $GREP`" ] ; then
- g.message "$GREP is required, please install it first"
- exit 1
-fi
defaultIFS="$IFS"
@@ -269,18 +256,27 @@
SERVER="${GIS_OPT_MAPSERVER}"
SRS="${GIS_OPT_SRS}"
+# use `tr '[:upper:]' '[:lower:]'` instead?
SRS_lower=`echo $SRS | sed "y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/"`
# If the user asserts that this projection is the same as the source
# use this projection as the source to get a trivial tiling from r.tileset
if [ $GIS_FLAG_P -eq 1 ] ; then
- PROJ4_SRS=`g.proj -j`
- eval `g.proj -p | $GREP meters | $SED "s/\\s*:\\s*/=/"`
- SRS_SCALE=$meters;
+ PROJ4_SRS=`g.proj -j | (
+ PROJ4_SRS=
+ while read line ; do
+ PROJ4_SRS="$PROJ4_SRS '$line'"
+ done
+ echo "$PROJ4_SRS"
+ eval `g.proj -p | grep ^meters | sed "s/\\s*:\\s*/=/"`
+ SRS_SCALE=$meters;
else
- PROJ4_SRS="+init=$SRS_lower"
- SRS_SCALE=1
+ PROJ4_SRS="+init=$SRS_lower"
+ SRS_SCALE=1
fi
WMS_QUERY="${GIS_OPT_WMSQUERY}"
