[GRASS-SVN] r43650 - grass/trunk/raster/r.surf.random
svn_grass at osgeo.org
Thu Sep 23 09:34:54 EDT 2010
Author: martinl
Date: 2010-09-23 13:34:53 +0000 (Thu, 23 Sep 2010)
New Revision: 43650
grass/trunk/raster/r.surf.random/main.c
grass/trunk/raster/r.surf.random/randsurf.c
r.surf.random: be more verbose
(merge r43648 from devbr6)
Modified: grass/trunk/raster/r.surf.random/main.c
--- grass/trunk/raster/r.surf.random/main.c 2010-09-23 13:29:50 UTC (rev 43649)
+++ grass/trunk/raster/r.surf.random/main.c 2010-09-23 13:34:53 UTC (rev 43650)
@@ -6,7 +6,7 @@
* Midlands Regional Research Laboratory (ASSIST)
* AUTHOR(S): Markus Neteler <neteler itc.it> (original contributor)
* PURPOSE: produces a raster map layer of uniform random deviates
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2006, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -37,10 +37,9 @@
G_add_keyword(_("surface"));
G_add_keyword(_("random"));
module->description =
- _("Produces a raster map layer of uniform random "
+ _("Produces a raster map of uniform random "
"deviates whose range can be expressed by the user.");
out = G_define_standard_option(G_OPT_R_OUTPUT);
min = G_define_option();
@@ -57,7 +56,7 @@
i_flag = G_define_flag();
i_flag->key = 'i';
- i_flag->description = _("Create an integer map");
+ i_flag->description = _("Create an integer raster map");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -65,5 +64,7 @@
randsurf(out->answer, atoi(min->answer), atoi(max->answer),
i_flag->answer);
+ G_done_msg(_("Raster map <%s> generated."), out->answer);
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.surf.random/randsurf.c
--- grass/trunk/raster/r.surf.random/randsurf.c 2010-09-23 13:29:50 UTC (rev 43649)
+++ grass/trunk/raster/r.surf.random/randsurf.c 2010-09-23 13:34:53 UTC (rev 43650)
@@ -36,6 +36,7 @@
/****** PASS THROUGH EACH CELL ASSIGNING RANDOM VALUE ******/
for (row_count = 0; row_count < nrows; row_count++) {
+ G_percent(row_count, nrows, 2);
for (col_count = 0; col_count < ncols; col_count++) {
if (int_map)
*(row_out_C + col_count) =
@@ -53,7 +54,8 @@
else
Rast_put_d_row(fd_out, (DCELL *) row_out_D);
+ G_percent(1, 1, 1);
Rast_close(fd_out);
return 0;
