[GRASS-SVN] r43625 -
grass/branches/releasebranch_6_4/vector/v.univar
svn_grass at osgeo.org
Wed Sep 22 14:36:25 EDT 2010
Author: neteler
Date: 2010-09-22 18:36:25 +0000 (Wed, 22 Sep 2010)
New Revision: 43625
grass/branches/releasebranch_6_4/vector/v.univar/main.c
backport: geometry distances instead of table data
Modified: grass/branches/releasebranch_6_4/vector/v.univar/main.c
--- grass/branches/releasebranch_6_4/vector/v.univar/main.c 2010-09-22 18:32:27 UTC (rev 43624)
+++ grass/branches/releasebranch_6_4/vector/v.univar/main.c 2010-09-22 18:36:25 UTC (rev 43625)
@@ -24,42 +24,49 @@
#include <grass/dbmi.h>
#include <grass/glocale.h>
-int main(int argc, char *argv[])
- struct GModule *module;
- struct Option *map_opt, *type_opt, *field_opt, *col_opt, *where_opt,
- *percentile;
- struct Flag *shell_flag, *extended;
- char *mapset;
- struct Map_info Map;
- struct field_info *Fi;
- dbDriver *Driver;
- dbCatValArray Cvarr;
- struct line_pnts *Points;
- struct line_cats *Cats;
- int otype, ofield;
- int compatible = 1; /* types are compatible: point+centroid or line+boundary or area */
- int nrec, ctype, nlines, line, nareas, area;
- int nmissing = 0; /* number of missing atttributes */
- int nnull = 0; /* number of null values */
- int first = 1;
+struct GModule *module;
+struct Option *map_opt, *type_opt, *field_opt, *col_opt, *where_opt,
+ *percentile;
+struct Flag *shell_flag, *extended, *geometry;
+char *mapset;
+struct Map_info Map;
+struct field_info *Fi;
+dbDriver *Driver;
+dbCatValArray Cvarr;
+struct line_pnts *Points;
+struct line_cats *Cats;
+int otype, ofield;
+int compatible = 1; /* types are compatible: point+centroid or line+boundary or area */
+int nrec, ctype, nlines, line, nareas, area;
+int nmissing = 0; /* number of missing atttributes */
+int nnull = 0; /* number of null values */
+int nzero = 0; /* number of zero distances */
+int first = 1;
- /* Statistics */
- int count = 0; /* number of features with non-null attribute */
- double sum = 0.0;
- double sumsq = 0.0;
- double sumcb = 0.0;
- double sumqt = 0.0;
- double sum_abs = 0.0;
- double min = 0.0 / 0.0; /* init as nan */
- double max = 0.0 / 0.0;
- double mean, mean_abs, pop_variance, sample_variance, pop_stdev,
- sample_stdev, pop_coeff_variation, kurtosis, skewness;
- double total_size = 0.0; /* total size: length/area */
+/* Statistics */
+int count = 0; /* number of features with non-null attribute */
+int nprim; /* number of primitives */
- /* Extended statistics */
- int perc;
+double sum = 0.0;
+double sumsq = 0.0;
+double sumcb = 0.0;
+double sumqt = 0.0;
+double sum_abs = 0.0;
+double min = 0.0 / 0.0; /* init as nan */
+double max = 0.0 / 0.0;
+double mean, mean_abs, pop_variance, sample_variance, pop_stdev, sample_stdev,
+ pop_coeff_variation, kurtosis, skewness;
+double total_size = 0.0; /* total size: length/area */
+/* Extended statistics */
+int perc;
+static void select_from_geometry(void);
+static void select_from_database(void);
+static void summary(void);
+int main(int argc, char *argv[])
module = G_define_module();
module->keywords = _("vector, statistics");
module->description =
@@ -74,7 +81,7 @@
col_opt = G_define_option();
col_opt->key = "column";
col_opt->type = TYPE_STRING;
- col_opt->required = YES;
+ col_opt->required = NO;
col_opt->multiple = NO;
col_opt->description = _("Column name");
@@ -99,10 +106,19 @@
extended->key = 'e';
extended->description = _("Calculate extended statistics");
+ geometry = G_define_flag();
+ geometry->key = 'd';
+ geometry->description = _("Calculate geometry distances instead of table data.");
G_gisinit(argv[0]);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* Only require col_opt answer if -g flag is not set */
+ if (!col_opt->answer && !geometry->answer) {
+ G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"), col_opt->key, col_opt->description);
otype = Vect_option_to_types(type_opt);
ofield = atoi(field_opt->answer);
perc = atoi(percentile->answer);
@@ -122,18 +138,120 @@
compatible = 0;
if ((otype & GV_LINES) && (otype & GV_AREA))
compatible = 0;
+ if (!compatible && geometry->answer)
+ compatible = 1; /* distances is copatible with all kinds of geometries */
if (!compatible) {
G_warning(_("Incompatible vector type(s) specified, only number of features, minimum, maximum and range "
"can be calculated"));
- if (extended->answer && !(otype & GV_POINTS)) {
+ if (extended->answer && (!(otype & GV_POINTS) || geometry->answer)) {
G_warning(_("Extended statistics is currently supported only for points/centroids"));
- /* Read attributes */
- db_CatValArray_init(&Cvarr);
+ if(geometry->answer)
+ select_from_geometry();
+ else
+ select_from_database();
+ summary();
+ Vect_close(&Map);
+ exit(EXIT_SUCCESS);
+ int i, ncats, *cats;
+ struct line_pnts *iPoints, *jPoints;
+ iPoints = Vect_new_line_struct();
+ jPoints = Vect_new_line_struct();
+ if (where_opt->answer != NULL) {
+ if (ofield < 1) {
+ G_fatal_error(_("'layer' must be > 0 for 'where'."));
+ Fi = Vect_get_field(&Map, ofield);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ ofield);
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (Driver == NULL)
+ G_fatal_error("Unable to open database <%s> by driver <%s>",
+ Fi->database, Fi->driver);
+ ncats = db_select_int(Driver, Fi->table, Fi->key, where_opt->answer,
+ &cats);
+ if (ncats == -1)
+ G_fatal_error(_("Unable select categories from table <%s>"), Fi->table);
+ db_close_database_shutdown_driver(Driver);
+ count = 0;
+ nprim = Vect_get_num_primitives(&Map, otype);
+ /* Start calculating the statistics based on distance to all other primitives.
+ Use the centroid of areas and the first point of lines */
+ for(i=1;i <= nprim; i++) {
+ int j;
+ int ri;
+ ri = Vect_read_line(&Map, iPoints, Cats, i);
+ if(where_opt->answer) {
+ int ok=FALSE;
+ for(j=0; j < Cats->n_cats; j++) {
+ if(Vect_cat_in_array(Cats->cat[j], cats, ncats)) {
+ ok = TRUE;
+ break;
+ if(!ok)
+ continue;
+ for(j=i+1; j < nprim; j++) {
+ /* get distance to this object */
+ int rj;
+ int k;
+ rj = Vect_read_line(&Map, jPoints, Cats, j);
+ double val = 0.0;
+ /* now calculate the min distance between each point in line i with line j */
+ for(k=0; k < iPoints->n_points; k++) {
+ double dmin = 0.0;
+ Vect_line_distance(jPoints, iPoints->x[k], iPoints->y[k], iPoints->z[k], 1,
+ NULL, NULL, NULL, &dmin, NULL, NULL);
+ if((k == 0) || (dmin < val)) {
+ val = dmin;
+ if(val == 0) {
+ nzero++;
+ continue;
+ if (first) {
+ max = val;
+ min = val;
+ first = 0;
+ else {
+ if (val > max)
+ max = val;
+ if (val < min)
+ min = val;
+ sum += val;
+ sumsq += val * val;
+ sumcb += val * val * val;
+ sumqt += val * val * val * val;
+ sum_abs += fabs(val);
+ count++;
+ G_debug(3, "i=%d j=%d sum = %f val=%f", i, j, sum, val);
if (Fi == NULL) {
G_fatal_error(_("Unable to get layer info for vector map"));
@@ -143,9 +261,8 @@
if (Driver == NULL)
/* Note do not check if the column exists in the table because it may be an expression */
+ db_CatValArray_init(&Cvarr);
nrec =
db_select_CatValArray(Driver, Fi->table, Fi->key, col_opt->answer,
where_opt->answer, &Cvarr);
@@ -160,6 +277,7 @@
/* Lines */
nlines = Vect_get_num_lines(&Map);
@@ -311,9 +429,12 @@
G_debug(2, "sum = %f total_size = %f", sum, total_size);
if (compatible) {
- if ((otype & GV_LINES) || (otype & GV_AREA)) {
+ if (((otype & GV_LINES) || (otype & GV_AREA)) && !geometry->answer) {
mean = sum / total_size;
mean_abs = sum_abs / total_size;
/* Roger Bivand says it is wrong see GRASS devel list 7/2004 */
@@ -325,15 +446,15 @@
else {
double n = count;
- mean = sum / count;
- mean_abs = sum_abs / count;
- pop_variance = (sumsq - sum * sum / count) / count;
+ mean = sum / n;
+ mean_abs = sum_abs / n;
+ pop_variance = (sumsq - sum * sum / n) / n;
pop_stdev = sqrt(pop_variance);
- pop_coeff_variation = pop_stdev / (sqrt(sum * sum) / count);
- sample_variance = (sumsq - sum * sum / count) / (count - 1);
+ pop_coeff_variation = pop_stdev / (sqrt(sum * sum) / n);
+ sample_variance = (sumsq - sum * sum / n) / (count - 1);
sample_stdev = sqrt(sample_variance);
kurtosis =
- (sumqt / count - 4 * sum * sumcb / (n * n) +
+ (sumqt / n - 4 * sum * sumcb / (n * n) +
6 * sum * sum * sumsq / (n * n * n) -
3 * sum * sum * sum * sum / (n * n * n * n))
/ (sample_stdev * sample_stdev * sample_stdev *
@@ -349,8 +470,13 @@
if (shell_flag->answer) {
fprintf(stdout, "n=%d\n", count);
- fprintf(stdout, "nmissing=%d\n", nmissing);
- fprintf(stdout, "nnull=%d\n", nnull);
+ if(geometry->answer) {
+ fprintf(stdout, "nzero=%d\n", nzero);
+ else {
+ fprintf(stdout, "nmissing=%d\n", nmissing);
+ fprintf(stdout, "nnull=%d\n", nnull);
if (count > 0) {
fprintf(stdout, "min=%g\n", min);
fprintf(stdout, "max=%g\n", max);
@@ -372,10 +498,17 @@
else {
- fprintf(stdout, "number of features with non NULL attribute: %d\n",
- count);
- fprintf(stdout, "number of missing attributes: %d\n", nmissing);
- fprintf(stdout, "number of NULL attributes: %d\n", nnull);
+ fprintf(stdout, "number of primitives: %d\n", nprim);
+ fprintf(stdout, "number of non zero distances: %d\n", count);
+ fprintf(stdout, "number of zero distances: %d\n", nzero);
+ else {
+ fprintf(stdout, "number of features with non NULL attribute: %d\n",
+ count);
+ fprintf(stdout, "number of missing attributes: %d\n", nmissing);
+ fprintf(stdout, "number of NULL attributes: %d\n", nnull);
if (count > 0) {
fprintf(stdout, "minimum: %g\n", min);
fprintf(stdout, "maximum: %g\n", max);
@@ -400,7 +533,8 @@
/* TODO: mode, skewness, kurtosis */
- if (extended->answer && compatible && (otype & GV_POINTS) && count > 0) {
+ /* Not possible to calculate for point distance, since we don't collect the population */
+ if (extended->answer && compatible && (otype & GV_POINTS) && !geometry->answer && count > 0) {
double quartile_25 = 0.0, quartile_75 = 0.0, quartile_perc = 0.0;
double median = 0.0;
int qpos_25, qpos_75, qpos_perc;
@@ -460,8 +594,5 @@
fprintf(stdout, "%dth percentile: %g\n", perc, quartile_perc);
- Vect_close(&Map);
- exit(EXIT_SUCCESS);
