[GRASS-SVN] r43619 -
grass/branches/releasebranch_6_4/vector/v.in.ascii
svn_grass at osgeo.org
Wed Sep 22 10:05:52 EDT 2010
Author: neteler
Date: 2010-09-22 14:05:51 +0000 (Wed, 22 Sep 2010)
New Revision: 43619
grass/branches/releasebranch_6_4/vector/v.in.ascii/a2b.c
grass/branches/releasebranch_6_4/vector/v.in.ascii/in.c
grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c
backport: accept D:M:S coords in standard mode
Modified: grass/branches/releasebranch_6_4/vector/v.in.ascii/a2b.c
--- grass/branches/releasebranch_6_4/vector/v.in.ascii/a2b.c 2010-09-22 14:00:36 UTC (rev 43618)
+++ grass/branches/releasebranch_6_4/vector/v.in.ascii/a2b.c 2010-09-22 14:05:51 UTC (rev 43619)
@@ -10,6 +10,7 @@
char ctype;
char buff[BUFFSIZE];
+ char east_str[256], north_str[256];
double *xarray;
double *yarray;
double *zarray;
@@ -108,9 +109,19 @@
*z = 0;
- if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2)
- G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
- buff);
+ if (sscanf(buff, "%lf%lf%lf", x, y, z) < 2) {
+ if (sscanf(buff, " %s %s %lf", east_str, north_str, z) < 2) {
+ G_fatal_error(_("Error reading ASCII file: (bad point) [%s]"),
+ buff);
+ } else {
+ if( ! G_scan_easting(east_str, x, G_projection()) )
+ G_fatal_error(_("Unparsable longitude value: [%s]"),
+ east_str);
+ if( ! G_scan_northing(north_str, y, G_projection()) )
+ G_fatal_error(_("Unparsable latitude value: [%s]"),
+ north_str);
G_debug(5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff),
*x, *y, *z);
Modified: grass/branches/releasebranch_6_4/vector/v.in.ascii/in.c
--- grass/branches/releasebranch_6_4/vector/v.in.ascii/in.c 2010-09-22 14:00:36 UTC (rev 43618)
+++ grass/branches/releasebranch_6_4/vector/v.in.ascii/in.c 2010-09-22 14:05:51 UTC (rev 43619)
@@ -8,7 +8,7 @@
* PURPOSE: Converts a vector map in ASCII format to a vector map
* in binary format
- * COPYRIGHT: (C) 2000-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -65,12 +65,14 @@
format_opt->multiple = NO;
format_opt->options = "point,standard";
format_opt->descriptions = _("point;simple x,y[,z] list;"
- "standard;GRASS's vector ASCII format");
+ "standard;GRASS vector ASCII format");
format_opt->answer = "point";
format_opt->description = _("Input file format");
+ format_opt->guisection = _("Input format");
delim_opt = G_define_standard_option(G_OPT_F_SEP);
+ delim_opt->guisection = _("Input format");
skip_opt = G_define_option();
skip_opt->key = "skip";
skip_opt->type = TYPE_INTEGER;
@@ -79,27 +81,28 @@
skip_opt->answer = "0";
skip_opt->description =
_("Number of header lines to skip at top of input file (points mode)");
+ skip_opt->guisection = _("Points");
columns_opt = G_define_option();
columns_opt->key = "columns";
columns_opt->type = TYPE_STRING;
columns_opt->required = NO;
columns_opt->multiple = NO;
- columns_opt->guisection = _("Columns");
+ columns_opt->guisection = _("Points");
columns_opt->label = _("Column definition in SQL style (points mode)");
columns_opt->description = _("For example: "
"'x double precision, y double precision, cat int, "
"name varchar(10)'");
xcol_opt = G_define_option();
xcol_opt->key = "x";
xcol_opt->type = TYPE_INTEGER;
xcol_opt->required = NO;
xcol_opt->multiple = NO;
xcol_opt->answer = "1";
- xcol_opt->guisection = _("Columns");
- xcol_opt->description =
- _("Number of column used as x coordinate (first column is 1) for points mode");
+ xcol_opt->guisection = _("Points");
+ xcol_opt->label = ("Number of column used as x coordinate (points mode)");
+ xcol_opt->description = _("First column is 1");
ycol_opt = G_define_option();
ycol_opt->key = "y";
@@ -107,9 +110,9 @@
ycol_opt->required = NO;
ycol_opt->multiple = NO;
ycol_opt->answer = "2";
- ycol_opt->guisection = _("Columns");
- ycol_opt->description =
- _("Number of column used as y coordinate (first column is 1) for points mode");
+ ycol_opt->guisection = _("Points");
+ ycol_opt->label = _("Number of column used as y coordinate (points mode)");
+ ycol_opt->description = _("First column is 1");
zcol_opt = G_define_option();
zcol_opt->key = "z";
@@ -117,11 +120,9 @@
zcol_opt->required = NO;
zcol_opt->multiple = NO;
zcol_opt->answer = "0";
- zcol_opt->guisection = _("Columns");
- zcol_opt->label =
- _("Number of column used as z coordinate (first column is 1) for "
- "points mode");
- zcol_opt->description = _("If 0, z coordinate is not used");
+ zcol_opt->guisection = _("Points");
+ zcol_opt->label = _("Number of column used as z coordinate (points mode)");
+ zcol_opt->description = _("First column is 1. If 0, z coordinate is not used");
catcol_opt = G_define_option();
catcol_opt->key = "cat";
@@ -129,12 +130,12 @@
catcol_opt->required = NO;
catcol_opt->multiple = NO;
catcol_opt->answer = "0";
- catcol_opt->guisection = _("Columns");
+ catcol_opt->guisection = _("Points");
catcol_opt->label =
- _("Number of column used as category (first column is 1) for points mode");
+ _("Number of column used as category (points mode)");
catcol_opt->description =
- _("If 0, unique category is assigned to each row and written to new column 'cat'");
+ _("First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'");
zcoorf = G_define_flag();
zcoorf->key = 'z';
zcoorf->description = _("Create 3D vector map");
@@ -142,28 +143,30 @@
e_flag = G_define_flag();
e_flag->key = 'e';
e_flag->description =
- _("Create a new empty vector map and exit. Nothing is read from input");
+ _("Create a new empty vector map and exit. Nothing is read from input.");
noheader_flag = G_define_flag();
noheader_flag->key = 'n';
noheader_flag->description =
_("Don't expect a header when reading in standard format");
+ noheader_flag->guisection = _("Input format");
t_flag = G_define_flag();
t_flag->key = 't';
t_flag->description = _("Do not create table in points mode");
- t_flag->guisection = _("Columns");
+ t_flag->guisection = _("Points");
notopol_flag = G_define_flag();
notopol_flag->key = 'b';
notopol_flag->description = _("Do not build topology in points mode");
+ notopol_flag->guisection = _("Points");
region_flag = G_define_flag();
region_flag->key = 'r';
region_flag->description =
_("Only import points falling within current region (points mode)");
+ region_flag->guisection = _("Points");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -186,7 +189,7 @@
/* specifying zcol= implies that a 3D map is needed */
if (zcol >= 0 && !zcoorf->answer)
- zcoorf->answer = 1;
+ zcoorf->answer = TRUE;
if (zcoorf->answer && format == FORMAT_POINT && zcol < 0)
G_fatal_error(_("Please specify reasonable z column"));
@@ -196,7 +199,7 @@
if (xcol+1 < 1 || ycol+1 < 1 || zcol+1 < 0 || catcol+1 < 0)
G_fatal_error(_("Column numbers must not be negative"));
- if (old->answer != NULL) {
+ if ( (old->answer != NULL) && (strcmp(old->answer, "-") != 0) ) {
if ((ascii = fopen(old->answer, "r")) == NULL) {
G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
Modified: grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c
--- grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c 2010-09-22 14:00:36 UTC (rev 43618)
+++ grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c 2010-09-22 14:05:51 UTC (rev 43619)
@@ -215,6 +215,11 @@
+ len = strlen(tokens[i]);
+ /* do not guess column type for missing values */
+ if (len == 0)
+ continue;
G_debug(4, "row %d col %d: '%s' is_int = %d is_double = %d",
row, i, tokens[i], is_int(tokens[i]),
is_double(tokens[i]));
@@ -230,7 +235,6 @@
/* string */
coltype[i] = DB_C_TYPE_STRING;
- len = strlen(tokens[i]);
if (len > collen[i])
collen[i] = len;
