[GRASS-SVN] r43623 - grass/branches/releasebranch_6_4/vector/v.surf.idw
Wed Sep 22 12:23:02 EDT 2010
Author: neteler
Date: 2010-09-22 16:23:02 +0000 (Wed, 22 Sep 2010)
New Revision: 43623
   grass/branches/releasebranch_6_4/vector/v.surf.idw/main.c
backport: guisection cosmetics
Modified: grass/branches/releasebranch_6_4/vector/v.surf.idw/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.idw/main.c	2010-09-22 16:22:21 UTC (rev 43622)
+++ grass/branches/releasebranch_6_4/vector/v.surf.idw/main.c	2010-09-22 16:23:02 UTC (rev 43623)
@@ -90,6 +90,21 @@
     parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
+    parm.dfield->description =
+	_("If set to 0, z coordinates are used (3D vector only)");
+    parm.dfield->answer = "1";
+    parm.dfield->gisprompt = "old_layer,layer,layer_zero";
+    parm.dfield->guisection = _("Values");
+    parm.col = G_define_option();
+    parm.col->key = "column";
+    parm.col->type = TYPE_STRING;
+    parm.col->required = NO;
+    parm.col->label = _("Attribute table column with values to interpolate");
+    parm.col->description = _("Required if layer > 0");
+    parm.col->guisection = _("Values");
     parm.npoints = G_define_option();
     parm.npoints->key = "npoints";
     parm.npoints->key_desc = "count";
@@ -97,6 +112,7 @@
     parm.npoints->required = NO;
     parm.npoints->description = _("Number of interpolation points");
     parm.npoints->answer = "12";
+    parm.npoints->guisection = _("Settings");
     parm.power = G_define_option();
     parm.power->key = "power";
@@ -104,26 +120,15 @@
     parm.power->answer = "2.0";
     parm.power->description =
     	_("Power parameter; greater values assign greater influence to closer points");
+    parm.power->guisection = _("Settings");
-    parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
-    parm.dfield->description =
-	_("If set to 0, z coordinates are used (3D vector only)");
-    parm.dfield->answer = "1";
-    parm.dfield->gisprompt = "old_layer,layer,layer_zero";
-    parm.col = G_define_option();
-    parm.col->key = "column";
-    parm.col->type = TYPE_STRING;
-    parm.col->required = NO;
-    parm.col->label = _("Attribute table column with values to interpolate");
-    parm.col->description = _("Required if layer > 0");
     noindex = G_define_flag();
     noindex->key = 'n';
     noindex->label = _("Don't index points by raster cell");
     noindex->description = _("Slower but uses"
 			     " less memory and includes points from outside region"
 			     " in the interpolation");
+    noindex->guisection = _("Settings");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
