[GRASS-SVN] r43637 - grass/branches/releasebranch_6_4/lib/ogsf
svn_grass at osgeo.org
Wed Sep 22 16:23:06 EDT 2010
Author: neteler
Date: 2010-09-22 20:23:06 +0000 (Wed, 22 Sep 2010)
New Revision: 43637
grass/branches/releasebranch_6_4/lib/ogsf/GS2.c
grass/branches/releasebranch_6_4/lib/ogsf/Gs3.c
backport: documentation updates; bugfix from r42689
Modified: grass/branches/releasebranch_6_4/lib/ogsf/GS2.c
--- grass/branches/releasebranch_6_4/lib/ogsf/GS2.c 2010-09-22 20:18:42 UTC (rev 43636)
+++ grass/branches/releasebranch_6_4/lib/ogsf/GS2.c 2010-09-22 20:23:06 UTC (rev 43637)
@@ -314,7 +314,7 @@
\brief Get light position
- \param num light id (starts with 1?)
+ \param num light id (starts at 1)
\param[out] xpos,ypos,zpos coordinates
\param[out] local ?
@@ -338,7 +338,7 @@
\brief Set light color
\param red,green,blue color values (from 0.0 to 1.0)
void GS_setlight_color(int num, float red, float green, float blue)
@@ -360,7 +360,7 @@
\brief Get light color
\param[out] red,green,blue color values
void GS_getlight_color(int num, float *red, float *green, float *blue)
@@ -382,7 +382,7 @@
Red, green, blue from 0.0 to 1.0
void GS_setlight_ambient(int num, float red, float green, float blue)
@@ -404,7 +404,7 @@
\brief Get light ambient
void GS_getlight_ambient(int num, float *red, float *green, float *blue)
@@ -453,7 +453,7 @@
\brief Switch on/off light
\param on non-zero for 'on' otherwise 'off'
void GS_switchlight(int num, int on)
@@ -796,17 +796,19 @@
- \brief Draw fringe around data at selected corners
+ \brief Draw fringe around data (surface) at selected corners
\param id surface id
- \param clr ?
+ \param clr color
\param elev elevation value
- \param where ?
+ \param where nw/ne/sw/se edges - 0 (turn off) 1 (turn on)
void GS_draw_fringe(int id, unsigned long clr, float elev, int *where)
geosurf *gs;
+ G_debug(3, "GS_draw_fringe(): id: %d clr: %ld elev %f edges: %d %d %d %d",
+ id, clr, elev, where[0], where[1], where[2], where[3]);
if ((gs = gs_get_surf(id)))
gsd_display_fringe(gs, clr, elev, where);
@@ -1144,23 +1146,23 @@
return (-1);
-#define CATSREADY
-#ifdef CATSREADY
- \brief Print categories on given position
+ \brief Get surface category on given position
- prints "no data" or a description (i.e., "coniferous forest") to catstr
- Usually call after GS_get_selected_point_on_surface
- att_src must be MAP_ATT
+ Prints "no data" or a description (i.e., "coniferous forest") to
+ <i>catstr</i>. Usually call after GS_get_selected_point_on_surface().
+ Define <i>att</i> as MAP_ATT
+ \todo Allocate catstr using G_store()
- \param att
+ \param att attribute id (MAP_ATT)
\param catstr cat string (must be allocated, dim?)
\param x,y real coordinates
\return -1 if no category info or point outside of window
\return 1 on success
int GS_get_cat_at_xy(int id, int att, char *catstr, float x, float y)
int offset, drow, dcol, vrow, vcol;
@@ -1172,7 +1174,7 @@
gs = gs_get_surf(id);
if (NULL == gs) {
- return (-1);
+ return -1;
pt[X] = x;
@@ -1180,16 +1182,16 @@
gsd_real2surf(gs, pt);
if (gs_point_is_masked(gs, pt)) {
- return (-1);
+ return -1;
if (!in_vregion(gs, pt)) {
- return (-1);
+ return -1;
if (MAP_ATT != gs_get_att_src(gs, att)) {
- sprintf(catstr, "no category info");
- return (-1);
+ sprintf(catstr, _("no category info"));
+ return -1;
buff = gs_get_att_typbuff(gs, att, 0);
@@ -1200,17 +1202,16 @@
dcol = VCOL2DCOL(gs, vcol);
offset = DRC2OFF(gs, drow, dcol);
if (GET_MAPATT(buff, offset, ftmp)) {
return
- (Gs_get_cat_label
- (gsds_get_name(gs->att[att].hdata), drow, dcol, catstr));
+ (Gs_get_cat_label(gsds_get_name(gs->att[att].hdata),
+ drow, dcol, catstr));
- sprintf(catstr, "no data");
+ sprintf(catstr, _("no data"));
- return (1);
+ return 1;
@@ -1274,20 +1275,18 @@
- \brief Get RGB color at given point
+ \brief Get RGB color at given point
- Colors are translated to rgb and returned as Rxxx Gxxx Bxxx
- Usually call after GS_get_selected_point_on_surface()
+ Colors are translated to rgb and returned as Rxxx Gxxx Bxxx Usually
+ call after GS_get_selected_point_on_surface().
- Prints "NULL" or the value (i.e., "921.5") to valstr
+ Prints NULL or the value (i.e., "921.5") to valstr
- \param att
\param[out] valstr value string (allocated, dim?)
\return -1 if point outside of window or masked
@@ -1300,9 +1299,9 @@
*valstr = '\0';
if (NULL == gs) {
- return (-1);
+ return -1;
pt[X] = x;
@@ -1311,7 +1310,7 @@
- return (-1);
+ return -1;
@@ -1330,10 +1329,10 @@
sprintf(valstr, "%f", gs->att[att].constant);
- return (1);
+ return 1;
else if (MAP_ATT != gs_get_att_src(gs, att)) {
- return (-1);
+ return -1;
@@ -1366,8 +1365,6 @@
return (1);
-#endif
\brief Unset attribute
@@ -3189,14 +3186,15 @@
- \brief Measure distance "as the ball rolls" between two points on surface
+ \brief Measure distance "as the ball rolls" between two points on
+ surface
- \param hs
- \param x1,y1,x2,y2 distance line nodes
- \param dist ?
- \param use_exag use exag ?
+ \param hs surface id
+ \param x1,y1,x2,y2 two points on surface
+ \param[out] dist measured distance
+ \param use_exag use exag. surface
- \return 0 on error or if one or more points is not in region,
+ \return 0 on error or if one or more points is not in region
\return distance following terrain
int GS_get_distance_alongsurf(int hs, float x1, float y1, float x2, float y2,
@@ -3204,11 +3202,12 @@
geosurf *gs;
float p1[2], p2[2];
- if (NULL == (gs = gs_get_surf(hs))) {
- return (0);
+ gs = gs_get_surf(hs);
+ if (gs == NULL) {
+ return 0;
p1[X] = x1;
p1[Y] = y1;
p2[X] = x2;
@@ -3216,7 +3215,9 @@
gsd_real2surf(gs, p1);
gsd_real2surf(gs, p2);
- return (gs_distance_onsurf(gs, p1, p2, dist, use_exag));
+ G_debug(3, "GS_get_distance_alongsurf(): hs=%d p1=%f,%f p2=%f,%f",
+ hs, x1, y1, x2, y2);
+ return gs_distance_onsurf(gs, p1, p2, dist, use_exag);
Modified: grass/branches/releasebranch_6_4/lib/ogsf/Gs3.c
--- grass/branches/releasebranch_6_4/lib/ogsf/Gs3.c 2010-09-22 20:18:42 UTC (rev 43636)
+++ grass/branches/releasebranch_6_4/lib/ogsf/Gs3.c 2010-09-22 20:23:06 UTC (rev 43637)
@@ -706,7 +706,8 @@
cur = buff;
- G_message(_("Translating colors from raster map <%s>..."), filename);
+ G_message(_("Translating colors from raster map <%s>..."),
+ G_fully_qualified_name(filename, mapset));
for (i = 0; i < rows; i++) {
G_lookup_colors(cur, r, g, b, set, cols, &colrules);
@@ -777,8 +778,9 @@
fcur = fbuf;
icur = ibuf;
G_lookup_f_raster_colors(fcur, r, g, b, set, cols, &colrules);
G_percent(i, rows, 2);
